( ] ?. M4 Z& u0 ?! p' I% }4 [6 y8 ` u2 f7 [( q$ p
! P5 r! r; }$ J5 x& k/ x$ d
) F& q1 O# @# B1 y4 E' b6 m' c
#include <reg52.h> I4 u, }. v/ b6 i! @1 ~4 W# g
#include <intrins.h>' @) }7 t- b. e% I1 c3 I' K
sbit RS=P2^0; 9 r- f( R7 W7 [- z8 C) F5 \9 V! C W
sbit RW=P2^1;
9 ]1 y+ n; N; S% b9 ?sbit E=P1^2;
. M3 S% R8 V- x- wsbit DQ=P1^4;
1 @, ]1 E+ R+ U" t# X' v" |$ Q
9 S5 ^6 t; A! ^1 K" l' s- }7 N: b" Tsbit led1=P0^0;- z3 X0 |& F: i/ ~3 P( J7 q
sbit led2=P0^1;' y1 X0 g- r' `0 U; B& d
sbit led3=P0^2;& O( v5 ~- t3 {$ I% }3 R
sbit led4=P0^3;
1 G! B3 K7 Y& ~+ W$ ]* n" g1 o, Lsbit led5=P0^4;
3 o2 H4 S9 ~: B0 W* k% S5 s" Psbit led6=P0^5;
Y: R. v) L. C* ~6 A: Xsbit led7=P0^6;
1 L% Y. u: r& o* hsbit led8=P0^7;; X: a: U; h# k4 \, |4 ^
sbit buzz=P0^6;
* ^1 T5 Z' F+ Y* V/ z& W
' E1 f4 i# x" `; t( Z( dunsigned char a,b,c,d,e,f,g,h;4 w* g- m" D1 \+ {4 }4 |
static int readtemp=0;. H2 W, h* J8 Z$ p7 j
unsigned char s[]={"Temp:"};" Q% t3 q6 Z) e/ X# \/ F3 ?( X
unsigned char str[]={"0123456789"};: U2 y) t. u" h- {5 U/ w I
. U) u+ P1 G6 ^6 f7 H//************************************************************************
' Y# c# Q' W: ], [9 Cvoid delay(unsigned int n)//Ñó3ùoˉêy
1 C0 P: T0 M! b( Q/ c+ O{2 l& n: W; ]. {6 d$ `
unsigned i=0,j=0;
0 L; s' _4 J! ?! L* F for(i=0;i<n;i++)
5 ]* ^2 w! \5 d( W, @ {( |. t) r4 _1 a; S! T' D
for(j=0;j<120;j++); q$ H2 `" v1 W. j+ x
$ |; b7 e( f7 ?+ x}
+ |+ {& ^, Y, P* m* N5 [//*************************ds18b20****************************************
/ g- w4 n8 W! L b7 j0 R7 b' i8 C! x% W/ Cvoid Write_DS18B20(unsigned char dat)* I3 }# e( l! o% M8 E7 ] D: P
' ^, H$ I3 l$ c9 ?3 T6 ?7 S4 d unsigned char i;7 q) V: Q" Z: F5 P
for(i=0;i<8;i++)
5 x" B* U4 E# L0 {9 a {5 L+ _' a- l. S6 b$ f- `7 a
DQ = 0;
1 x0 y4 M. I: J: O3 d3 h DQ = dat&0x01;
5 G, M/ a) I% _ delay(5);
, y }, h8 {5 O% C: H& ?. ]- G DQ = 1;
7 i& s- R2 E+ P: h4 ]" ~& ? dat >>= 1;) P5 d# E" j' s1 `3 M& m
$ `6 j2 u T# }; ]. a delay(5);: _, V0 K8 u' N) d
}% Q! E5 B/ @) O* r7 w6 ?. i8 k3 Q
unsigned char Read_DS18B20(void)
# f- O& U5 h% |8 K% }+ P{6 \2 Z: T9 j2 M x+ |
unsigned char i;
4 M1 b9 s+ o( _2 M2 G$ l unsigned char dat;
* M3 a$ ]5 I$ H; m \, C
, n }$ v) v! D1 c6 f) N) i for(i=0;i<8;i++)
: O7 h* b1 A1 z- l8 R: X& \ {7 k8 K- ], B6 W- N" B% G5 r
DQ = 0;" v3 P0 N2 T7 g/ }
dat >>= 1;
5 \9 s% w+ |! Z% k5 k: K" O DQ = 1;: Y# J$ ~3 F6 j' x* s2 f8 S
if(DQ)
" _) f* y( h1 }2 M; h {4 {4 ?! T; E# @
dat |= 0x80;% s F7 l: {! f8 M1 f1 a! @
} 1 W, L D. U. D- A
delay(5);
( r6 j# P7 Z) \- | }
( W8 q. B. j3 B7 S- h return dat;
. ?# g9 z, S8 I5 @, ~+ Q}; O6 E8 t! Q& n0 |( x- U
bit init_ds18b20(void)
1 O' g4 K+ t7 b6 S0 k; |{
O' s% {/ N" o T: {" B- M bit initflag = 0;
