我有orcad图纸,page13单独编译,可以单独导出netlist;其他page合在一起 ,可以导出netlist. 当合并在一起,就报错如下: 7 c9 q6 k q5 I" i& R
, S- x# T7 X5 z5 F7 B+ j5 LError at line 4663 while loading the E:\00_HARDWARE\15_1IN1OUT\V300\allegro\pstxnet.dat file. Unable to create the following new pin instance, 1, as the pin definition was not found. $ h$ f: s# _% r( q ]% u/ X Reference Designator: C453. 2 U* ]) v1 c/ ^8 d. i8 s$ a: N
