查看: 191|回复: 0
ZCC2213A锂电池均衡芯片完全替代HY2213A
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-11-11 17:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    1. General Description
    & Q. f- g# u. E/ D1 v, h- _) aThe series ofZCC2213is created for multi-cell battery packs to single-cell lithium-ion battery 0 K/ e% w, ~9 n* r9 s+ A4 L' Q
    Charge balance control, electrical level monitoring ICs and it also comprises high-accuracy & n5 `, q2 C1 h7 I" h4 [
    voltage detection circuit and delay circuit.0 c4 L: ]& f& {# Y7 Y1 N* ~8 x5 f
    2. Feature
    ) Z; o5 f' O0 ?0 [5 @7 xZCC2213series IC equips with the following features:# ^* ~& B2 d$ Z  n* m; C
    (1) High Precision Voltage Detection Circuit. g5 f# g8 b) u* w, n
     Overcharge detection voltage 4.000~4.500V Precision: ±25mV
    ( j- `0 m8 X# S+ P* } Overcharge release voltage 3.800~4.500V Precision: ±35mV
    ) c' G& k2 s! s- s$ }4 o* w; k6 I Standby detection voltage 2.70V Precision: ±15%
    * ~& ^4 o9 P' z6 _5 |' D Standby release voltage 2.70V Precision: ±15%: {1 @/ v% p7 v3 r1 r0 C% c
    (2) Delay times are generated by an internal circuit (external capacitors are unnecessary).) e' G" {; G7 |( i/ q$ ^
    (3) Low consumption current9 ~& Z* `) z* h8 b3 \2 }
     Operation mode Typ. value 2.5μA, max. value: 3.5μA (VDD=3.9V)
    # l$ a, @: Q$ ~& {$ y& } Standby mode Max. value:0.5μA (VDD=2.7V)
    ' [2 X6 J* J6 m1 l8 h(4) Wide operation temperature range: -40℃~ +85℃
      F5 V+ G: Z  b7 C+ N(5) Small package: SOT-23-6
    & j9 L9 o6 m2 _8 B$ j3 x(6) The series are Halogen-free, green package0 p4 m6 O" [3 F3 M* G# t; O
    3. Application
      h6 X  ~5 o. d2 n+ u2 ] Multi-cell Li-ion rechargeable battery packs9 p3 A$ z5 ^0 Y
    / H6 h$ V3 b+ R! g* |
    GMT+8, 2025-7-1 16:59 , Processed in 0.062500 second(s), 24 queries , Gzip On.
