查看: 4816|回复: 17
[allegro17.2][6层]Jetson_Xavier_NX_A01参考设计(EFM8SB1+TXB0108+USB)pcb文件
发表于 2021-6-12 16:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
7 n8 d% d( A, ?4 `8 L  J$ k1 G# P( X
[allegro17.2][6层]Jetson_Xavier_NX_A01参考设计EFM8SB1+TXB0108+USB)pcb文件
8 X+ f6 [8 j9 K4 {& U0 @, }) n: e0 h  a4 y' q. h% M
文件描述:! d) m+ N2 X: Y* p' D( a
- T. L6 C& t7 ~. n' D1 \9 s! h1. 作品用途:Jetson_Xavier_NX_A01参考设计9 k# A2 V! W+ k; S: Q
2. 软件版本:allegro17.2
" v: _$ h$ `1 t, s+ \  y
- a+ S3 e0 G+ B) b- m3. 层数:6层6 \, g& E0 p8 S; x
4. 用到的主要芯片:EFM8SB1+TXB0108+USB
6 K/ H& G6 C3 {% u3 X* Z5. pcb尺寸:100*79 mm
+ n) W3 ^; Y7 k  V3 R作品截图如下:: _  K7 K6 C4 v6 i7 G% z3 w& M# v" H
- |* p0 f0 x6 r/ Q5 S' U2 X
顶层截图:1 @- y% j8 p& @  r0 t4 s! ]
  Q- N" [4 r- ]0 H1 r) M4 s
4 m7 j+ |2 D7 e, N# r, [3 J: W
$ \1 l# S6 g* B* r- {
0 A, Z! w, g$ s8 X) O* @3 @底层截图:4 u6 W7 f" t' f
2 z  d0 U4 X  z- n
0 h( A# P3 M, E1 Y) S- _; N! i/ P9 D
) G( `5 C! D2 [* l
( ^1 o: n& e  f  `  E全层截图:
: j5 {& {0 \- ~  x1 A& a9 g$ r$ P, Q, w8 u( I/ y3 G% @( g
' N! F0 B3 [* F4 a9 J
# b& s' j  u) s! v& ?  A' A8 I叠层阻抗信息如下:4 O5 {/ m9 z# \' X3 {
& F3 y" k& d$ M# X3 L
- c6 O" c$ O' N( G) f
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402C_0402-0.1UF,X5R,10%,6.3V,039-0007-000-0.1UF,039-0007-0000.1uFDISCRETE73C4; C5; C32; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C51; C55; C56; C60; C62; C64; C65; C66; C67; C72; C73; C74; C75; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C88; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C106; C107; C110; C111; C112; C113; C115; C124; C125; C126; C128; C129; C130; C132; C134; C135; C137; C142; C144; C155; C156; C170; C172; C173; C174
402C_0402-680PF,C0G,5%,50V,035-0296-000-035-0296-000,680PF680pFDISCRETE2C10; C22
402C_0402-0.1UF,X5R,20%,16V,032-0877-000-0.1UF,032-0877-0000.1uFDISCRETE2C12; C24
402C_0402-100PF,C0G,5%,50V,035-0012-000-035-0012-000,100PF100pFDISCRETE4C14; C26; C93; C138
402C_0402-1UF,X5R,10%,6.3V,039-0008-000-039-0008-000,1UF1uFDISCRETE4C30; C31; C33; C35
402C_0402-1NF,X5R,10%,25V,039-0028-000-039-0028-000,1NF1nFDISCRETE1C34
402C_0402-22PF,C0G,5%,50V,035-0023-000-035-0023-000,22PF22pFDISCRETE3C61; C63; C165
402C_0402-4.7PF,C0G,0.25PF,50V,035-0031-000-035-0031-000,4.7PF4.7pFDISCRETE2C89; C91
402C_0402-12PF,C0G,5%,50V,035-0014-000-035-0014-000,12PF12pFDISCRETE2C90; C104
