查看: 157|回复: 0
ZCC2785 (500V线性稳压器芯片,替代NCP785)
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-11-29 16:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    The ZCC2785 is a high−peRFormance linear regulator, offering a very wide5 t& q. ~. S& }
    operating input voltage range of up to 450 V DC, with an output current of up to
    " H" U- w' C: _  M, Z( r10 mA.  u$ Y8 L' r* T: o0 E, y
    Ideal for high input voltage applications such as industrial and home metering,5 \# p- ?- ]" }, r# r6 g1 H. U
    home appliances. The ZCC2785 family offers ±5% initial accuracy, extremely% V0 C8 z" z# Q  _/ @
    high−power supply rejection ratio and ultra−low quiescent current. The9 h" w7 P7 Y" i/ b
    ZCC2785 is optimized for high−voltage line and load transients, making this
      _" w! o  H6 b4 _1 K, R; Epart ideal for harsh environment applications.
    & K# C7 l3 A( \  B; t: p/ K2 iThe ZCC2785 is offered in fixed output voltage options 2.7V,3.3 V, and5.0 V.7 K. K2 p5 Z6 `6 b0 q! [
    package offers good thermal performance and help to
    : {0 J  H+ b* K8 s, e# H. eminimize the solution size.
    3 a+ O" m, ~. p. j1 H9 |, UFeatures
    6 r( Y& G% y: k4 X- a) s● Wide Input Voltage Range:+ X9 S. D6 _+ G+ @% U
    DC: Up to 450 V
    % g  Y9 e" {  w8 DAC: 85 V to 260 V (half−wave rectifier and 2.2 μF capacitor)
    & S' U, O. x/ b9 O●10 mA Guaranteed Output Current2 s" c/ r% f) C/ S: X& U
    ●Ultra Low Quiescent Current: Typ. 10 μA (VOUT ≤ 5 V)
    * _( A% a8 N% k8 b6 o●±5% Accuracy Over Full Load, Line and Temperature Variations
    9 Y. M2 y3 ]9 w& |- @- Z* ^●Ultra−high PSRR: 70 dB at 60 Hz, 90 dB at 100 kHz( V, X7 [* e' ?8 J
    ●Stable with Ceramic Output Capacitor 22 μF MLCC: Q6 p# ]2 w0 `" t, ]# @# n/ c
    ●Thermal Shutdown and Current Limit Protection
    9 J4 S. G: y* Q0 V5 O2 m+ m●Available in Thermally Enhanced ESOP8 Package. O( W. D1 Q" d5 L* L" y, g
    ●This is a Pb−Free Device
    + d3 d7 ]& t3 w$ ]! _3 K. R0 z% h" H! j3 R% j  ]
    GMT+8, 2025-7-6 22:21 , Processed in 0.125000 second(s), 24 queries , Gzip On.
