查看: 159|回复: 0
ZCC6601 直流隔离电源 替代SN6505
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-11-18 15:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    FEATURES2 h" u  w2 x$ L" l# w: P) s; t
    • Push-Pull Driver for Small Transformers$ z- Y9 q  T. ?: n2 ]! H
    • Single 3.3 V or 5 V Supply
    3 X2 E  t4 J! Q' |1 y0 T• High Primary-side Current Drive:
    6 F6 w2 y* ~2 X. {– 5 V Supply: 650 mA (max)( s. s& L! D2 m( [, K" P
    – 3.3 V Supply: 450 mA (max)
    , f0 q, h, r* ~: o" h• Low Ripple on Rectified Output Permits Small8 n6 [5 B! o- U4 e9 b) f; m. x
    Output Capacitors  z* J0 p! `& E# A( u
    • Soft start and Current limit
    . y$ L1 E' K, e) o% n& U: C3 h• Thermal shutdown' K) h1 |1 L: z4 P% ~& ?6 L
    • Small 5-pin SOT23 Package4 L6 x7 O/ o8 j" Y/ D9 e& Q0 q; D) Q
    • Short circuit protection
    9 J' j6 S4 h9 H* I• Over temperature protection. r) _9 h- ]- o& v
    ( _" [9 R2 ~1 i' Q0 G1 y* l
    APPLICATIONS
    $ J/ ]9 I- M8 n7 W! V[size=13.2667px]• Isolated InteRFace Power Supply for CAN, RS-485, RS-422, RS-232, SPI, I2C, Low-Power LAN
    : z) G8 z- S& d' g% m$ Z• Industrial Automation
    + }# o- }/ D+ o& S• Process Control2 }/ }4 N" I) S4 _' h
    • Medical Equipment- Z" E% _7 M5 ~- x7 u& r" t
    DESCRIPTION7 n5 V/ q, U7 _. W  U, K/ I
    The ZCC6601 is a monolithic oscillator/power-driver, specifically designed for small form factor, isolated power5 u$ r  k6 j7 f
    supplies in isolated interface applications. It drives a low-profile, center-tapped transformer primary from a 3.3 V
    ' H- s% L# Z/ N0 @+ kor 5 V DC power supply. The secondary can be wound to provide any isolated voltage based on transformer
    " R$ u$ A+ {/ Bturns ratio.& |4 W. o- x' i+ W* M& i% J, o) |
    The ZCC6601 consists of an oscillator followed by a gate drive circuit that provides the complementary output6 m- U1 X: L" @6 l0 h4 |0 F$ L
    signals to drive the ground referenced N-channel power switches. The internal logic ensures break-before-make3 L4 A4 l* R2 L2 F# y
    action between the two switches.
    5 C5 @  S: o0 l9 Z+ EThe ZCC6601 is available in a small SOT23-5 package, and is specified for operation at temperatures from –
    5 p8 D) X# G6 j! M2 X. `( d40°C to 125°C9 o/ E$ w3 ?. D/ F* g
    GMT+8, 2025-7-3 20:03 , Processed in 0.078125 second(s), 24 queries , Gzip On.
