查看: 538|回复: 0
求助Orcad port intersheet references页码无法显示
    奋斗
    2023-7-27 15:01
  • 签到天数: 47 天
    [LV.5]常住居民I
    发表于 2022-5-7 23:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    , S: N0 r% C% J" d
    * ]+ V  e! {- R/ B8 ^各位大神好, 小弟第一次发文询问, 如果有什么错误冒犯的地方还请多见谅
    ; ?  K$ ^/ `' f' u7 G7 p. M小弟我目前遇到一个问题是/ F9 D" |( W- [
    使用 orcad add intersheet references 无法正常显示页码
    ' T! X/ b) W% k' T) y. O3 K2 m# l6 ~: o% k9 E" ^9 T+ E
    如下图7 b8 c2 g6 x, W5 w
      D$ R  O: [/ M9 [! h
    7 I" V0 n  m, q
    * z( i3 I6 F) U7 ?0 i
    2 V# Z- _  K( d
    0 R( H5 a8 D6 A+ N9 S我这支port "S0_PD_LP5X_VDD_SENSE_FIXED"/ S; y5 G, a# T9 b2 i
    有连接到 另一页 S0_PD_LP5X_VDD_SENSE_FIXED. \; H& q" d2 S
    如下图
    - p  ~3 \5 ~$ m, }- _* _+ b4 k8 T3 ^/ _0 ]# ^( v% s
    " p) V5 M. l$ c8 Q2 z但是不管怎么设定怎么刷 都没办法让  我这页(S0-16)Socket Pin 的port尾端显示出跳接的页码3 h+ P: k5 N# I
    但是它是有连上的( M8 {$ ], o; O6 p
    Title blocks 的 page number也有确定是正确& r" \% W( ?# y2 W
    5 o7 H2 ~# l8 q# ?; J: h$ ]# \6 j8 r7 E/ a
    跑完 add intersheet references 出现的Log如下
    " K, n0 q/ U& C" f6 h
    8 L  W& W& H* M5 }7 ywhy!!!!!  救命:'(:'(! v, `+ B, m% L) R9 O  p' F* ^" @4 q  W
    我的問題原文
    " D4 a3 c: x+ L" `* [- ]I have an inteRFace of 32 signals, each having its own off-page connector. They all go to another page to connect to another chip. The problem is, that one of the 32 signals offpage connector does not want to pick up an intersheet reference number (page number), and in the annotate it gives a warning: Hierarchical Port  'S0_PD_LP5X_VDD_SENSE_FIXED' on Page (S0-16)Socket Pin has no Intersheet References.+ K5 g4 t; B: p, N
    $ z: |- W" ]' XThis only happens at one end, but not the other end. The signal names are identical at both end. There is enough space around the offpage conn to place the number. Still Orcad refuses to add the offpage number.
    3 w" f, I( ^9 r9 W; e: d
    7 e9 T* Z  I- l
    $ W; {! m" G# v5 O5 p  `# X
    GMT+8, 2025-9-11 09:23 , Processed in 0.531250 second(s), 27 queries , Gzip On.
