查看: 992|回复: 8
Altium Designer 22.5.1 Build 42 (x64) 迅雷种子
    2023-2-9 15:41
  • 签到天数: 89 天
    [LV.6]常住居民II
    发表于 2022-5-21 08:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    2 M7 I& }, f, I# s% g& @: r" t% J9 P; q- v! q: V3 a. W
    altium Designer 22.5.1 Build 42 (x64)  迅雷种子
    / n7 M. I( \0 i5 t( N' X% j- R8 t$ C7 ^. i: _' @- Q
    magnet:?xt=urn:btih:08E198F50E4A7911463B7AFA2D1F8ADD8C5ECC4A&tr=http%3A%2F%2Fbt3.t-ru.org%2Fann%3Fmagnet&dn=Altium%20Designer%2022.5.1%20Build%2042%20(x64)%20%5B%D0%94%D0%B0%D1%82%D0%B0%20%D0%B2%D1%8B%D0%BF%D1%83%D1%81%D0%BA%D0%B0%3A%202022-05-19%5D%20ISO
    $ D  }  D7 I: k" q7 P0 O2 X! N9 @, o+ q. D: L* i
    Version 22.5.1
    Build: 42 Date: 19 May 2022
    2 ?& P7 m& Y! ^' \- X! I- `
    " D6 Y2 q8 N+ R4 V  N
    Schematic
    49008
    Switching to another application while in-line editing in a schematic text frame could result in the edits being lost and the message "Interactive process not finished" appearing. (BC:17965)
    49420
    The Find Text dialog now includes a Mask Matching option, when enabled everything in the workspace is masked except the found results. The Mask level (Dimming) and Zooming behavior are configured in the Highlight Methods options in the System - Navigation page of the Preferences dialog. (BC:3857)
    49527
    Formulas within text on a schematic were not being resolved correctly when the PC was set to use French regional settings for Windows.
    49822
    The Schematic.EnableCustomDiffPairNaming feature has been moved to Open Beta.
    PCB
    45204
    Stacked THPs and vias generated duplicate drill hits in the Drill Table.
    47196
    The PCB List panel was displaying an incorrect value for the "Remove Islands Less Than" polygon threshold value when the units were set to mils. (BC:16973)
    47379
    In a rigid-flex design, if the flex zone has a Coverlay layer with a layer type of Solder Mask, the actual Solder Mask layer is always displayed in the 2D view even when its visibility is disabled in the View Configuration panel.
    48786
    Double-clicking on stacked PCB objects in 3D view mode with the 'Display Popup Selection dialog' option enabled and the 'Double Click Runs Interactive Properties' option disabled, would sometimes result in the software being locked in 3D view mode and not being able to save the board.
    48994
    The embedded board array object now includes a Board Shape option in the Properties panel; use this to switch the PCB background from green to transparent. (BC:17814)
    49220
    Exported ODB++ data was still incorrectly showing back drilled vias as being plated when using millimeters as the default units. (BC:13553)
    49358
    Millimeters are now the default units when generating output from the PCB such as Gerber, Gerber X2, ODB++ and NC Drill. (BC:15848)
    49425
    When pasting a via over a pad and some polygons, the selection pop-up would appear, even though there was no ambiguity as to which net (that of the pad) the via should 'pick up'.
    49462
    In some cases, self-intersecting regions were created when adding teardrops to a PCB.
    49463
    Self-intersecting regions were being exported to ODB++.
    49499
    When the PCB.IPC4761Support advanced option is enabled, and there is a certain combination of columns enabled in the Drill Table defaults, and the Drill Table defaults are edited to include certain additional columns, those columns could become repeated in the table.
    49520
    A pad with the Counterhole option enabled could result in that pad disconnecting from inner layer polygons when the Counterhole size approached the pad size.
