这是做annotate的报错:
( {4 f2 w1 P" {/ V- w0 q, _9 C. d N) {
5 M+ a5 O: s( L/ M9 y5 F0 ^ @
- H* k% I- l3 b* b- [9 c* c9 {
5 z8 `' X( ^$ b# J r* ^*0 A0 I# I8 A, F
* Performing annotation.. {( n- i1 a, c) G- [5 @
: `1 h- t/ N) d v********************************************************************************2 V; h) P# L5 V3 l
Done updating part references
( I( t$ Q8 ^6 B* b% |0 D' i/ s
" o+ T- M3 q5 x" D. L
0 J( ~) ]$ M4 s P* l6 ]* u********************************************************************************
0 w, u6 ~* ^9 B7 B; a*, l& q I7 V$ @* B
* Performing annotation.9 @ K* |" X/ P# I( L" v3 a
*' t; F9 F/ g. f
********************************************************************************- J$ Q8 z; V/ x7 A2 K
[ANN0009] WARNING:5 w: W; `& i! q$ s! |
Component R2A has different common pin connection for two instances and hence packaged separately.
( z3 w- {# K5 x: }/ h[ANN0009] WARNING:. q% B5 N6 o, s4 s! [0 i6 M- a
Component R3A has different common pin connection for two instances and hence packaged separately.
{5 x8 L/ ?+ N: o[ANN0009] WARNING:8 b& a: ^8 z' r: M4 F; y
Component R4A has different common pin connection for two instances and hence packaged separately.( f3 C8 y/ S6 ?; L
[ANN0009] WARNING:
+ w5 g/ }$ M, ?2 f, `Component R6A has different common pin connection for two instances and hence packaged separately.7 H% Y. e* k( v" Q
[ANN0009] WARNING:( r, g2 [7 n9 ?5 E' H
Component R7A has different common pin connection for two instances and hence packaged separately., G1 @( A6 E9 a& v8 m
[ANN0009] WARNING:3 ~2 [/ N- P& Z+ l; Q
Component R8A has different common pin connection for two instances and hence packaged separately.
* A8 O3 n" i5 ~+ j/ B3 q" t, P[ANN0009] WARNING:* f& X! [+ c* ?# m5 k, i+ _* z5 h$ ^
Component R9A has different common pin connection for two instances and hence packaged separately.; R& @2 p; Q5 W; j# ?
[ANN0009] WARNING:4 t# a# E- b6 U+ ^/ E! y
Component R10A has different common pin connection for two instances and hence packaged separately.
, v$ P1 {/ E1 a" w[ANN0009] WARNING:% d9 D6 z$ d h# L2 W6 E/ e
Component R11A has different common pin connection for two instances and hence packaged separately.
7 o* w- O( X# X, @7 s" l2 s[ANN0009] WARNING:* I1 J+ j4 ]; _3 ?! j9 k* E
Component R12A has different common pin connection for two instances and hence packaged separately.% n" g' x# ]1 h; M/ ?! e3 R
[ANN0009] WARNING:& @" x' x5 a" x; O
Component R14A has different common pin connection for two instances and hence packaged separately.
2 q0 z7 Z: [6 V; v# y[ANN0009] WARNING:
# W, t) o( ?7 Y fComponent R15A has different common pin connection for two instances and hence packaged separately.) J9 s+ ?# o9 {
[ANN0009] WARNING:; I2 l+ ?5 l" h; o; T
Component R16A has different common pin connection for two instances and hence packaged separately.
$ r$ r6 n' b6 L; N[ANN0009] WARNING:
) l4 ~1 } r5 `Component R17A has different common pin connection for two instances and hence packaged separately., w7 |) o* x1 A* c1 V& Y* t$ c
[ANN0009] WARNING:
7 D: f+ F& A# {2 N$ C; t* u8 v# FComponent R18A has different common pin connection for two instances and hence packaged separately.
6 ?7 ]$ e: z. u( W( g) p4 m[ANN0009] WARNING:& K( X9 V# g/ p
Component R19A has different common pin connection for two instances and hence packaged separately.
9 M' i5 d& X! C( r5 [1 k5 c$ s[ANN0009] WARNING:2 w' |5 p4 I+ g: @/ ^; i5 n
Component R20A has different common pin connection for two instances and hence packaged separately.2 a U2 J+ w! `/ i
[ANN0009] WARNING:
& k' a1 k- f3 hComponent R21A has different common pin connection for two instances and hence packaged separately.. q- l& }2 e* m6 m* J. ^
[ANN0009] WARNING:
' F9 P7 j6 ^9 e- A M! `, jComponent R22A has different common pin connection for two instances and hence packaged separately.
* q( _( L* s. I. ~& T$ ^[ANN0009] WARNING:
- P H; z: p" S4 Y. PComponent R23A has different common pin connection for two instances and hence packaged separately.' E- d" ^, d$ f8 D& x/ e
[ANN0009] WARNING:* m7 @- x- B7 Q6 e( @
Component R24A has different common pin connection for two instances and hence packaged separately.* |$ Z1 n+ M& e( a' ]) x
[ANN0009] WARNING:+ k! t, s' Y9 b0 O
Component R25A has different common pin connection for two instances and hence packaged separately.5 p' x7 |: B" I0 m8 j2 a c# I
ERROR [ANN0005]
/ b* K% r$ y2 n5 r
9 Y$ D' C9 b8 h & M7 u, F& r. T& \( A
Cannot perform annotation of heterogeneous part 'C?A(Value 100NF) at location (21.10, 6.85) on page SHEET_10', part has not been uniquely grouped (using a common User Property with differing Values) or the device designation has not been chosen6 s f4 ?+ q; a! v) T
Done updating part references2 C! B F( m$ ^. s