6 b2 l, k M3 h' H/ F) b
( D( J6 q- q1 [8 K6 ^- I DQ = 1;
( W o" e3 N) i b1 K delay(12);# N% G4 J7 f9 ?8 |2 J: N
DQ = 0;# _, `; o1 N8 h( r' i
delay(80);# h$ Z1 I; v3 n6 P
DQ = 1;
9 i+ M$ [* U$ H delay(10);" M! \2 {7 |# M1 e) B: z$ ^
initflag = DQ;
# ~5 ^3 Z3 ^5 B6 x( q+ O( W delay(5);
6 z) k6 J2 z$ u9 U# C5 ~
4 V8 ^1 v+ O9 @3 C1 V: F `' b* M W return initflag;# A& _$ W& s/ [; e* n( \4 m
}+ X/ f) E6 N( a- a# Z6 x
unsigned char Readtemp(void) Y2 h) k7 w7 b+ V
, c- d, |' r: b" R char temp; R$ ]3 w0 S/ S. ?3 P s& @8 o, V" w6 I
Z* [" \/ W5 p* @: b2 _
init_ds18b20();
) }- b0 ] m. u, y; d4 _- ?1 f Write_DS18B20(0xCC);+ v# k9 z4 X) e' A$ X6 k' X) j" {
Write_DS18B20(0x44);
2 T7 C; ]% o1 s6 S5 g delay(100);) A( u1 s* A: k, ?& t
, M/ y8 r2 ?3 n4 R* W8 H7 e& P; D
init_ds18b20();9 F6 x. V' I+ Z# H
Write_DS18B20(0xCC);( k5 ~4 ]/ E; S1 c# d
Write_DS18B20(0xBE);
( |7 U" }7 p/ }+ x& g2 C9 h delay(100);* o" V: V: B5 v3 c! a
a = Read_DS18B20();
9 U a2 N7 h8 [$ J) X b = Read_DS18B20();
/ s3 U h5 {/ a a& i R4 c6 Y temp = ((b*256+a)>>4); . ^; g: m- l4 J$ x
$ R6 W2 v1 V7 B( S' u" Z! m
return temp;7 a* D" j" |4 ]" }$ t, D: ~
$ x/ E7 R$ F( F) U- \9 s# s: R; O+ m}
, u3 x6 I) M. ?% w& [7 W, g' E
//*********************1602************************************
l" f6 ?' D4 F/ Fvoid writedat(unsigned char dat)9 Y* f* I8 R3 Z+ O1 K; y
5 F6 j; F( K" k) q/ d RS=1;0 _- ]4 G3 V$ [3 K* Z, U8 j
RW=0;
- W2 v2 Y5 ^! d/ n5 i E=0; ! L* d0 j- _$ H; Z" b$ \
P0=dat;2 H: T& q! o9 H. e
delay(5);2 K/ J6 k8 ^( Y" J# r1 H( o9 _
E=1;
* L& I, `& M- u5 S& |( s8 C E=0;+ |& p. R. c$ N
}9 r' i: q2 E# h7 w$ X
! s2 D5 J1 }! s& C- S5 L7 ^' B9 Uvoid writecom(unsigned char com)# Z4 {: V% W$ T" |/ X; j1 R
( Q; H- J7 e4 v5 W# |7 B) z# P: e3 m: k RS=0;
8 h) J( n1 y- h3 W, B; P4 c% U RW=0; 5 ~6 {: e% {, ]; n1 s6 \6 X( G
E=0; 8 z3 b a, S: h( p2 V
P0=com;, C# A1 g$ Z6 ~2 D! d6 D8 X
delay(5);
/ H7 T3 g) l5 f* Z" c8 S1 s2 h) | E=1;* I8 b L( B$ }7 A
E=0;( W4 Z. @/ F: ~# }: y/ q/ d
1 {' v X4 p* x% Nvoid initlcd()
" `8 _; f+ [! s% K( v1 I0 y5 b7 j{
: g7 W5 n& n# e+ ] writecom(0x38); 5 y- m/ R" G; J
writecom(0x0c); ( b2 ]1 @; j6 G
writecom(0x06);
' l2 ^% _7 e1 n, T; D writecom(0x01); s! ?3 e) x7 G& G1 {
}0 }7 F* j6 u) V
2 Y$ \6 o& w/ ?" a5 e7 D1 p( y2 @* o: X! b" H+ _
3 v) c' I/ j3 f. C% ?6 d7 `, i//*************oˉêy********************************************
: h7 p+ y: J/ Nvoid display()//ÏÔê¾oˉêy+ k+ t+ f& b- L1 H t8 K" n, e
{$ n4 f( h; q& ~. g: Z
unsigned int temp0=0,temp1=0,temp2=0,i=0;6 p1 }; y9 A2 C7 {. a' o: o
temp0=readtemp/100+'0';
" }$ G5 L" {* Z/ |' b5 x temp1=(readtemp%100)/10+'0';
9 d# v% @- p# S0 U5 O; o temp2=readtemp%10+'0';