    49559
    The gray-scale color palette used for generating PCB Prints did not offer the correct coloring choices. (BC:18209)
    49574
    On Windows 7 the PCB Heads-Up display was not correctly updating the location coordinates as the cursor was moved. (BC:18149)
    49629
    The feature to 'Prevent modification of PCB Component Primitives' is no longer controlled by an option in the Advanced Settings dialog. Instead, an option for it - Protect Locked Primitives in Component - has been added to the PCB Editor - General page of the Preferences dialog and is disabled by default. (BC:18281)
    49639
    The BoardOutlineClearance rule did not display the edge types for a rigid-flex board.
    49664
    It was not possible to select any components on a particular PCB document due to a regression involving ordinate dimensions that included several points of measurement.
    49735
    Drill layers enabled for plotting in the older Gerber/Gerber X2 setup dialogs (pre-Altium Designer 22.4) would all be disabled when using the new unified Gerber/Gerber X2 setup dialogs (available from Altium Designer 22.4 by enabling the UI.Unification.GerberDialog option in the Advanced Settings dialog).
    49906
    The settings for mechanical layers added to plots in the old Gerber Setup dialog were not retained when those Gerber settings were opened in the new Gerber Setup dialog.
    49922
    There was a mismatch in Gerber extensions vs actual layer ordering when generating Gerber/Gerber X2 output using the new unified Gerber/Gerber X2 dialogs (enabled by the UI.Unification.GerberDialog option in the Advanced Settings dialog) and with the output format set to 'filename.* (gtl, gbl, gto,...)'. (BC:18411)
    Draftsman
    45950
    Draftsman now supports copy/paste of Annotation objects between Draftsman documents or from a template to a document. Note that you can only copy an Annotation object when it is not attached to another Draftsman object, such as a View. (BC:16782)
    48253
    Copying and pasting a table that includes merged cells would result in the merged cells becoming un-merged in the pasted table. (BC:11561)
    Platform
    45944
    VCS analytics and logging has been improved, providing improved error status and logging data.
    Data Management
    49435
    If a Malformed URL GIT error occurred, the error dialog would display the user's password and the Workspace URL. (BC:18032)
    49519
    The Filter feature in the Components panel (and the MPS panel) was incorrectly displaying the temperature value options in degrees Fahrenheit instead of Celcius.
    Import/Export
    46882
    An exception would occur when importing a specific pads PCB file.
    47927
    The allegro importer would sometimes incorrectly create a region object in the same shape and location as a polygon.
    47928
    The Allegro importer was incorrectly creating a polygon cutout over unconnected pads within a polygon, making it impossible to control the polygon clearance using design rules.
    Simulation
    49521
    There was an issue with multi-part components where, for floating nodes, a ? was entered into the simulation netlist instead of a new net.
    49645
    It was not possible to stop a running sweep-type simulation at any stage in the sweep. instead, the simulation would stop only after completing the full number of swept outputs.
    49692
    The peRFormance has been increased when plotting histograms and parametric plots by a factor of 10.
    * H& N5 r' P5 E3 K
    发表于 2022-5-21 10:44 | 只看该作者
    感谢。但是下载没速度。
    郁闷
    2020-11-23 15:19
  • 签到天数: 104 天
    [LV.6]常住居民II
    发表于 2022-5-21 11:05 | 只看该作者
    无聊
    2025-9-10 15:15
  • 签到天数: 1722 天
    [LV.Master]伴坛终老
    发表于 2022-5-21 15:29 | 只看该作者
    感謝樓主無私分享,迅雷比較方便。
    发表于 2022-5-22 18:33 | 只看该作者
    这个和22.4.1比,出Gerber的界面又改回去了,其它就不知道改了哪里,能不能打开项目里的原理图文档时,不要自动出B~O1M1表
    发表于 2022-5-22 20:25 | 只看该作者
    更新速度haokuai
    GMT+8, 2025-9-11 02:07 , Processed in 0.140625 second(s), 23 queries , Gzip On.