402C_0402-0.22UF,X5R,10%,6.3V,039-0011-000-0.22UF,039-0011-0000.22uFDISCRETE8C116; C117; C118; C119; C120; C121; C122; C123
402C_0402-10NF,X5R,10%,16V,039-0024-000-039-0024-000,10NF10nFDISCRETE4C133; C136; C154; C169
402C_0402-10PF,C0G,5%,50V,035-0011-000-035-0011-000,10PF10pFDISCRETE1C175
402C_0402-0.7PF,C0G,0.1PF,50V,035-0203-000-0.7PF,035-0203-0000.7pFDISCRETE8C177; C178; C179; C180; C181; C182; C183; C184
402R_0402-0OHM,0.05 OHM,62.5MW,195-2655-000-0OHM,195-2655-0000ohmDISCRETE55R1; R2; R15; R23; R32; R41; R42; R44; R45; R46; R47; R77; R78; R79; R80; R81; R82; R83; R84; R91; R95; R120; R133; R134; R148; R149; R150; R167; R169; R185; R186; R187; R188; R189; R190; R191; R202; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R225
402R_0402-47K,5 %,62.5MW,195-0599-000-195-0599-000,47K47kDISCRETE20R3; R4; R5; R6; R8; R10; R94; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R113; R114; R180
402R_0402-1.8K,5 %,62.5MW,195-0528-000-1.8K,195-0528-0001.8kDISCRETE3R7; R63; R64
402R_0402-10K,5 %,62.5MW,195-0486-000-10K,195-0486-00010kDISCRETE24R9; R13; R37; R40; R59; R60; R65; R76; R93; R123; R124; R126; R127; R128; R129; R130; R131; R132; R135; R174; R199; R200; R201; R223
402R_0402-1.6K,5 %,62.5MW,195-0521-000-1.6K,195-0521-0001.6kDISCRETE2R11; R12
402R_0402-10K,1 %,62.5MW,195-0004-000-10K,195-0004-00010kDISCRETE13R14; R137; R139; R141; R163; R164; R183; R184; R195; R198; R224; R227; R228
402R_0402-18.2K,1 %,62.5MW,195-0130-000-18.2K,195-0130-00018.2kDISCRETE2R17; R25
402R_0402-100OHM,1 %,62.5MW,195-0002-000-100OHM,195-0002-000100ohmDISCRETE3R18; R26; R176
402R_0402-127K,1 %,62.5MW,195-0056-000-127K,195-0056-000127kDISCRETE1R19
402R_0402-22.1K,1 %,62.5MW,195-0170-000-195-0170-000,22.1K22.1kDISCRETE1R20
402R_0402-47.5K,1 %,62.5MW,195-0330-000-195-0330-000,47.5K47.5kDISCRETE2R21; R29
402R_0402-90.9K,1 %,62.5MW,195-0465-000-195-0465-000,90.9K90.9kDISCRETE1R27
402R_0402-27.4K,1 %,62.5MW,195-0215-000-195-0215-000,27.4K27.4kDISCRETE1R28
402R_0402-309K,1 %,62.5MW,195-0241-000-195-0241-000,309K309kDISCRETE1R30
402R_0402-100K,1 %,62.5MW,195-0005-000-100K,195-0005-000100kDISCRETE30R31; R36; R38; R48; R49; R74; R75; R87; R88; R89; R90; R117; R118; R119; R121; R125; R138; R144; R166; R170; R177; R179; R181; R182; R192; R193; R196; R197; R203; R204
402R_0402-1M,5 %,62.5MW,195-0488-000-195-0488-000,1M1MDISCRETE3R33; R116; R194
