查看: 951|回复: 11
AD22.3.1下载地址 AD 22.3.1 下载地址 :链接:https://pan.baidu.com/s/1sNXl9Z03...
发表于 2022-3-17 14:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AD 22.3.1 下载地址 :链接:https://pan.baidu.com/s/1sNXl9Z03TBKTSTf0KC5-Zg?pwd=1234
+ s# `5 Y+ e5 H提取码:1234 " N% E& T1 u& T( S0 @
' s3 P3 S/ N  z3 o7 |! W3 F9 P' O
1 Q$ B) S" L  w3 W
    2025-8-15 15:54
  • 签到天数: 1024 天
    [LV.10]以坛为家III
    推荐
    发表于 2022-3-17 14:56 | 只看该作者
    谢谢分享!更新得很快啊!
    无聊
    2025-8-19 15:21
  • 签到天数: 1700 天
    [LV.Master]伴坛终老
    发表于 2022-3-18 07:51 | 只看该作者
    感謝樓主無私分享。, n' J" S( F# d% j; Z
    22.3.1,不知道改善了那一部份?
    2023-2-9 15:41
  • 签到天数: 89 天
    [LV.6]常住居民II
    发表于 2022-3-18 08:54 | 只看该作者
    Version 22.3.17 S" |( H& ?4 ?; L% r5 s. V' D. w
    Build: 43 Date: 16 March 2022
    9 N% [' B3 y( L& `7 d- n0 ^3 c: e6 p' v3 A
    Schematic
    ( |  f7 O' @  I% e+ o* K47692        When attempting to change multiple selected components via the Properties panel, if a different library is selected as the Source, the Component Source dialog appears. When the Select button is clicked the Replace dialog opens to choose the replacement, but instead of updating all currently selected components the Replace dialog would reappear for each of the selected components. (BC:11607): J1 ~) a, J8 @* v6 S- N0 P
    47757        Updates (such as footprint and parameter changes) to components that were used as an alternate part in a Variant, were not propagating through to the design when an Update Schematics or Update Parameters command was run. (BC:7574)6 N% k& `3 @) c" Q6 [' w
    48492        Improved the performance of dragging components on a schematic sheet that has a large number of components and wires.$ U4 X& S, j4 e
    48801        A new "Display Name of Special String" option added to the Schematic - Graphical Editing page of the Preferences dialog. When enabled, each special string has its name displayed as a faint superscript.
    6 [) A1 ?6 Z( i4 c49034        Net name negation using the trailing backslash character was not working for Power Ports. (BC:4186)
    # G: U2 C% l* [! s! z$ f5 GPCB% {/ c6 g) v) T3 N7 I
    46628        An access violation would sometimes occur during differential pair routing if the PCB file was stored in a OneDrive folder.* E3 \$ G' P6 {% }+ A* g
    47327        The Heads Up Display would remain visible on top of all other applications after switching from Altium Designer to a different Windows application. (BC:9923)$ B- ^7 l, F" X6 ~
    47714        While attempting to place a linked 3D STEP model via the Place > Extruded 3D Body command, the model would automatically switch to the Embedded mode. (BC:13236). This ticket also corrected an issue where, if changes were made to a STEP model that was linked to a PCB, when that PCB was reopened and the linked model automatically updated, the model location and orientation were not correctly maintained, resulting in the linked model moving. (BC:7034)2 c! I8 C0 }' ^/ ?& y
    47981        Performing a 3D measurement between a 3D object and the board surface or board edge, reported a distance of zero.
    - o7 R( V8 _( I* G48177        The Footprint Comparison Report would give a false failure on a component if: the component had been rotated, and the component included an extruded 3D Body object with an arc in its outline.: V/ A* Y! Y3 r+ }
    48189        Assembly Testpoint Style Component Body Clearance violations were not always being detected during online DRC, and were not reported after a batch DRC. (BC:14687)
    # T8 A5 R7 M+ t5 C8 A* |48548        Differential pair reported signal length was not the same in the PCB panel and the tuning gauge during interactive length tuning, when the pair included vias., \. t" u8 |: ~: e$ C
    48572        Improved usability for Top-Middle-Bottom and Full Stack editing in the Via mode of the Properties panel.
    3 ?( @" P; a( Q3 k' C4 n' C48840        Connected traces were unrouted when reroute failed after a component move.% y8 Q3 O/ T6 O" v3 z, J
    49001        A trace would disappear when dragging a corner.* F: n- r" [$ Z* ^
    49149        Changing a via type (e.g. thru to blind, or blind to thru) could result in a broken net or a short circuit, which was not being detected as a design rule violation.' @7 O8 Z# I, N4 l2 @( B  p
    49196        For a specific design project an Access Violation would result when the Retrace Selected command was run on a partially selected accordion.$ ~' A7 V6 h& S) P% Z
    Platform
    7 u; l$ E6 Y9 T* r! K9 E+ f7 B48876        On-site Workspaces (Concord Pro and NEXUS Server) did not display the Project History correctly./ C" T$ w$ |% ?8 d9 k* F: L
    48907        Switching between Workspaces or signing out of a Workspace would result in the software disconnecting from the Private License Server./ O8 }: K7 q8 i9 }
    Data Management
    ( _6 q, R/ C, Y# Q2 [! o# t48389        To reduce potential for confusion when using the Soft Locks feature, if a user has made changes to a document more than two days ago, a second user opening the same document will not see that the first user is 'editing' the document, but rather a clearer state of ' made changes locally on ' . In addition, the icon used in the Projects panel will change to gray, indicating that this is a change made more than two days ago and not an active editing session by that first user.# ^& u' k6 g# X0 W/ B& K2 x
    48778        User ranking of an existing Part Choice was not being saved.
    ( B3 z" X4 N% a8 a% Q* \) |48814        It was not possible to navigate through the different project Comment dialog options (such as the list of suggested email recipients), using the keyboard.9 P( k6 `: }: ^' @( E3 z% k5 {
    48836        A project that has a broken ProjectGUID did not result in the "Fix Version control link" dialog opening, as it should have.
    ; e) m$ k- C7 |! f+ y  D3 P48892        When there was a remote VCS repository connected to a local repository (which does not require authorization), the software would still prompt for authorization credentials when a VCS action was performed. (BC:17786)
    # z, o9 f$ l8 T0 \  h6 N48966        If a component included a ranked Part Choice, attempting to remove another Part Choice would remove that one and the Part Choice below it.
    $ T1 w; N2 A9 m5 p0 i* G7 tSimulation
    ; ]& i8 s: M& l3 m& s1 w" b
    2025-8-19 15:54
  • 签到天数: 1571 天
    [LV.Master]伴坛终老
    发表于 2022-3-19 11:17 | 只看该作者
    谢谢分享!更新得很快啊!
    奋斗
    2022-5-24 15:44
  • 签到天数: 68 天
    [LV.6]常住居民II
    发表于 2022-3-21 13:20 | 只看该作者
    感謝大大,好人一生平安
    发表于 2022-3-22 08:17 | 只看该作者
    为什么提取码不正确
    发表于 2022-3-22 15:54 | 只看该作者
    正准备安装,赶上新版本了
    发表于 2022-3-22 16:39 | 只看该作者
    谢谢分享!更新得很快啊!
    GMT+8, 2025-8-19 17:45 , Processed in 0.125000 second(s), 24 queries , Gzip On.
