查看: 556|回复: 1
音频光纤同轴发射器方案CS8406+MS1808,附带电路图参考设计
发表于 2021-10-28 16:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
音频光纤同轴发射器方案可以由CS8406+MS1808来做成。具体以下为音频光纤同轴发射芯片CS8406和音频ADC芯片MS1808详细介绍。深圳锦宏世纪/李先生189380473001 Z3 w4 _" F! t( y7 L
MS1808 是带有采样速率 8kHz ~ 96kHz 的立体A/D 转换器,适合于面向消费者的专业音频系统。
( V! }% L* W. mMS1808 通过使用增强型双位  技术来实现其高精度的特点。MS1808 是单端的模拟输入所以不需要外部器件。音频接口有两种类型(最高有效位对齐, I 2S )适合用于像 DTV,DVR AV 接收器的系统。* W1 n# ~* {) U, ]2 T: a
主要特点+ ]9 G% y' G  D0 v: Q) S% e
线性相位抗混叠数字滤波器8 _! @. k2 N9 ?1 U! @5 I% M" j7 x* c
单端输入$ D6 `9 G1 o  z, B" N8 p- m
带失调电压消除的数字高通滤波器
$ U" }/ C! N1 ~, h9 N信噪失真比:85dB; Q. i+ H! v7 h* K
动态范围:95dB1 a4 Q2 a8 X9 b% N
信噪比:95dB) z- Q$ \; E  f. t
采样速率 8kHZ 96kHz5 Y. s: P& C* J* o
主时钟:
5 A5 w  [7 Y$ n" }4 W  h256fs/384fs/512fs/768fs
0 a5 k& d' o- t) y(8kHz ~ 48kHz)/ o7 P# S8 ?# N
256fs/384fs& s" U2 n3 R- p( w/ ]# L9 l
(48kHz ~ 96kHz)
$ ~7 v* m3 _& @2 n0 i" r" ]$ A主机/从机模式
: |3 i+ J- J& R' w7 e- @音频接口:24 位最高有效位对齐/ I 2S
: z2 g0 V: q. E3 @电源:4.5 ~ 5.5V 模拟,2.7 ~ 5.5V 数字$ z4 K" m) d) Z* k: e
温度范围 -20 ~ 85
  Z2 Y* a3 X. p2 U  sTSSOP14 封装* _& g) M" }- a5 I  |% ^  V
应用
5 f6 a* m" u# `4 J8 yDVD 录音机
' x: \5 }% l( v" i数字 TV
( s) U: o0 y, @7 s5 s$ ?CD 录音机
- C' }7 V! t9 n/ ]) ?
The CS8406 is a monolithic CMOS device which encodes and transmits audio data according to the AES3,IEC60958, S/PDIF, o r EIAJ CP1201 standards. The! g( |) f. I2 F$ Y" a9 ~* e
CS8406 accepts audio and digital data, which is thenmultiplexed, encoded, and driven onto a cable.! w. ^; ^; b- a1 v" i% }
The audio data is input through a configurable, 3-wireinput port. The channel status and user bit data are input through an SPI™ or I2C® microcontroller port, and- m+ M3 v# ^7 X# P4 I( i6 F
may be assembled in block-sized buffers. For systemswith no microcontroller, a Stand-Alone Mode allows direct access to channel status and user bit data pins.
# P# ~$ Q, X; t  wThe CS8406 is available in a 28-pin TSSOP and SOICpackage for both Co mmercial (-10o to +70oC) andAutomotive grade (-40o to +85oC). The CDB8416Demonstration board is also available for deviceevaluation and implementation suggestions. Please* {5 {/ @: B  p. |
refer to “Ordering Information” on page 34 for completedetails.
  b$ [$ j- i" O' @1 [Target applications include A/V Receivers, CD-R, DVD
4 R0 U- b' U( z7 yreceivers, digital mixin g consoles, effects processors,
6 S+ `/ M# D* }6 tset-top boxes, and computer and automotive audio systems
" K4 N7 I" Y% G
9 ?* s# ?! ^  ^8 uComplete EIAJ CP1201, IEC-60958, AES3,6 q* F8 @! f  Z6 o
S/PDIF-compatible Transmitter
3 R1 ]  A6 P( y4 `5 ^& i
- M# l* w& r& @, s& `3 E+ F/ K+3.3 V or 5.0 V Digital Supply (VD)
# y+ ?% q+ O4 Q! R
6 J# x: `0 C3 }7 `: P+3.3 V or 5.0 V Digital InteRFace (VL)/ Y+ a4 |4 [2 y: B' @  @; k
5 l% c7 @1 q; a: o& |
On-Chip Channel Status and User Bit Buffer8 t. n# U; v/ Z' z  D
Memories Allow Block-Sized Updates
, A" F3 ^* \3 d  G
$ L! A0 c; M- r2 c: MFlexible 3-Wire Serial Digital Audio Input Port
& B7 [& m: j! g, P
6 u* e' X4 p2 A- `% X- yUp to 192-kHz Frame Rate
5 {$ M! c/ a' S+ t1 I/ Q& @
8 B$ y. ?' s% h1 T+ [4 D3 `! w5 aMicrocontroller Write Access to Channel Status
" J" B" t) ]: T; j9 Z3 Xand User Bit Data
( n  C/ K6 r; T& W7 G  B+ T9 l' u6 }+ l3 ], H3 v
On-Chip Differential Line Driver$ [/ J  h& |1 K
7 V; A, ~3 N  Z+ A& iGenerates CRC Codes and Parity Bits
" o. J( \6 W# V: z- N: L4 T2 i3 j0 G, w+ E) {2 Q+ @% E9 C
Stand-Alone Mode Allows Use without a0 ?: `" p, q; H9 U! o. Z
Microcontroller
$ X# ]# \2 `* {7 j0 b* K5 @4 P
8 |/ p: J; d3 k( f7 W& R
& Q/ C3 o5 C, b
发表于 2021-10-28 16:40 | 只看该作者
适合于面向消费者的专业音频系统
GMT+8, 2025-10-5 10:57 , Processed in 0.109375 second(s), 23 queries , Gzip On.
