SYM_NAME | COMP_DEVICE_TYPE | REFDES |
AUDIO6-1180P-6AN | PJ-3607_AUDIO6-1180P-6AN_PJ-360 | J9 |
C0402 | C_C0402_1NF_50V | C1;C2;C41;C45;C61;C62 |
C0402 | C_C0402_100PF_50V | C15;C25;C107;C126 |
C0402 | C_C0402_100NF_16V | C20;C42;C44;C106;C109;C112;C113;C115;C116;C119;C121;C124;C125 |
C0402 | C_C0402_22PF_50V_T:CC1206N;B:CC | C22 |
C0402 | C_C0402_270PF_50V | C28;C128 |
C0402 | CAP NP_C0402_10PF | C46;C58 |
C0402 | CAP NP_C0402_0.1UF | C47;C50;C51;C52;C56;C59;C60;C64;C69;C70;C71;C73;C74;C76;C77;C78;C79;C80;C81 |
C0402 | CAP NP_C0402_1UF | C49;C72;C75 |
C0402 | CAP NP_C0402_18PF | C53;C54 |
C0402 | CAP NP_C0402_10PF/NC | C65;C66;C83;C84 |
C0402 | CAP_C0402_DISCRETE_8.2PF_06-208 | C67;C82 |
C0402 | C_C0402_10NF_25V | C105;C110;C114;C123 |
C0402 | CAP NP_C0402_C0805 | C132 |
C0402 | CAP NP_C0402_20PF | C133 |
C0603 | C_C0603_4.7UF_6.3V | C9;C10 |
C0603 | 100NF_C0603_56P | C11 |
C0603 | 1UF_C0603_4.7UF | C13;C129 |
C0603 | C_C0603_10UF_6.3V | C14 |
C0603 | 1UF_C0603_1UF | C16 |
C0603 | C_C0603_2.2UF_6.3V_ | C17 |
C0603 | C_C0603_1UF_16V | C18 |
C0603 | 100NF_C0603_820P | C19 |
C0603 | C_C0603_10UF_6.3V_ | C21;C108;C111;C117;C118;C120;C122 |
C0603 | CAP1_C0603_1UF | C23 |
C0603 | C_C0603_2.2UF_6.3V | C24;C26 |
C0603 | CAP_1UF_0805_16V_10%_X7R_C0603_ | C27 |
C0603 | CAP_1UF_0805_16V_10%_X7R_C060_1 | C31 |
C0603 | C_C0603_100NF | C34;C38;C85;C87;C88;C89;C90;C91;C93;C94;C95;C96;C97 |
C0603 | C_C0603_20PF | C39;C40 |
C0603 | C_C0603_1NF | C43 |
C0603 | CAP NP_C0603_4.7UF | C48;C55;C57;C63;C68 |
C0603 | CAP NP_C0603_100NF | C100;C101;C102;C103;C104 |
C0603 | 100NF_C0603_1000P | C127 |
C0603 | 100NF_C0603_474 | C130 |
C0805 | C_C0805_10UF | C37;C86;C92;C98;C99 |
C1206 | CAP NP_C1206_100UF | C3 |
C1206 | CAP NP_C1206_1UF | C4;C5 |
C1206 | C_C1206_22UF | C35 |
C1206 | CAP NP_C1206_10UF | C36 |
C1206 | CAP NP_C1206_20UF | C131 |
C1210 | CAP_1UF_0805_16V_10%_X7R_C1210_ | C6;C8;C12;C32;C33 |
C1210 | CAP_1UF_0805_16V_10%_X7R_C121_1 | C7;C29 |
CONN-WIFI_WM-BAN-BM-10_L | WM-BAN-BM-10_6_CONN-WIFI_WM-BAN | U7 |
D0402 | ESD_D0402_ES0402V014BT | ZD1;ZD2;ZD3;ZD4;ZD5;ZD6;ZD7 |
DC-300A | CAP NP_DC-300A_1NF | C30 |
DFN8-2510P10E | MC4_1_DFN8-2510P10E_MLSEP08A-25 | D2 |
F1206 | FUSEHOLDER_F1206_TR/3216FF5-R | F1 |
FB0603 | FB_FB0603_600OHM@100MHZ | FB1;FB3;FB5 |
FB0805 | FB_FB0805_330OHM@100MHZ | FB2;FB4 |
FB0805 | FB_FB0805_LFBK2125HS101_T | LB1;LB2;LB3;LB4 |
FPC2-80MIL-65MIL | 2_FAN CONN_FPC2-80MIL-65MIL_2_F | J1;J6 |
GPS4-CONN | CON RF I-PEX MHF-20279_0_GPS4-C | J7;J8 |
L4-80X50MIL | OW3216_900_L4-80X50MIL_90R-100M | L6;L7;L8 |
L4-2020 | TRNSFMR TY-400P_0_L4-2020_DLW5B | L1 |
L0603 | CHOKE_L0603_BLM18PG121SH1D | L9 |
L0805 | CHOKE_L0805_BLM18PG121SH1D | L2 |
L2520 | IND_L2520_2.2UH | L10 |
