1.担心与skill冲突已卸载skill2.焊盘路径PSM路径已设置
9 X0 E/ i: ^* [5 F$ M+ V( g( C1 F' b& `: v
3错误信息( [- y% `) y$ @2 y# Y/ `
麻烦走过路过的大佬,帮忙看一眼,看哪里设置不对,可以帮忙解决掉这个问题,非常感谢。
) B4 e1 H9 t: [3 f7 ^Loading axlcore.cxt : h6 f3 P W7 Z, r) t9 y
Starting new design...
( }: C ?( a5 Z5 K: c, P* Q5 U2 kReading Footprint XML5 W" ^* ?- M# j: Y1 G
Creating padstacks
" s; C% `0 l3 i6 f: ^) }9 f0 A5 w2 [# c# iStarting new design...8 H# a/ d$ H0 O I
PeRForming DRC..., y/ [7 w: `/ }* x% V) u7 C* ^" C2 ?
Multithreaded DRC update (12 threads).3 U; a1 B; P8 ]# _) Q T" c& t- ?
No DRC errors detected.
. q3 D x4 l+ p9 q6 C- k/ R2 n; UPerforming a partial design check before saving.! E7 |* h& O! Y' h2 P3 Y, }' S
Writing design to disk.
4 U5 }% }- f+ y8 k4 r* y! h+ c'r172_60m192_80.pad' saved to disk. q; S! W4 T, O0 \+ u* N2 }8 O
Opening Design "SOIC127P1031X140-16N.dra"- k% j) P0 ^2 T2 `5 T. u
W- (SPMHUT-48): Scaled value has been rounded off.4 C6 N2 y5 x7 u* \% C
% W0 X2 ?! d% W F$ QCreating Shapes on Package layers
* O a3 o% Z3 ]+ iCreating Pins
6 M$ T9 P# {& c3 }# D! MCreating Vias5 n! C! L& Z* r, F; D) B3 B0 x
Symbol Created$ g1 R- D/ y6 Z6 d$ Z3 M3 X0 `. l
Creating package symbol 'C:/Users/xbf/Desktop/SOIC127P1031X140-16N/SOIC127P1031X140-16N_allegro/soic127p1031x140-16n.psm'.$ {+ T; K- r8 `5 g! D
Starting Create symbol...
L. ^" D6 [. Acreate_sym completed successfully, use Viewlog to review the log file.! x+ C( H& R8 e+ K0 l; u
create_sym completed successfully, use Viewlog to review the log file.. P- v- @- r d" z
Symbol 'C:/Users/xbf/Desktop/SOIC127P1031X140-16N/SOIC127P1031X140-16N_Allegro/soic127p1031x140-16n.psm' created.0 T* w) m+ \) @; q
Loading cmds.cxt
+ \: E L& g z+ e! [" g- iLoading skillExt.cxt R5 _# `4 g) @' r
E- (SPMHA1-161): Cannot open the design because of database problems. Run the dbdoctor command on the design and try to open again.
' b$ U$ d3 R% v" A* k. [* HPerforming a partial design check before saving.6 B8 \+ u1 B8 R; z- V
' `! q5 e+ |$ h6 G2 d; U'SOIC127P1031X140-16N.dra' saved to disk.* O" K( _; h9 e5 s4 A7 r! p5 `; d
Opening existing design..." U* h P" c! d6 y: a0 p& x
Symbol Saved* _ q! y: |7 w A; ?
t# R/ q0 m& H! N+ g- M( D
Command >
: E' t/ [, u9 `" F
. q+ b. d9 u9 S1 x
$ o, ^# {- k5 W+ X
