TA的每日心情 | 开心 2020-1-6 15:29 |
签到天数: 1 天 [LV.1]初来乍到
;## 1-SKILL CHECK Angle of Cline seg on the Cline#
axlCmdRegister( "csa" `csa)
(defun csa ()
originalVisible=axlVisibleGet()
designName = axlCurrentDesign()
design_path = axlGetDrawingName()
design_unit = car(axlDBGetDesignUnits())
AllObject=list()
drc = 0
stop = nil
logWindow = nil
max_angle = 90.0
axlSetFindFilter(?enabled '(noall CLINES) ?onButtons '(noall CLINES))
mypopup = axlUIPopupDefine(nil (list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun)))
axlUIPopupSet( mypopup)
while(axlSelect(?prompt "Please select Cline...")
AllObject = axlGetSelSet()
axlClearSelSet()
if(logWindow != nil then
axlUIWClose(logWindow)
if(isFile("Clineseg_angle.log") == t then deleteFile("Clineseg_angle.log"));end if
logWindow = nil
);end if
drc = 0
WriteOutFile = outfile("./Clineseg_angle.log" "w")
fprintf(WriteOutFile, "Design name: %s\n", design_path)
fprintf(WriteOutFile, "Angle Check: %f\n", max_angle)
fprintf(WriteOutFile, "%s %s\n", "Check Date:", timeToString(fileTimeModified("Clineseg_angle.log")))
fprintf(WriteOutFile, "%s\n", "------------------------------------------------")
fprintf(WriteOutFile, "%-14s %-10s %s\n", "Layer", "Angle", "Locations")
foreach(object AllObject
Netname = object->net->name
Layer = object->layer
drcLayer = strcat("DRC ERROR CLASS/", cadr(parseString(Layer, "/")))
Cline_Segments = object->segments
while(length(Cline_Segments) > 1
First_seg = car(Cline_Segments)
Second_seg = nthelem(2,Cline_Segments)
First_seg_width = First_seg->width
Second_seg_width = Second_seg->width
if(First_seg_width < Max_LW || Second_seg_width < Max_LW then
First_seg_length = axlDistance(car(First_seg->startEnd) lastelem(First_seg->startEnd))
Second_seg_length = axlDistance(car(Second_seg->startEnd) lastelem(Second_seg->startEnd))
Third_seg_length = axlDistance(car(First_seg->startEnd) lastelem(Second_seg->startEnd))
aa = First_seg_length*First_seg_length
bb = Second_seg_length*Second_seg_length
cc = Third_seg_length*Third_seg_length
ab2 = 2*First_seg_length*Second_seg_length
CosC = (aa + bb - cc)/ab2
AngleInDegree = axlRadToDeg(acos(CosC))
;### CONG THUC TINH GOC _axlAngleBetweenLines(list(pt1, pt2), list(pt3, pt4)) =>CHUA TEST THU
if(AngleInDegree <= max_angle then
fprintf(WriteOutFile, "%-14s %-10.2f %L\n", Layer, AngleInDegree, car(Second_seg->startEnd))
actual_text = sprintf(actual_text "%.2f", AngleInDegree)
drc_text = sprintf(drc_text "No Permit Angle In Cline")
drc_maker = axlDBCreateExternalDRC(list(drc_text sprintf(nil "%.3f", max_angle)), car(Second_seg->startEnd), drcLayer , list(First_seg Second_seg) , nil , actual_text)
drc = drc + 1
;else
; printf("%L\n", AngleInDegree)
);end if
);end if seg_width
Cline_Segments = cdr(Cline_Segments)
);end while i> 1
);end foreach clines AllObject
; Close the file and wrap up
fprintf(WriteOutFile, "%s\n", "END OF FILE")
close(WriteOutFile)
printf("Process done!\n")
axlVisibleSet(originalVisible)
axlShell("redisplay")
if(drc > 0 then
logWindow = axlUIViewFileCreate("Clineseg_angle.log" "Angle report..." nil );t xoa file sau khi xem, nil khong xoa
else
printf("No Error Found!\n")
if(isFile("Clineseg_angle.log") then deleteFile("Clineseg_angle.log"))
);end if
printf("Please select Cline...\n")
);end while
);end defun Clineseg_angle
