http://ptm.asu.edu/ 裡面可以幫你產生 pspice 模型
1 I* R' m1 Z4 N4 l7 q! K- c點選藍色的 CMOS 文字,進入 1.Select the type of MOSFET and the technology node,
9 [$ j) Q* p/ N+ U2 T再填入 2. Input your technology specifications7 Y: P' Z( P k8 |* f. ]" A& v0 W
然後 產生3種結果 PTM : Nominal model FF corner SS corner
% k6 Q. e B9 x' a# T( Z' h% S& y" l9 L
範例如下
1 g3 I% ?- S; `* Customized PTM 45nm NMOS
) n$ K$ J- ] z! x
2 ~3 s, E5 L' f! E6 U# j0 Q.model nmos nmos level = 54! N! M* Z) F4 l' W/ ?
" |+ o( L: \; b0 A% E* \
+version = 4.0 binunit = 1 paramchk= 1 mobmod = 08 s0 h0 y5 L* i) N- J2 L
+capmod = 2 igcmod = 1 igbmod = 1 geomod = 1( f1 k7 H" i/ G% m( }
+diomod = 1 rdsmod = 0 rbodymod= 1 rgatemod= 1+ D/ M2 r+ m7 V
+permod = 1 acnqsmod= 0 trnqsmod= 0
- r$ z: B; ]! t: @! q
( i$ t% J" a5 i8 l2 N+ Y* K$ W2 [* parameters related to the technology node. A) B2 u3 ?' {6 t' _4 d3 N5 w
+tnom = 27 epsrox = 3.9
+ z" x" @( a8 L! @) Q/ B+eta0 = 0.0049 nfactor = 2.1 wint = 5e-09" S9 z; D3 k5 a$ t& }* C
+cgso = 1.1e-10 cgdo = 1.1e-10 xl = -2e-086 P6 _- ^+ C/ j3 v \6 @) {
$ E3 U A7 N |, ?' g
* parameters customized by the user
- o1 h* P; `' f; u1 m+toxe = 1.75e-09 toxp = 1.1e-09 toxm = 1.75e-09 toxref = 1.75e-096 A, J! o; y( Z+ }
+dtox = 6.5e-10 lint = 3.75e-09
, _, Y; f5 W7 w% r* _2 x+vth0 = 0.469 k1 = 0.528 u0 = 0.04372 vsat = 147390
' \4 ?6 {& u) Z6 q( R+rdsw = 155 ndep = 3.28e+18 xj = 1.4e-08& ?0 {1 W* Y4 t, V
9 l+ B+ a2 Z* g) R( t* Q
* secondary parameters
0 v- w- B5 c* @8 k( I+ll = 0 wl = 0 lln = 1 wln = 1
# T+ y, N9 } ~/ m! p% R& \7 ^+lw = 0 ww = 0 lwn = 1 wwn = 1 2 K. [" u: U: E; l, z/ G& j+ ?) F
+lwl = 0 wwl = 0 xpart = 0
2 m; t- C, f3 w, s4 O+k2 = 0.01 k3 = 0
) X" `! g+ z* Q- V6 I/ ]+k3b = 0 w0 = 2.5e-006 dvt0 = 1 dvt1 = 2 6 c( X' j9 F+ }. m1 A
+dvt2 = -0.032 dvt0w = 0 dvt1w = 0 dvt2w = 0 % t% |, I) g' Q
+dsub = 0.1 minv = 0.05 voffl = 0 dvtp0 = 1.0e-009
- H. f) g7 L. X% e2 g+dvtp1 = 0.1 lpe0 = 0 lpeb = 0 & O' d% L" g `+ C9 e% g" x
+ngate = 2e+020 nsd = 2e+020 phin = 0
2 x- e" S) O: x- _# u- |( [( Z+cdsc = 0.000 cdscb = 0 cdscd = 0 cit = 0
) f! e! E" I" y7 z* x- m+voff = -0.13 etab = 0
6 C* `! C! ?( C8 h: Z+vfb = -0.55 ua = 6e-010 ub = 1.2e-018 & D" F! X3 W6 ]- x$ e) V; f
+uc = 0 a0 = 1.0 ags = 1e-020
, D- ~+ {) \+ n, I; ~+ a+a1 = 0 a2 = 1.0 b0 = 0 b1 = 0 % M9 ~( q' S- p5 M
+keta = 0.04 dwg = 0 dwb = 0 pclm = 0.04
/ z# ~! a0 [4 T6 p5 r+pdiblc1 = 0.001 pdiblc2 = 0.001 pdiblcb = -0.005 drout = 0.5
0 ^( h p+ E% ~' m6 \ C3 x+pvag = 1e-020 delta = 0.01 pscbe1 = 8.14e+008 pscbe2 = 1e-007 + t; F* c, F% B$ u- ]" G5 a; B/ X c8 X
