查看: 173|回复: 0
ZCC2213A锂电池均衡芯片完全替代HY2213A
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-11-22 17:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    1. General Description
    ( T# T: G9 B! _6 EThe series ofZCC2213is created for multi-cell battery packs to single-cell lithium-ion battery
    2 b! E4 P+ B% NCharge balance control, electrical level monitoring ICs and it also comprises high-accuracy 4 d4 D9 k: h8 z4 P1 ~
    voltage detection circuit and delay circuit.
    5 |4 v7 f" L# q7 i. M5 ]2. Feature
    # N, J: w: [7 D6 Z& j) U- uZCC2213series IC equips with the following features:1 h& v0 G' J# K0 _
    (1) High Precision Voltage Detection Circuit# X4 v5 P: \3 h/ @
     Overcharge detection voltage 4.000~4.500V Precision: ±25mV* G, N5 v) C4 v7 b6 p5 s. F: F9 S" O2 u
     Overcharge release voltage 3.800~4.500V Precision: ±35mV
      B4 P& m/ v7 w6 o* a! h; ^- U Standby detection voltage 2.70V Precision: ±15%# Y+ R% A( U' Z- e- K2 c& I) Y
     Standby release voltage 2.70V Precision: ±15%
    3 F2 x4 O4 z7 u$ C5 |(2) Delay times are generated by an internal circuit (external capacitors are unnecessary).
    0 Y4 T$ h  }6 s8 Z: U3 u(3) Low consumption current
    0 Z: v2 _2 n% c Operation mode Typ. value 2.5μA, max. value: 3.5μA (VDD=3.9V) ; V1 ]* @. Y6 C9 d3 n  l+ }1 V9 a
     Standby mode Max. value:0.5μA (VDD=2.7V). P3 {1 m5 o5 N* `4 y  v
    (4) Wide operation temperature range: -40℃~ +85℃
    ( x# t+ ?. X/ v2 }' ~(5) Small package: SOT-23-6' M9 Q+ y5 f7 [/ z4 P8 U$ [
    (6) The series are Halogen-free, green package' V: z6 m$ G9 ?
    3. Application& |6 ^7 [& d7 V* N+ Z3 @
     Multi-cell Li-ion rechargeable battery packs& M. ?  @" d* O6 o7 b8 D
    ; e4 y6 X7 X9 h4 u' I$ J" `! F+ ]
    GMT+8, 2025-7-3 20:28 , Processed in 0.093750 second(s), 24 queries , Gzip On.
