大家好,以前用AD6,pads, 与在用SPB16.2,很不习惯呀。8 L2 l' X2 _( p
在做完原理图,DRC检查没有错误后,生成网表时,出现:; T( l0 z" `5 R9 t
#248 ERROR(SPCODD-248): All physical pins are common in section 1 of physical part 'CEJMK212BJ106KD_T'. Each section must have at least one non-common pin.
N; B T2 U! I _ v Open the part in Part Developer and ensure that you have at least one non-common pin for each section of a physical part.! h9 r. D: ~ V( l# C" _
我检查了原理图SYMBOL和PCB封装,也换另外的PCB封装试了试,错误依旧。3 p4 p3 G5 s" b0 I
大家帮我看看,是什么原因呀。! b" {/ F6 l3 v# R8 W5 A0 `
我在画原理图时还碰到其它的问题:* P& M( v7 }3 Q* `: g
1:元件编号如电阻电容之后,总自动出现一个A或是B, 如:R120A . `9 O, F+ V+ _* {- ^3 Y
2: 在COPY一个元件到另外一个地方去时,本应每COPY一次编号都自动增加,可现在是每COPY两次,编号才自动增加一次。
% k( j8 ?6 ^; K& f6 T$ H6 { 为方便大家检查,我把生成网有的出错贴在下面了:
8 ~5 [* P; {/ M$ G6 {& j4 N6 A% f ********************************************************************************+ C' r( ]1 o5 ^3 T/ k
Design Name:
' i9 ]0 T5 U+ M# xE:\Hi3515FJ_cadence\hi3515fj.dsn
( N/ U& t8 x0 O) _Netlist Directory:
+ b: j( i' d) L) Y3 {0 kE:\HI3515FJ_CADENCE\NETLIST2 K* r# u1 y' M6 }
Configuration File:3 E6 J/ A) u1 y6 D7 }
D:\Candence\SPB16.2\tools\capture\allegro.cfg- c6 O+ F# c7 z. i! O9 Q
Spawning... "D:\Candence\SPB16.2\tools\capture\pstswp.exe" -pst -d "E:\Hi3515FJ_CADENCE\hi3515fj.dsn" -n "E:\HI3515FJ_CADENCE\NETLIST" -c "D:\Candence\SPB16.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
' E$ H9 O8 [+ `#1 Warning [ALG0016] Part Name "PHONE JACK-4_0_PHONEJACT_4_PHONE JACK-4" is renamed to "PHONE JACK-4_0_PHONEJACT_4_PHON".5 M Q, ^$ B8 z+ w
#2 Warning [ALG0016] Part Name "SN74CBT16214_0_SOP56-20-250-550_SN74CBT16214C" is renamed to "SN74CBT16214_0_SOP56-20-250-550".9 ]- C* D- y6 c' a- K+ v, W
Scanning netlist files ...
' P* z% Y4 N! v8 K! F8 SLoading... E:\HI3515FJ_CADENCE\NETLIST/pstchip.dat6 Y/ O0 U: a9 H5 ], ^8 [5 A
#248 ERROR(SPCODD-248): All physical pins are common in section 1 of physical part 'CEJMK212BJ106KD_T'. Each section must have at least one non-common pin.1 s' X4 a* F$ ^( o4 Z# S
Open the part in Part Developer and ensure that you have at least one non-common pin for each section of a physical part.$ \6 L5 ]6 d; k+ v" C# C
ERROR(SPCODD-47): File E:/HI3515FJ_CADENCE/NETLIST/pstchip.dat could not be loaded, and the packaging operation did not complete. Check the pxl.log file for the errors causing this situation and package the design again.# c( L. K/ C) X' k( Y1 f
#53 ERROR(SPCODD-53): Packaging cannot be completed because packaging has encountered a null object ID. The design may not have been saved correctly. Save the schema$ [4 y; C5 H( ?# L
tic and rerun packaging.! j$ V1 F6 i: K4 S
#3 Error [ALG0036] Unable to read logical netlist data.
3 W) e9 _ O% GExiting... "D:\Candence\SPB16.2\tools\capture\pstswp.exe" -pst -d "E:\Hi3515FJ_CADENCE\hi3515fj.dsn" -n "E:\HI3515FJ_CADENCE\NETLIST" -c "D:\Candence\SPB16.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
: h/ o+ a6 X/ t/ {( _* F$ D4 l& \* o% o
*** Done *** |
