查看: 118|回复: 0
ZCC6601替代SN6501和SN6505
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-12-3 16:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    FEATURES
    • Push-Pull Driver for Small Transformers
    • Wide range 3 V - 12 V Supply
    • High Primary-side Current Drive:  – 5 V Supply: 600 mA (max)  – 3.3 V Supply: 300 mA (max)
    • Low Ripple on Rectified Output Permits Small Output Capacitors
    • Soft start and Current limit
    • Thermal shutdown
    • Small 5-pin SOT23 Package
    APPLICATIONS
    • Isolated InteRFace Power Supply for CAN, RS- 485, RS-422, RS-232, SPI, I2C, Low-Power LAN
    • Industrial Automation
    • Process Control
    • Medical Equipment
    DESCRIPTION
    The ZCC6601 is a monolithic oscillator/power-driver, specifically designed for small form factor, isolated power supplies in isolated interface applications. It drives a low-profile, center-tapped transformer primary from a 3V to12 V DC power supply. The secondary can be wound to provide any isolated voltage based on transformer turns ratio. The ZCC6601 consists of an oscillator followed by a gate drive circuit that provides the complementary output signals to drive the ground referenced N-channel power switches. The internal logic ensures break-before-make action between the two switches. The ZCC6601 is available in a small SOT23-5 package, and is specified for operation at temperatures from –40°C to 125°C.
    0 w0 x, p9 c3 R: F) p
    GMT+8, 2025-8-24 08:35 , Processed in 0.125000 second(s), 24 queries , Gzip On.
