查看: 148|回复: 0
ZCC541AKP替代SY5864
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-12-30 17:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
     Description% Y* x( N, F7 K# `& I
    The ZCC541A/B series is a high input voltage
    7 m5 A6 p4 Y( Z' v& N8 r) }/ I, f6 c5 O(40V), low-dropout linear regulator (LDO) able to
    , }' q8 i3 V" {. w/ I# b  vprovide 1A load current. The ZCC541A/B family
    % s+ H: R6 u3 SLDO offers EN pin to enable and disable the LDO
    2 |% f! Q) y2 ]/ w, [+ S0 D  Xoutput, EN pin can take 40V input voltage.; y; N7 ], @6 s( L5 g' [
    The LDO features very fast response against line* W  B! p2 D' A/ z5 V/ K
    voltage transient and load current transient, and
    9 d* \1 `. K# Xensures no overshoot voltage during the LDO start+ [+ ]8 N3 e. k9 _
    up and short circuit recovery  I+ |9 A- s/ P
    The device features integrated short-circuit and
    9 S! x" Z6 t" B5 t3 v9 j; l8 M, Cthermal shutdown protection.
    / s' \7 R' G, |  |! l4 X7 R  ]) gFixed voltages of 5.0V , 3.3V , 3.0V and 1.8V1 H; w& F+ d  }; }3 T( G7 D
    are available on ZCC541BKP with adjustable
    7 [- V1 X& r6 [3 O% a1 {output voltages to 0.6V on ZCC541AKP.% c7 u, O) \& b6 G
     Features
    ) ^( z) t! Z3 r' @; h" K Fixed and adjustable output voltages to 0.6V' X. n+ k/ ]. Z4 h
     High Input Voltage Rating:Up to 40V
    ' h7 Z6 h5 u0 I  q High Output Current:1A# P" n5 b2 ?( }7 D
     High PSRR:65dB at 1kHZ
    ! M! Z8 j- \# v  m- y Low Dropout Voltage:1.5V@1A
      r9 c0 V4 \$ F Fixed Output Voltages:  s2 F* O4 `" D; B
    1.8V, 3.0V, 3.3V,5.0V and ADJ
    ( u: ~4 x' ^5 Q+ |" l High-accuracy Output Voltage: ±2%
    # k/ q0 j# i! }0 j Fast Transient Response: m2 B0 R! V( l, T  ]
     Integrated Short-Circuit Protection
    ; l' Z2 w5 d( c: _ Enable pin is available
      k' {( d1 \  @$ p Integrated Thermal Protection+ ~! d0 W* t( r, @3 u" r, E  ~" {
     Available Packages:ESOP8
    3 j8 p4 Z2 J5 z$ L; p' B
    ) V3 p) {- a1 E2 h: m* E1 K; ^
    6 d! b- I8 f$ r, ~' x5 T
    GMT+8, 2025-8-24 17:33 , Processed in 0.109375 second(s), 24 queries , Gzip On.
