查看: 180|回复: 0
ZCC2213A锂电池均衡芯片完全替代HY2213A
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-11-16 16:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    1. General Description* g, _9 o! C7 E4 i9 E+ i
    The series ofZCC2213is created for multi-cell battery packs to single-cell lithium-ion battery
    5 n, r: h: x, R$ y8 LCharge balance control, electrical level monitoring ICs and it also comprises high-accuracy
    4 i1 T% n" D- uvoltage detection circuit and delay circuit., N8 _: k* R2 f* b$ w: G# X: `1 r3 n' b
    2. Feature* \% D. y0 F& \# T. v/ X
    ZCC2213series IC equips with the following features:
    " p( n9 c" p$ e  m' S3 g$ r(1) High Precision Voltage Detection Circuit
    ' _. p+ @& N, G' X Overcharge detection voltage 4.000~4.500V Precision: ±25mV
    ( K  M6 Z8 t6 N; K& y5 v8 ]$ `2 K: ? Overcharge release voltage 3.800~4.500V Precision: ±35mV9 p; ~* \# A  ~; K0 O) b7 y, v8 q
     Standby detection voltage 2.70V Precision: ±15%. a* j: l* S# n- F0 Q! ~% y
     Standby release voltage 2.70V Precision: ±15%6 S1 L9 W4 n' S* F
    (2) Delay times are generated by an internal circuit (external capacitors are unnecessary).
    1 O- M4 Y( O7 @+ ^(3) Low consumption current
    & `; b: q# l( c Operation mode Typ. value 2.5μA, max. value: 3.5μA (VDD=3.9V) 6 v1 Q) {* b8 \1 ^; y$ @. {! z2 B
     Standby mode Max. value:0.5μA (VDD=2.7V)4 O; I- C5 S6 W+ l+ K
    (4) Wide operation temperature range: -40℃~ +85℃
    ' x' r" n! {4 g& W3 y  R2 ](5) Small package: SOT-23-6+ t" i1 N5 B$ S
    (6) The series are Halogen-free, green package
    8 X# Y1 ?" c. J3. Application9 S5 O- ^( ^9 J
     Multi-cell Li-ion rechargeable battery packs
    . e1 ~# X+ j2 @" Y, l9 D* W! d
    7 f; z3 m. t9 S0 H. Q
    GMT+8, 2025-7-3 14:28 , Processed in 0.078125 second(s), 24 queries , Gzip On.