+fprout = 0.2 pdits = 0.08 pditsd = 0.23 pditsl = 2.3e+006 1 U4 z* ^9 _8 \4 F3 f! u
+rsh = 5 rsw = 85 rdw = 85 0 u* Y' z" J5 |6 B
+rdswmin = 0 rdwmin = 0 rswmin = 0 prwg = 0 7 i( k* Q* T7 `) i0 w
+prwb = 6.8e-011 wr = 1 alpha0 = 0.074 alpha1 = 0.005 ) l* f- n) S2 r, d" x+ R% b
+beta0 = 30 agidl = 0.0002 bgidl = 2.1e+009 cgidl = 0.0002
* n' @: G/ j" J$ S4 y0 t+egidl = 0.8
# h( p3 z. s% R/ k1 m/ F4 n) F1 c9 c, u
7 z4 j' l% ^- u+ J+aigbacc = 0.012 bigbacc = 0.0028 cigbacc = 0.002 # Y! F' E7 V7 I
+nigbacc = 1 aigbinv = 0.014 bigbinv = 0.004 cigbinv = 0.004 ) \1 w2 t+ ~9 x
+eigbinv = 1.1 nigbinv = 3 aigc = 0.012 bigc = 0.0028 * l! N/ J4 c2 Q; A! s9 Z
+cigc = 0.002 aigsd = 0.012 bigsd = 0.0028 cigsd = 0.002
, q' J( F! V" l. e3 j+nigc = 1 poxedge = 1 pigcd = 1 ntox = 1
: F: b. Y6 p+ ?8 N n( L/ E# r( s" v7 Q) y0 F" t3 T: S A
+xrcrg1 = 12 xrcrg2 = 5
5 t; `% u2 f! S) g: h. ~; K- S5 u+cgbo = 2.56e-011 cgdl = 2.653e-10 ( C0 Z `& P4 o( m' c+ K% r
+cgsl = 2.653e-10 ckappas = 0.03 ckappad = 0.03 acde = 1 , a4 o# u/ \) q6 p4 r
+moin = 15 noff = 0.9 voffcv = 0.02 : d. N3 x4 B# l* J a1 r
) \$ o: X' ]8 G* x# c+ @. A
+kt1 = -0.11 kt1l = 0 kt2 = 0.022 ute = -1.5 2 s# W0 K1 r# u4 ~9 |0 j, ]2 i
+ua1 = 4.31e-009 ub1 = 7.61e-018 uc1 = -5.6e-011 prt = 0
( S! e4 ?" h. U7 F( c# R; Y, G+at = 33000
0 z& B f) a ?! z. |
9 D5 u8 f* @2 H* j% r; L, P$ M+fnoimod = 1 tnoimod = 0
3 P% q" m, p+ N2 S' U [# o' k5 H- Z4 u/ W& i7 a- O
+jss = 0.0001 jsws = 1e-011 jswgs = 1e-010 njs = 1 ' q( V. w" B' Z
+ijthsfwd= 0.01 ijthsrev= 0.001 bvs = 10 xjbvs = 1
, W/ H K' N* h) J6 }7 I# t; U. u+jsd = 0.0001 jswd = 1e-011 jswgd = 1e-010 njd = 1 9 l4 }- F# D3 V; M) E. s' j& I; u
+ijthdfwd= 0.01 ijthdrev= 0.001 bvd = 10 xjbvd = 1
/ M" i1 A- V: D6 L+pbs = 1 cjs = 0.0005 mjs = 0.5 pbsws = 1
$ d L# g: x/ J, I6 C: `+cjsws = 5e-010 mjsws = 0.33 pbswgs = 1 cjswgs = 3e-010 1 i$ o2 U5 o# _5 i
+mjswgs = 0.33 pbd = 1 cjd = 0.0005 mjd = 0.5 ! G( \3 i/ b4 K
+pbswd = 1 cjswd = 5e-010 mjswd = 0.33 pbswgd = 1
% g; B* h E/ e- R7 \+ s5 F( e+cjswgd = 5e-010 mjswgd = 0.33 tpb = 0.005 tcj = 0.001
6 E! _* w" r# l0 F4 N# `+tpbsw = 0.005 tcjsw = 0.001 tpbswg = 0.005 tcjswg = 0.001 # z; s4 k' U$ F" _
+xtis = 3 xtid = 3 . `8 P7 H! y: J7 z) B
$ S# c7 ?. \8 r* q: u" r: o
+dmcg = 0e-006 dmci = 0e-006 dmdg = 0e-006 dmcgt = 0e-007
+ ~0 b/ ]' f2 W0 H- [+dwj = 0.0e-008 xgw = 0e-007 xgl = 0e-008 , d, `% G n* u* Q& Y
$ A, R' J! e2 l2 V7 M$ ^1 { F0 `
+rshg = 0.4 gbmin = 1e-010 rbpb = 5 rbpd = 15
% @: W" E7 V! [" I% `+rbps = 15 rbdb = 15 rbsb = 15 ngcon = 1
+ ?, N/ }$ w" e( u! a- A; U |
