查看: 780|回复: 3
基于matlab GUI录音与音频处理
发表于 2021-6-24 11:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
9 |3 X  y( X+ E. \" p$ E% T0 l
一、简介
; I) J' W; O9 {6 c* H- T基于matlab GUI界面处理录音与音频
8 P) u) v+ W$ B$ A/ y% ^5 t
' t& S% q+ E2 N/ j- z$ @二、源代码
) S, G9 h: W3 }0 A
  • function varargout = sigany(varargin)
  • % SIGANY M-file for sigany.fig
  • %      SIGANY, by itself, creates a new SIGANY or raises the existing
  • %      singleton*.
  • %      H = SIGANY returns the handle to a new SIGANY or the handle to
  • %      the existing singleton*.
  • %      SIGANY('CALLBACK',hObject,eventData,handles,...) calls the local
  • %      function named CALLBACK in SIGANY.M with the given input arguments.
  • %      SIGANY('Property','Value',...) creates a new SIGANY or raises the
  • %      existing singleton*.  Starting from the left, property value pairs are
  • %      applied to the GUI before sigany_OpeningFunction gets called.  An
  • %      unrecognized property name or invalid value makes property application
  • %      stop.  All inputs are passed to sigany_OpeningFcn via varargin.
  • %      *See GUI Options on GUIDE's Tools menu.  Choose "GUI allows only one
  • %      instance to run (singleton)".
  • % See also: GUIDE, GUIDATA, GUIHANDLES
  • % Copyright 2002-2003 The MathWorks, Inc.
  • % Edit the above text to modify the response to help sigany
  • % Last Modified by GUIDE v2.5 14-May-2008 18:52:43
  • % Begin initialization code - DO NOT EDIT
  • gui_Singleton = 1;
  • gui_State = struct('gui_Name',       mfilename, ...
  •                    'gui_Singleton',  gui_Singleton, ...
  •                    'gui_OpeningFcn', @sigany_OpeningFcn, ...
  •                    'gui_OutputFcn',  @sigany_OutputFcn, ...
  •                    'gui_LayoutFcn',  [] , ...
  •                    'gui_Callback',   []);
  • if nargin && ischar(varargin{1})
  •     gui_State.gui_Callback = str2func(varargin{1});
  • end
  • if nargout
  •     [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
  • else
  •     gui_mainfcn(gui_State, varargin{:});
  • end
  • % End initialization code - DO NOT EDIT
  • % --- Executes just before sigany is made visible.
  • function sigany_OpeningFcn(hObject, eventdata, handles, varargin)
  • % This function has no output args, see OutputFcn.
  • % hObject    handle to figure
  • % eventdata  reserved - to be defined in a future version of MATLAB
  • % handles    structure with handles and user data (see GUIDATA)
  • % varargin   command line arguments to sigany (see VARARGIN)
  • hstartshow=figure;
  • imshow('start.jpg');
  • pause(3);
  • % Choose default command line output for sigany
  • handles.output = hObject;
  • handles.time=str2double(get(handles.time,'String'));                  %  ù±
  • handles.sample=str2double(get(handles.sample,'String'));              % ù
  • handles.filename=get(handles.name,'String');                          % ±
  • axes(handles.axes1);                                                  %
  • set(gcf,'doublebuffer','on') %Reduce plot flicker
  • P = plot(zeros(1000,1));                                              % ú
  • xlabel('Samples'), axis([0 1000 -1 1]), grid on
  • title('采样数据实时波形');
  • handles.P=P;                                                          % ±±ú
  • handles.data=[];                                                      % ó
  • AI = analoginput('winsound');                                         % ù¨è±
  • addchannel(AI,1);                                                     % íù
  • handles.AI=AI;                                                        % ±ù¨è±
  • % Update handles structure
  • guidata(hObject, handles);
  • % UIWAIT makes sigany wait for user response (see UIRESUME)
  • % uiwait(handles.figure1);
  • close(hstartshow);8 C3 `; T% _: A& v
  z* X/ T7 ?- J/ `2 I
/ h; B' S7 P  @% N  U: K三、运行结果
0 A- ]" @8 B  D4 {* x8 y" ~% X
: g: [: u  G! f' t  {+ T/ `
& b/ E0 C! X9 }1 k % c* ^/ }6 J) h) U+ @# N% b: O
" o4 D- D7 K- e+ K0 J
& o7 ?) O) `: X! A
5 I' e" ~0 l$ q' X* ?4 w/ W' f9 X- p+ d6 r0 N
, o! |  m  M* q4 R
发表于 2021-6-24 13:22 | 只看该作者
基于matlab GUI录音与音频处理
发表于 2021-6-24 13:23 | 只看该作者
基于matlab GUI录音与音频处理
基于matlab GUI录音与音频处理
GMT+8, 2025-10-29 10:21 , Processed in 0.156250 second(s), 26 queries , Gzip On.
