查看: 164|回复: 0
ZCC2139替代ME2139
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-12-30 17:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Description
    4 _( `" _: L, r* X; ^7 aThe Z CC2139 series is a CMOS step-up
    3 X% z% W7 m4 kswitching regulator which mainly consists of a
    + f" \& `1 p0 C4 r: hreference voltage source, an oscillation circuit, / ?. q  b8 W8 e  k% l  V% n" V% b
    an error amplifier, a phase compensation circuit, 2 O$ o% a" o$ t7 F" `, j
    a PWM/PFM switching control circuit. With an
    % ?0 r* C2 F( S' M" r# Kexternal low-ON-resistance Nch Power MOS,
    4 A' S- Y5 H8 n3 |; f& A0 t( Hthis product is applicable to applications 0 _/ O' c9 _$ d. A- Z
    requiring high efficiency and high output current. : G% S+ `0 O9 z& g
    The Z CC 2139 series switches its operation to the ! q0 z7 T7 T- _- f1 l$ J+ W! r
    PFM control circuit whose duty ratio is 15 % with
    ! @+ o$ L' ?0 d5 P8 r# S. U0 ]4 pto the PWM/PFM switching control circuit under ( y- `* Z0 N) D$ v4 p3 L
    a light load and to prevent decline in the ( z0 p4 s/ w# u3 t8 |$ q: _( n" K
    efficiency by IC operation current.
    , r1 j: i  N3 aFeature
    4 o: f6 s/ I3 S3 u& r# F2 @ Low voltage operation: Start-up is guaranteed
    2 b  ~$ F; `* N: {  T5 tfrom 0.9 V(IOUT =1 mA ); N" F9 U2 F6 ~, {
     Duty ratio: Built-in PWM/PFM switching control
    3 N$ q6 i; G7 h1 a/ r) Q$ T' Vcircuit 15 to 78 % .
    6 J$ B. y& I; [. \; v2 k, L: v) j oscillator frequency:1.0MHz
    9 L& k. m) Q5 ^ External parts: coil, diode, capacitor, and
      I0 k' E& |! ]' b; I! Dtransistor
    ( T# d( b" D3 o5 m2 ~# \4 a Output voltage range: 1.5V ~6.5 V
    7 a0 `# V. ]8 N Output voltage accuracy:±2%
    ( K/ q# q2 n$ r  _6 y3 F Soft start function: 2 mS.
    * G" i* u6 K/ W: V PACKAGE:SOT23-5
    0 D5 M: e* }0 z) ^& I* n
      }$ z& p. u5 c
    6 N( n5 p/ h( W/ L" E
    GMT+8, 2025-8-24 17:25 , Processed in 0.125000 second(s), 24 queries , Gzip On.