402R_0402-6.19K,1 %,62.5MW,195-0384-000-195-0384-000,6.19K6.19kDISCRETE1R35
402R_0402-130K,1 %,62.5MW,195-0061-000-130K,195-0061-000130kDISCRETE1R50
402R_0402-499OHM,1 %,62.5MW,195-0338-000-195-0338-000,499OHM499ohmDISCRETE9R51; R52; R53; R54; R55; R56; R57; R58; R136
402R_0402-32.4K,1 %,62.5MW,195-0250-000-195-0250-000,32.4K32.4kDISCRETE1R61
402R_0402-162K,1 %,62.5MW,195-0106-000-162K,195-0106-000162kDISCRETE1R62
402R_0402-5.6OHM,5 %,62.5MW,195-0609-000-195-0609-000,5.6OHM5.6ohmDISCRETE9R66; R67; R68; R69; R70; R71; R72; R73; R205
402R_0402-5.1K,5 %,62.5MW,195-0605-000-195-0605-000,5.1K5.1kDISCRETE2R85; R86
402R_0402-24.9K,1 %,62.5MW,195-0195-000-195-0195-000,24.9K24.9kDISCRETE1R92
402R_0402-20K,1 %,62.5MW,195-0150-000-195-0150-000,20K20kDISCRETE2R115; R175
402R_0402-4.7K,5 %,62.5MW,195-0598-000-195-0598-000,4.7K4.7kDISCRETE2R122; R140
402R_0402-34K,1 %,62.5MW,195-0260-000-195-0260-000,34K34kDISCRETE1R142
402R_0402-110OHM,5 %,62.5MW,195-0492-000-110OHM,195-0492-000110ohmDISCRETE2R146; R165
402R_0402-120OHM,5 %,62.5MW,195-0499-000-120OHM,195-0499-000120ohmDISCRETE1R147
402R_0402-1OHM,1 %,62.5MW,195-2682-000-195-2682-000,1OHM1ohmDISCRETE1R171
402R_0402-147K,1 %,62.5MW,195-0086-000-147K,195-0086-000147kDISCRETE1R172
402R_0402-61.9K,1 %,62.5MW,195-0385-000-195-0385-000,61.9K61.9kDISCRETE1R173
402R_0402-121K,1 %,62.5MW,195-0046-000-121K,195-0046-000121kDISCRETE1R178
402R_0402-91K,5 %,62.5MW,195-0648-000-195-0648-000,91K91kDISCRETE1R226
603C_0603-1UF,X5R,20%,25V,032-0882-000-032-0882-000,1UF1uFDISCRETE4C6; C8; C20; C168
603C_0603-4.7UF,X5R,20%,6.3V,032-0886-000-032-0886-000,4.7UF4.7uFDISCRETE6C7; C19; C36; C76; C127; C158
603C_0603-10UF,X5R,20%,6.3V,039-0135-000-039-0135-000,10UF10uFDISCRETE10C52; C58; C87; C108; C109; C114; C163; C164; C166; C167
603C_0603-0.1UF,X5R,10%,25V,039-0044-000-0.1UF,039-0044-0000.1uFDISCRETE1C171
603R_0603-0OHM,0.05 OHM,0MW,195-1765-000-0OHM,195-1765-0000ohmDISCRETE7R106; R107; R110; R111; R151; R152; R153
805C_0805-22UF,X5R,20%,25V,032-1308-000-032-1308-000,22UF22uFDISCRETE6C9; C11; C21; C23; C152; C153
805C_0805-22UF,X5R,20%,6.3V,039-0127-000-039-0127-000,22UF22uFDISCRETE8C15; C16; C27; C28; C148; C149; C150; C151
805C_0805-4.7UF,X5R,10%,10V,039-0152-000-039-0152-000,4.7UF4.7uFDISCRETE1C38
805C_0805-4.7UF,X5R,10%,25V,032-1141-000-032-1141-000,4.7UF4.7uFDISCRETE1C143