3 h) w5 y7 s# H! r( }! ]0 R writecom(0x80);
% F- b+ b- R, {8 w! b delay(5);
3 j4 k( ?' l( ~3 L while(s!='\0')
5 ~ w% z6 A* v' T! Y2 z {7 }6 P, e( q0 h% [( u# [3 j
writedat(s);
! e% L5 Y* g8 o' h" ] delay(5);
8 K+ _9 | r$ N* Z& f i++;
1 Q$ d9 N0 e1 N( { } F' h1 Z! c8 y6 Z2 O$ N4 H
" \/ e4 H M0 F7 o writecom(0x80+6); & S1 G6 }. J6 }
delay(5);
% k! e+ u# l, ` writedat(' ');
; R1 Y' _4 a& O' ~0 t delay(5);7 s7 e, I7 {. @
writedat(str[temp0]);
6 }+ ^$ t- v4 }& L delay(5);
8 t" V& i9 E5 B" G) @% I; Q. y# N writedat(str[temp1]);/ M$ W0 n2 c! R
delay(5);
: _8 l7 Q$ I0 h3 h, n5 I2 V- D: ~ writedat(str[temp2]);/ B8 `- h+ C% F, `4 D' n
delay(5);
! W! t+ ] W- @* d% o7 R writedat('.');6 }3 C8 v( {& {1 E6 Q$ i
delay(5); 7 I3 v$ C- q7 ]7 Q, _- {: U
writedat('0');
9 S4 z" T/ O, n# j delay(5);
! U8 W) h8 A( L) l writedat(0xDF);" V( n; Y; i' R; c* o3 ?1 G. y8 m
delay(5); 7 Q/ W1 m/ A7 `4 l9 D7 h7 ?% r& M
writedat('C');- `8 b2 k" m1 O' L# O% q) `
delay(5);
+ G8 g2 l/ B( x% h- r8 t: I9 `}4 e2 H: M: R3 k: m6 r( P
void displayfu()
: I |7 h! F! r# \{
" F H' Y& \8 o% Q. \; B, z' P unsigned int temp0=0,temp1=0,temp2=0,i=0;
8 L, w& W# Y2 P$ } temp0=~readtemp/100+'0';- L. z0 T) ~0 [+ D! n2 h
temp1=(~readtemp%100)/10+'0';, p- W% H) ?2 g! @
temp2=~readtemp%10+'0';
1 z% R U2 j& W& }+ m* t7 E writecom(0x80); 0 P7 g( Z, b/ U# ~/ G& t2 K# W
delay(5);
# a# K. {& O! U9 N while(s!='\0')
+ B6 H5 _6 p+ c) q4 @* T7 K {
" K* q1 ^8 A( R5 \! t writedat(s);
: {! i3 c3 s0 l$ [* D( H delay(5);
' I% t+ D3 f& P) k0 M9 e" V i++;
: t7 _+ `4 W0 y/ x$ b }8 ^; @' H0 Z, p5 k' R
2 L* ]9 S; d$ n/ V- x) | K' b* ~ writecom(0x80+6); - U7 }; S' |5 M/ e4 Z8 R
delay(5);) ^( y; G& \2 b' e! k4 ~) V4 c- K. [0 p0 i
writedat('-');9 ]0 |' R2 x0 u+ y
delay(5);
" F: E+ q2 z' m- l+ a5 m5 X, Z writedat(str[temp0]);, l; @6 A3 Y& B$ P
delay(5); 4 l4 w4 ^, p7 v
writedat(str[temp1]);7 h; ]0 u h7 g6 s8 \) @! P1 t5 Q) [
delay(5);
+ }/ i9 x! {5 x! i U, f6 Z2 | writedat(str[temp2]);
3 M* m! A* m6 z! r1 ?" O% E delay(5); * X8 @9 I2 M4 h
writedat('.');
) m' f+ k# G7 \& U& z9 x% ~7 j delay(5);
! r! M$ ]0 _1 b writedat('0');# }9 k) w) Z: U) P0 f
delay(5);
" r* P! {0 P6 V5 {& Q2 i$ ` writedat(0xDF); @3 J( q& A" N ^3 d! ~3 K
delay(5); # e- z& n5 M+ L$ C1 t- C' r4 Q
writedat('C');8 }2 S7 `3 d; q" A4 E- }
delay(5); # j! K! S- s' C' F7 T0 ?8 i1 C! S+ ~
9 s' j6 ~ w) W7 f4 p//************************Ö÷oˉêy******************************
8 b) U& a/ \4 H& l9 |2 dvoid main()
& b! _# l# ^* |1 A8 Y{& @" @4 b% [! O* w
int i;# |1 C2 W7 G. x2 x% w8 ?0 R
initlcd();/*/ h& f5 O7 @" i) K' V0 H( M* g
void disply18b20Rom(char Rom);
! v- T/ h% U+ }- r: C+ _4 [Write_DS18B20(0x33);' `( D& t+ v! W; q/ ?
