查看: 198|回复: 1
STM32单片机+SX1278官方源码分享
发表于 2022-5-31 10:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自带收发功能,支持SX1272/1276/1278
! ]4 q6 f% v3 s0 E* O* V" P
# D) F) O& ?! y" V0 S* S
  • #include <string.h>
  • #include <stdint.h>
  • #include <stdbool.h>
  • #include "platform.h"
  • #include "led.h"
  • #if USE_UART
  • #include "uart.h"
  • #endif
  • #include "radio.h"
  • #define BUFFER_SIZE                                 9 // Define the payload size here
  • static uint16_t BufferSize = BUFFER_SIZE;                        // RF buffer size
  • static uint8_t Buffer[BUFFER_SIZE];                                        // RF buffer
  • static uint8_t EnableMaster = true;                                 // Master/Slave selection
  • tRadioDriver *Radio = NULL;
  • const uint8_t PingMsg[] = "PING";
  • const uint8_t PongMsg[] = "PONG";
  • * Manages the master operation
  • void OnMaster( void )
  •     uint8_t i;
  •     switch( Radio->Process( ) )
  •     case RF_RX_TIMEOUT:
  •         // Send the next PING frame
  •         Buffer[0] = 'P';
  •         Buffer[1] = 'I';
  •         Buffer[2] = 'N';
  •         Buffer[3] = 'G';
  •         for( i = 4; i < BufferSize; i++ )
  •             Buffer = i - 4;
  •         Radio->SetTxPacket( Buffer, BufferSize );
  •         break;
  •     case RF_RX_DONE:
  •         Radio->GetRxPacket( Buffer, ( uint16_t* )&BufferSize );
  •         if( BufferSize > 0 )
  •             if( strncmp( ( const char* )Buffer, ( const char* )PongMsg, 4 ) == 0 )
  •                 // Indicates on a LED that the received frame is a PONG
  •                 LedToggle( LED_GREEN );
  •                 Buffer[0] = 'P';
  •                 Buffer[1] = 'I';
  •                 Buffer[2] = 'N';
  •                 Buffer[3] = 'G';
  •                 // We fill the buffer with numbers for the payload
  •                     Buffer = i - 4;
  •             else if( strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
  •             { // A master already exists then become a slave
  •                 EnableMaster = false;
  •                 LedOff( LED_RED );
  •         break;
  •     case RF_TX_DONE:
  •         // Indicates on a LED that we have sent a PING
  •         LedToggle( LED_RED );
  •         Radio->StartRx( );
  •         break;
  •     default:
  •         break;
  • * Manages the slave operation
  • void OnSlave( void )
  •     uint8_t i;
  •     case RF_RX_DONE:
  •             if( strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
  •                 // Indicates on a LED that the received frame is a PING
  •                // Send the reply to the PONG string
  •                 Buffer[0] = 'P';
  •                 Buffer[1] = 'O';
  •                 Buffer[2] = 'N';
  •                 Buffer[3] = 'G';
  •                     Buffer = i - 4;
  •         break;
  •     case RF_TX_DONE:
  •         // Indicates on a LED that we have sent a PONG
  •         break;
  •     default:
  •         break;
  • * Main application entry point.
  • int main( void )
  •     BoardInit( );
  •     Radio = RadioDriverInit( );
  •     Radio->Init( );
  •     while( 1 )
  •         if( EnableMaster == true )
  •             OnMaster( );
  •         else
  •             OnSlave( );
  • #if( PLATFORM == SX12xxEiger ) && ( USE_UART == 1 )
  •         UartProcess( );
  •             uint8_t data = 0;
  •             if( UartGetChar( &data ) == UART_OK )
  •                 UartPutChar( data );
  • #endif
  • #ifdef __GNUC__
  •     return 0;
  • #endif
  • }4 w) f7 K8 i& \" v; g. _3 F3 x
$ U3 T( A/ E6 w7 ?8 T$ X1 y
# J( t. @8 r0 _5 J% V* f3 C3 C( L3 M2 r6 e- _. U/ f( \
发表于 2022-5-31 13:54 | 只看该作者
怎么分析程序呢?这么长的行数。
GMT+8, 2025-9-28 08:17 , Processed in 0.109375 second(s), 23 queries , Gzip On.