805R_0805-3.3OHM,5 %,0.125W,195-1602-000-195-1602-000,3.3OHM3.3ohmDISCRETE2R16; R24
CAP_SMD_3528C_POL_SMD_3528-330UF,TA-POLYMER,20%,6.3V@85DEGC,0.04OHM,9.999UH,0.855A@85DEGC,100KHZ,032-0696-000-032-0696-000,330UF330uFDISCRETE6C105; C145; C146; C147; C157; C160
CON_BATTERY_003_SMD_ST_F_132X121CON_BATTERY_SMD_3PIN-3000TR,FEMALE,N/A,N/A,YES,NO,NO,NO,YES,N/A,N/A,220-0146-000-220-0146-000IO1J3
CON_FFC_030_SMD_ST_F_P010_ZIFCON_FPC_15_SMD15_TE-1-1734248-5,FEMALE,1MM,0,YES,YES,[ ],NO,NO,N/A,N/A,080-1669-000-080-1669-000IO2J1; J9
CON_HDMI_019_DP_020_TH_RA_F_181X180_BCON_HDMI_DISPLAYPORT_DP_HDMI_TH-2HE1700-000111F,FEMALE,1.4MM,90,YES,YES,YES,YES,YES,40 MV,500 MA,064-0374-000-064-0374-000IO1J8
CON_HDR_001X002_TH_ST_M_P025HDR_1X2_NORM-HDR_1M2,MALE,2.54MM,0,NO,NO,NO,250V,3A,074-0117-000-074-0117-000IO1J18
CON_HDR_001X004_TH_RA_M_P025_BHDR_1X4_NORM-AC2100-0011-001-HH,MALE,2.54MM,0,NO,N/A,NO,500VAC,3A,074-0245-000-074-0245-000IO1J17
CON_HDR_001X004_TH_ST_M_P025HDR_1X4_NORM-HDR_1M4,MALE,2.54MM,0,NO,N/A,NO,500VAC,3A,074-0062-000-074-0062-000IO1J19
CON_HDR_001X012_TH_RA_M_P025HDR_1X12_NORM-G2100CE04C-016-H,MALE,2.54MM,90,YES,NO,NO,125 V,3 A,074-0239-000-074-0239-000IO1J14
CON_HDR_002X020_TH_ST_M_P025_BHDR_2X20_NORM-27-0169H-220-1G-H,MALE,2.54MM,0,YES,NO,NO,1000 V,3 A,074-0221-000-074-0221-000IO1J12
CON_MINIPEX_067_SMT_RA_M2_KEYE_CCON_M2_PCI_EXP_SMD67_KEYE-APCI0534-P017H06,FEMALE,0.5MM,90,YES,NO,NO,NO,NO,50 V,0.5 A,080-1761-000-080-1761-000IO1J10
CON_MINIPEX_075_SMT_RA_M2_KEYMCON_M2_PCI_EXP_SMD77_KEYM-SM3ZS067U215AM,N/A,0.5MM,90,YES,NO,N/A,N/A,NO,50V,0.5A,080-1743-000-080-1743-000IO1J11
CON_MISC_004_TH_ST_M_P013_WTBCON_B2W_1X4_TH-50275-00471-003,MALE,1.25MM,0,YES,YES,NO,NO,N/A,NA,NA,064-0267-000-064-0267-000IO1J13
CON_PWR_003_TH_RA_145X090_CCON_PWR_JACK_CON_3PIN-2DC-0005B206F,FEMALE,N/A,90,NO,YES,N/A,N/A,NO,24 V,5 A,064-0437-000-064-0437-000IO1J16
CON_RJ45_018_TH_RA_F_2LEDCON_RJ45_RJ45_POE-A70-112-331N126,FEMALE,1.27MM,90,NO,YES,YES,YES,YES,54 V,600 MA,064-0373-000-064-0373-000IO1J15
CON_SODIMM_260_SMT_RA_F_P005CON_SODIMM_260_CON_SODIMM260_JETSON_NANO-2309413-1,FEMALE,0.5MM,90,N/A,N/A,YES,NO,NO,25 V,0.5 A,080-1656-000-080-1656-000IO1J2
CON_USB3_024_SMT_RA_F_138X174CON_USB3_TYPEA_27PIN-G3509CE04C-008-H,RECEPTACLE,2MM,90,YES,YES,YES,NO,YES,30V,1.8 A,065-0738-000-065-0738-000IO2J6; J7
