网上试过很多方法了都不行,
3 e$ X1 x3 x8 P0 G7 x' C: ^总是到 Delta compression using up to 2 threads.
# u1 ~1 c$ U' Q" C% ]Compressing objects: 100% (17094/17094), done.! o C0 P' f. p7 I2 ]7 C
Writing objects: 23% (4049/17483), 836.30 MiB | 100.78 MiB/s 就不动了/ `- i. _ s* d8 w( E# |
设置了git config --local http.postBuffer 1957286400,8 P4 |1 O6 V8 r% L; h
gitlab也设置了Maximum attachment size 和 Maximum push size = 5000
0 g4 ~- |% d; E: o& k但是就不行?看日记
+ Z9 b- v, p( L+ N$ q2020/07/08 16:23:30 [error] 20218#0: *859 client intended to send too large chunked body: 262138870+16372 bytes while sending request to upstream, 这到底还要设置哪儿 4 K4 P7 W" I7 l3 g8 T