delay(1);
3 F3 g8 A3 m; J& W& y4 Da =Read_DS18B20();
. A# ]" O8 n2 R/ ]3 F b =Read_DS18B20();0 z, ?# u6 N+ u5 C3 J
c=Read_DS18B20();
) v. j/ o. ?9 Y4 n) @% Y d =Read_DS18B20();% b) ]( f9 d% O4 f
e=Read_DS18B20();
( g+ B" s" E8 a f=Read_DS18B20();
7 a& @/ x v: Y9 d g =Read_DS18B20();+ k6 \3 {& k6 P( z/ P4 O; s
h = Read_DS18B20();
: i/ s* L9 n5 q, Q0 t. _ writecom(0x80+0x40);: p: G5 }$ e6 Y! `
display18b20Rom(h);
9 y% h7 g3 t+ u* O2 Tdisplay18b20Rom(g);
& e( V' i; [- e% e( } R. M: Tdisplay18b20Rom(f);: ~5 R4 I9 L9 j( [' ` ]
display18b20Rom(e);
5 H9 e/ y; v% [display18b20Rom(d);
0 N7 F0 M8 x$ T# I: S9 f$ udisplay18b20Rom(c);
7 U0 D9 c: D7 Vdisplay18b20Rom(b);; w& N( b7 E; j3 k
display18b20Rom(a);*/ `' U+ |; ~) ?, V- `$ i- Y; q; }: @
" B: s8 |6 V% o+ H( Y; r
while(1)
) I) L1 q% U% d {) j; Z, ^" T3 b- g2 L* K/ ?+ W: w
if(Readtemp()==0)+ \: P) ^5 V* S9 q
{) _4 [' w2 X, W2 M/ z# Z& ~
writecom(0x01);( ]7 w0 z1 u [. h
readtemp=0;& d5 s0 X( l% S ~; s. b; M
display();
: @9 A5 c+ _; z4 u' j6 U% z }4 b' l! L6 V5 a
else if(Readtemp()<150)
8 x* I. [$ W$ a, D0 K7 _# m {2 R/ y8 I. r! P, H/ Y# F) i
readtemp=Readtemp();
F0 s* S0 S/ v2 \ display();. V, [% l" u j! y0 N* T. {
) O) w; t% V; l" z- ~ else
; Z7 D9 w; f. Q! } l* r, s( e4 H7 H {5 y2 F/ c+ C; m! V
int a=0; _8 D! ~3 A6 S
a=Readtemp();: f) a" C; I1 [! D; @- A0 \5 e4 ~
readtemp=a-257;: ^3 k5 K$ g6 M3 {
displayfu();/ c P9 c3 L0 e1 Y
}0 Q4 h6 D* X Q0 ~) l: y! |+ z
if((readtemp>=20)||(readtemp<=10))
3 f9 i. y H& o$ t {1 E9 n4 D- @; U. }
for(i=0;1>0;i++)
% f; S6 a9 M# d4 S {
6 @; o: \1 P& k/ r6 | led1=1;led2=1;led3=1;led4=1;led5=1;led6=1;led7=1;led8=1;7 u% L1 O8 \$ s4 V* d
buzz=1;
8 J8 N- B( Z G. l/ x6 R! |+ ~# H delay(500);# \( i5 i4 g! L$ }8 v! y" Z) L
led1=0;led2=0;led3=0;led4=0;led5=0;led6=0;led7=0;led8=0;( i1 l8 T& l6 u8 {( t/ o- Y( M( O
buzz=0;4 P: Y; P3 A' a) i
delay(500);) \" G7 l- r0 v, `) |' a
4 P, x0 e1 A, x" [$ _ j }$ E N0 M$ g8 [* E" U' r2 K& ?5 r
& ?( E; Z: u. v" t8 b}6 _4 k" h7 ]0 x
' Y0 b: O; r1 V8 C1 q
2 X6 Z0 u, T& ?8 R
