TA的每日心情 | 开心 2022-5-9 15:00 |
签到天数: 28 天 [LV.4]偶尔看看III
FEATURES
; j: g6 D) ~% [) q1 W$ M9 dAPPLICATIONS
* r6 ]) |0 Z: Y0 Q3 J• Push-Pull Driver for Small Transformers
8 Z; I2 `( x2 t% R• Isolated InteRFace Power Supply for CAN, RS- ' m* l5 u. I. F) a6 `4 ]
• Single 3.3 V or 5 V Supply
* x& M4 i+ p# X( A* Y7 y1 T• High Primary-side Current Drive: 0 U! ~% R k! e) U5 U# r8 L1 Y
– 5 V Supply: 650 mA (max)
/ N. W3 a! |! P" g1 |– 3.3 V Supply: 450 mA (max) ( l' A( y5 k- o- H
• Low Ripple on Rectified Output Permits Small
* k9 a9 K8 s6 V6 C1 K- v/ l/ YOutput Capacitors , c Q) O, @7 h l0 q1 u
• Soft start and Current limit
2 R r, R* `0 o) y# ]• Thermal shutdown 7 ?2 k+ y( O, P& C
• Small 5-pin SOT23 Package . d7 k; a( r2 b
485, RS-422, RS-232, SPI, I2C, Low-Power LAN
8 C& p/ f* C9 f" l# i0 O• Industrial Automation
, `8 n H# h }9 K/ y) t* ?• Process Control
2 o" h9 `' O9 u3 p) u1 h2 k2 R• Medical Equipment
) f% T8 f4 V) ~5 b$ A A1 {DESCRIPTION
* q/ N" G, {$ W0 I6 ^The ZCC6601 is a monolithic oscillator/power-driver, specifically designed for small form factor, isolated power
$ O3 E- D* S& V' y# K( _supplies in isolated interface applications. It drives a low-profile, center-tapped transformer primary from a 3.3 V
( b3 t8 c" i, r, R F M) V8 zor 5 V DC power supply. The secondary can be wound to provide any isolated voltage based on transformer
; Q3 d" Z1 r/ s7 V. l$ xturns ratio.
+ a! A+ `, Q0 x: }7 M2 K6 G6 tThe ZCC6601 consists of an oscillator followed by a gate drive circuit that provides the complementary output
, ~. A8 A6 N5 Z3 o+ T% O9 G8 ~3 v, f Lsignals to drive the ground referenced N-channel power switches. The internal logic ensures break-before-make ) G7 K0 }6 I* M, t, b
action between the two switches. ) }( E9 V Z. X3 a5 N8 k) W
The ZCC6601 is available in a small SOT23-5 package, and is specified for operation at temperatures from – $ K, C# X; Y: @: W" y$ i
40°C to 125°C.' p d8 J6 p6 j; n; W* H) @
6 \, c1 [& d3 W* ~: x