CON_USB_005_SMT_RA_080X066CON_USB_MICRO_B-2UB2141-000111F,FEMALE,0.65,90,YES,YES,YES,NO,YES,500.0 V,500.0 MA,080-1368-000-080-1368-000IO1J5
DFET_003_SMD_010X006_BQ_FET_N_ENH_DFN1006-DMN26D0UFB4,20V,999MOHM@10V / 3000MOHM@4.5V / 4000MOHM@2.5V,0.14A,0.805A,10V,0.35W,999NC@10V / 0NC@4.5V / BDISCRETE16Q1; Q8; Q11; Q13; Q17; Q18; Q20; Q21; Q30; Q31; Q32; Q33; Q34; Q35; Q36; Q37
DFET_003_SMD_010X006_BQ_NPN_DFN1006-MMBT3904LP-7,40V,0.3V,0.2A,9999A,6V,0.25W,300-0869-000-300-0869-000DISCRETE1Q14
DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V / 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / [ ]@2.5V,BDISCRETE1Q25
DFN06_P050_016X012U_DCDC_BUCK_MP2152_QFN6-MP2152,BUCK,1PH,1.1MHZ,NONE,0.6V..5.5V,1.5%,0.6V,5.5V,2A,2W,316-0758-000-0.6V,316-0758-0000.6VIC1U26
DFN08_P040_018X012U_LEVSHFT_TXB0302_DFN8-TXB0302DQMR,LEVEL SHIFTER,115-2177-000-115-2177-000IC1U16
DFN08_P050_030X020_T016X016U_MEM_EE_I2C_DFN08-1MHZ,1.7V..3.6V,AT24C02D-MAHM-T,174-0159-000-174-0159-000IC1U17
DIODE_SMD_010X060D_ESD_NORM-TPD1E10B06,1 LINE,BI-DIRECTIONAL,5.5V,0.1UA,6V,10V@1A,12PF,090-0243-000-090-0243-000DISCRETE7D1; D2; D3; D18; D46; D48; D49
DIODE_SMD_010X060D_ESD_NORM-LESD5VD8LCG-R,1 LINE,BI-DIRECTIONAL,5V,0.05UA,5.5V,10V@2A,1.2PF,090-0172-000-090-0172-000DISCRETE26D6; D7; D16; D17; D24; D25; D26; D27; D28; D29; D30; D31; D32; D33; D34; D35; D36; D37; D38; D39; D40; D41; D42; D43; D44; D45
DIODE_SMD_010X060D_ESD_SLP_2PIN-RCLAMP2431T.TCT,1 LINE,BI-DIRECTIONAL,24V,0.1UA,26.7V,45V@1A,0.5PF,090-0337-000-090-0337-000DISCRETE1D20
DIODE_SMD_025X013D_ESD_MICROSMP-MSP5.0A-M3/89A,1 LINE,UNI-DIRECTIONAL,5V,100UA,6.4V,9.2V@16.3A,9.999NF,090-0233-000-090-0233-000DISCRETE1D5
DIODE_SMD_025X013D_ESD_MICROSMP-MSMP20A-M3/89A,1 LINE,UNI-DIRECTIONAL,24.5V,1UA,22.2V,42.8V@23.4A,102PF,090-0378-000-090-0378-000DISCRETE1D64
DIODE_SMD_SOD123D_SCHOTTKY_SOD-123-LS34SG,SINGLE,40V,25A,0.38V@1A,3A,090-0155-000-090-0155-000DISCRETE1D4
DIODE_SMD_SOD323_CD_ZENER_SOD323-DDZ22BSF-7,21.71V,5MA,0.9V@10MA,0.5W,090-0377-000-090-0377-000DISCRETE1D65
DIODE_SMD_SOD523_BD_ZENER_SOD523-BZT52C3V3T,3.5V,5MA,0.9V@10MA,0.3W,090-0343-000-090-0343-000DISCRETE1D66
IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-90OHM,[ ],25%,0.2A,0.4OHM,[ ],102-0037-000-102-0037-000,90OHM90ohmDISCRETE12L1; L2; L8; L10; L20; L21; L22; L23; L24; L25; L26; L27
IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-12OHM,[ ],25%,0.1A,1.5OHM,MCZ1210DH120L2TA0G,102-0066-000-102-0066-000,12OHM12ohmDISCRETE4L15; L16; L17; L18
IND_NONRKO_SMD_025X020L_2520-1UH,METAL ALLOY,20%,3.2A,3.8A,0.042OHM,[ ]@[ ],[ ],130-0562-000-130-0562-000,1UH1uHDISCRETE1L19
IND_NONRKO_SMD_071X065L_SMD_7X7-1UH,IRON POWDER CORE,20%,14A,14.4A,0.0065OHM,0@0HZ,3MHZ,130-0996-000-130-0996-000,1UH1uHDISCRETE2L3; L5
IND_NONRKO_SMD_073X066L_SMD_073X066-1UH,CARBONYL POWDER,20%,11A,22A,0.01OHM,[ ]@[ ],[ ],130-0776-000-130-0776-000,1UH1uHDISCRETE2L4; L6
IND_SMD_0201_BL_0201-4NH,CERAMIC,2.5%,0.35A,0.35A,0.4OHM,14@500MHZ,5.3GHZ,130-1369-000-130-1369-000,4NH4nHDISCRETE8L28; L29; L30; L31; L32; L33; L34; L35
IND_SMD_0402L_0402-1NH,MULTI-LAYER,30%,0.4A,0.4A,0.07OHM,8@100MHZ,10GHZ,130-1041-000-130-1041-000,1NH1nHDISCRETE1L14
LED_SMD_0603_ST_CLED_0603_B-APT1608-NVD17,5V,0.15A,4V,30MA,WHITE,092-0160-000-092-0160-000DISCRETE1DS1
LTPB071C125D045C025PLABTESTPOINT_PIN-LTPB071C125IO28TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42
LTPT089C125DLABTESTPOINT_PIN-LABTESTPOINTIO4TP9; TP10; TP11; TP12
MECH_RECT_01000X00790_HOLES_BMOUNTING_HOLE_X2-P3509_MOUNTING_HOLEIO1MEC3
MEC_STANDOFF_PTH_620C380PMEC_STANDOFF_SMD-SMD MECH STDF_035MM,155-0879-000-155-0879-000IO2MEC1; MEC2
MULTI_SMD_DFN08_SON08Q_FET_N_ENH_DFN3X3-NTTFS4C25N,30V,17MOHM@10V / 26.5MOHM@4.5V / [ ]@2.5V,12.2A,81A,20V,1.63W,10.3NC@10V / 5.1NC@4.5V / [ ]@2.5VBDISCRETE2Q4; Q6
MULTI_SMD_DFN08_SON08Q_FET_N_ENH_DFN3X3-NTTFS4C06NTAG,30V,4.2MOHM@10V / 6.1MOHM@4.5V / [ ]@2.5V,18A,166A,20V,2.16W,26NC@10V / 11.6NC@4.5V / [ ]@2.5BDISCRETE2Q5; Q7
QFN010R_P040_0018X0014U_SW_ANA_USB_UQFN10-TS3USB30E,SWITCH - ANALOG,115-0655-000-115-0655-000IC1U11
QFN020Q_P050_0030_T018X018U_CPU_EFM8SB1_QFN20-EFM8SB10F2G,OTHER,115-2594-000-115-2594-000IC1U18
QFN020R_P050_0045X0035_T031X021_VIASU_LEVSHFT_TXB0108_QFN20-TXB0108RGYR,LEVEL SHIFTER,115-1921-000-115-1921-000IC3U12; U13; U14
QFN088Q_P040_0100_T069X069U_USB_HUB_RTS5489_QFN88-RTS5489-GR,USB,115-2752-000-115-2752-000IC1U7
SC70_5U_BUF_OD_SC70_5-74LVC1G07GW/SN74LVC1G07DCKRE4,BUFFER - OPEN DRAIN,115-0138-000-115-0138-000IC2U1; U19
SC70_5U_LEVSHFT_3STATE_SC70_5-SN74LV1T125,LEVEL SHIFTER,115-2747-000-115-2747-000IC3U22; U23; U27
SC70_6Q_FET_N_ENH_SOT363-NTJD4001N,30V,1500MOHM@10V / 1500MOHM@4.5V / 1500MOHM@2.5V,0.25A,0.25A,20V,0.272W,[ ]@10V / [ ]@4.5V / [ ]@BDISCRETE1Q12
