超級狗 发表于 2022-01-07 10:45:50# T1 c/ W- h( V0 b0 f
本帖最后由 超級狗 于 2022-1-8 23:12 编辑 , `, E9 S: p7 |3 o, r" B
$ {* Y- A) G* |9 SUse a Schottky diode
4 q- }0 E/ p/ `7 Q* t$ D3 |Use a Schottky diode as shown in Figure 3, using a Schottky diode from OUT to IN will keep the body diode in the LDO from conducting when the output voltage exceeds the input voltage. You must use Schottky diodes because of their low forward voltage; traditional diodes have a much higher forward voltage than Schottky diodes. During normal operation, the Schottky diode is reverse biased and will not conduct any current. Another advantage of this approach is that the LDO’s dropout voltage will not increase when placing a Schottky diode between the output and the input.
x, h+ l' J* \3 X& d$ k0 ?* s3 N, O( V! w# j& ^
 + t1 D. X Z2 H0 z4 A# U- M: F
+ @ Q" x7 q' n2 K老板,咋哪都有你。
c& {6 e) f+ O+ `' k! }# }6 d |
“来自电巢APP”