PL-0705 | IND_BEAD_0603_PL-0705_2.2UH | L5 |
PL-1010MM | IND_BEAD_0603_PL-1010MM_1R | L3 |
PL-1010MM | IND_BEAD_0603_PL-1010MM_2R2 | L4 |
PW3-PJ1-021-SMD | PJ1-021-SMT_PW3-PJ1-021-SMD_PJ1 | J2 |
QFN10-050-0303 | 8+1_TPS2556_2_QFN10-050-0303_TP | U5 |
QFN10-050-0303A | TPS40192_7_QFN10-050-0303A_TPS4 | U1 |
QFN36-050-0606LH | USB2514B-AEZG_6_QFN36-050-0606L | U6 |
QFN48-050-0707H | 48+1_ALC269Q-VB6-GR_0_QFN48-050 | U2 |
QFN64-050-0909H | RTL8211EG_QFN64-050-0909H_RTL82 | U4 |
R0402 | R_R0402_0 | R3;R4;R85;R91;R102 |
R0402 | R_R0402_20K_1% | R6 |
R0402 | R_R0402_DISCRETE_20K | R7 |
R0402 | R_R0402_4.7K | R8;R80;R81;R82;R83;R87;R88;R89;R90 |
R0402 | R_R0402_22K_1% | R9;R98 |
R0402 | R_R0402_33 | R13 |
R0402 | R_R0402_75 | R14;R15 |
R0402 | R_R0402_1K | R16;R20;R104 |
R0402 | RESISTOR_R0402_10K | R21;R22;R23;R27;R29;R32;R40;R72;R75;R76 |
R0402 | RESISTOR_R0402_2.2R_1% | R24 |
R0402 | R_R0402_10K | R53 |
R0402 | RESISTOR_R0402_12K | R64 |
R0402 | RESISTOR_R0402_100K | R65;R69;R73;R74;R77;R84 |
R0402 | RESISTOR_R0402_OE | R71 |
R0402 | R_R0402_100K | R86 |
R0402 | R_R0402_24.9K_1% | R92 |
R0402 | R_R0402_2.2K | R99 |
R0402 | R_R0402_1K_1% | R101 |
R0402 | MLVS0603M04_R0402_MLSEP12A-0402 | VR1;VR2 |
R0603 | R_R0603_39.2K_1% | R5 |
R0603 | RESISTOR_R0603_2.15K F | R10 |
R0603 | RESISTOR_R0603_10K F | R11 |
R0603 | RESISTOR_R0603_576R | R12 |
R0603 | R_1_R0603_2K F | R17 |
R0603 | R_1_R0603_6.2K F | R18 |
R0603 | R_1_R0603_4K7 | R19 |
R0603 | R_R0603_510 | R25;R26 |
R0603 | R_R0603_4.7K | R28;R48;R52 |
R0603 | R_R0603_0 | R30;R39;R50;R51;R54;R56;R57;R58;R59;R60;R62;R100 |
R0603 | R_R0603_22 | R31;R35;R37;R41;R44 |
R0603 | R_R0603_0_J | R33;R36;R38;R42;R46;R49 |
R0603 | R_R0603_1MEG | R34 |
R0603 | R_R0603_4.7K/NC | R43;R45 |
R0603 | R_R0603_33 | R47;R61 |
R0603 | R_R0603_1K | R55 |
R0603 | R_R0603_0.01 | R63;R67;R68 |
R0603 | RESISTOR_R0603_1M | R66 |
R0603 | RESISTOR_R0603_10K | R70;R106 |
R0603 | R_R0603_2.49K | R93 |
R0603 | R_R0603_75 | R94;R95;R96;R97 |
R0603 | RESISTOR_R0603_8.87K F | R103 |
R0603 | RESISTOR_R0603_3.9K | R105 |
R0603 | RESISTOR_R0603_33R | R107 |
R0805 | R_R0805_0 | R1;R2;R78;R79 |
RJ8-SRLFY | E5J88_14L824_L_RJ8-SRLFY_E5J88_ | J3 |
SD11-ECSM_211_DZ_J | SD CARD_5_SD11-ECSM_211_DZ_J_EC | J4 |
SMA | BAS70/SOT_1_SMA_NP | D3 |
SMB | ZHCS750/SOT_0_SMB_1SMB24AT3G4 | D1 |
SOD-0402 | DZ-1_SOD-0402_USB0005DP | DZ1;DZ2;DZ3;DZ4 |
SOP8-50-157H | MP8666_0_SOP8-50-157H_MP8666 | U3 |
SOT23-3 | 3_2N7002+215_SOT23-3_2N7002+215 | Q3 |
SOT-DPAK | IRLR3717_SOT-DPAK_AOD456 | Q1;Q2;Q4 |
TC3528 | C_P_TC3528_220UF_6.3V | CP1 |
TFM24-50-480 | S558_5999_T3_TFM24-50-480_S558_ | T1 |
USB9-USB3-AF-RVS | USB_9+4_D_0_USB9-USB3-AF-RVS_8- | J5 |
X2-49-SMD | CRYSTAL_1_X2-49-SMD_24MHZ | X1 |
X4-0302 | XL/SM_3_X4-0302_24MHZ | Y1 |
