查看: 208|回复: 0
5V多节锂电(2~4节)同步升压管理芯片ZCC6983
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2022-3-2 17:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    特性
    1 E1 L+ c- L$ x4 v■ 3.0V to 5.5V Operating Input Voltage
    * e+ z% ]8 u: [9 I2 Q■ Up to 26V Sustainable Voltage
    - R$ a. Z$ S4 G1 K' x■ Up to 2A Configurable Charge Current for Battery
    ! Q9 p0 k% d  Dwith 2~4 Cells in Series6 }# G" k3 x$ d* h
    ■ Configurable Input Voltage Limit* L4 k8 ]# o% R4 o, L5 H5 S
    ■ Charge Status Indication: a) z4 v4 f# P( x. I
    ■ Constant Voltage Selectable
      m* G, K5 s. p5 ~6 ~■ Programmable Charge Timeout4 F2 W" y# P7 Z5 Q& Y
    ■ Thermal Regulation Protection
    8 o$ r* D( D! ~+ C/ k■ External Shutdown Function
    # [' Y% V3 j% j9 S# h■ Input Voltage UVLO and OVP' ?; N8 J: J3 a2 V
    ■ Over Temperature Protection# r0 y% ~! `9 g. ~* r# S
    ■ Output Short Cir cuit Protec tion Normal1 H5 M* X& z% L8 m
    Synchronous Boost Operation When Battery' Y8 k- A; I+ o/ x
    Removed
    ' [" g* P  ]7 u/ l应用: Z8 S5 z4 B3 O0 b3 O' ]3 f" a
    ■ Power Bank
    * W" V8 v: t4 H, E7 _8 K# r- V% G■ Cellular Telephones,MP3Players,MP4 Players
    1 _6 T% N+ i3 Z( K4 H  S■ PSP Game Players,NDS game Players0 u7 j& p* h! ^. h8 W  H
    ■ Notebook
    - [* H, r) X) B3 A+ U2 |描述* ~' G9 g; {, ~: O: x, R
    ZCC6983 is a highly integrated synchronous boost
    ; l/ N3 i& H* n1 \7 fcharger IC for Lithium-ion batteries with four cells in
    4 ?$ P7 L6 b0 I" G) c( Zseries . The charge current up to 2A can be
    0 R, ~7 x* P$ Q( }programmed by using the external resistor for different, g; ]) a9 [, Q2 R
    portable applications.& x  ?1 ?& Q$ _; ]2 c& o
    Robust protections include input over-voltage' D0 n( U2 z. ^- h3 L
    protection (OVP), battery OVP, battery short protection,
    8 F8 [" x+ w$ h5 Lthermal shut down, battery temperature monitor, a
    , E( K# ?* M% i+ q. Qconfigurable timer to prevent prolonged charging of a$ w# d9 [4 t  e, _9 a+ f( p2 ]6 L
    dead battery.2 \  j- Z# F. W
    GMT+8, 2025-7-5 08:03 , Processed in 0.125000 second(s), 24 queries , Gzip On.