SC70_6Q_PNP_SOT363-NST45010MW6T1G,-45V,-50V,-0.1A,-0.1A,-5V,0.1MW,300-0906-000-300-0906-000DISCRETE1Q24
SC70_6U_SW_LOAD_SOT363-GS7616SC-R,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1566-000-115-1566-000IC1U8
SC70_6U_LEVSHFT_3STATE_SC70_6-SN74LVC1T45DCKR,LEVEL SHIFTER,115-2544-000-115-2544-000IC1U15
SO08_048X038U_MEM_FL_SER_512KX8_SO_8-104MHZ,2.3V..3.6V,W25X40CLSNIG,170-0285-000-170-0285-000IC1U28
SOT23_5U_VREG_5PIN_SOT235-TLV70018,LOW DROP OUT/FIXED,0.25V@0.2A,1.8V..1.8V,2%,[ ],5.5V,0.2A,0.5W,315-0620-000-315-0620-000,[ ][ ]IC1U5
SOT23_5U_LDO_SOT23_5_NOVR-GS7116S5-ADJ-R,STANDARD,0.45V@0.5A,0.8V..5V,2%,0.8V,6.5V,0.5A,0.4W,315-1022-000-0.8V,315-1022-0000.8VIC1U6
SOT23_5U_PWR_SW_UL_SOT23_5_EFU-APL3552ABI-TRG,2.7V..5.5V,2.7V..5.5V,2A,SWITCH,315-1062-000-315-1062-000IC2U9; U10
SOT23_5U_RST_MON_TSOP_5-NCP301LSN20T1,VOLTAGE SUPERVISOR,115-2146-000-115-2146-000IC1U24
SOT23_5_BU_SW_LOAD_SOT23_5B-AP22811AW5-7,0MV..5.5V,2.7V..5.5V,9999A,SWITCH,115-2766-000-115-2766-000IC2U21; U25
SOT323D_3PIN_CC_SOT323-BAS70W-05,1 PAIR - COMMON CATHODE,70V,0.1A,1V@15MA,70MA,091-0023-000-091-0023-000DISCRETE1D15
SOT323D_3PIN_CC_SOT323-BAT54CW,1 PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0022-000-091-0022-000DISCRETE2D62; D63
SOT323Q_FET_P_ENH_SOT323_1G1D1S-NTS4101PT1G,-20V,0MOHM@10V / 120MOHM@4.5V / 160MOHM@2.5V,-1.37A,-4A,8V,0.329W,[ ]@10V / 9NC@4.5V / [BDISCRETE1Q23
SOT323Q_FET_P_ENH_SOT323_1G1D1S-BSS84W-7-F,-50V,-1000MOHM@10V / -1000MOHM@4.5V / -1000MOHM@2.5V,-0.13A,[ ],20V,0.2W,[ ]@10V / [ ]@4.BDISCRETE1Q28
SOT323Q_FET_N_ENH_SOT323_1G1D1S-2N7002_SERIES,60V,13500MOHM@10V / 7500MOHM@4.5V / [ ]@2.5V,0.115A,0.8A,20V,0.15W,[ ]@10V / 0.5NC@4.5BDISCRETE1Q29
SOT323_DQ_NPN_SOT323_1B1C1E-3904_SERIES,40V,0.3V,0.2A,0.2A,6V,0.15W,300-1128-000-300-1128-000DISCRETE2Q15; Q16
TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2 DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000IO11D8; D9; D10; D11; D12; D13; D14; D19; D21; D22; D23
VIRTUAL_SHORTVIRTUAL_SHORT_SHUNT-VIRTUAL_SHORTDISCRETE16VS1; VS2; VS3; VS4; VS5; VS6; VS7; VS8; VS9; VS10; VS12; VS13; VS16; VS17; VS18; VS19
XSOP10_P050_030X030U_SWREG_TPS53015_XSOP10-TPS53015,BUCK,1PH,500KHZ,NONE,0.77V..7V,1%,0.773V,28V,10A,50W,316-0314-000-0.773V,316-0314-0000.773VIC2U3; U4
XTAL_SMD_4_032X025_DXTAL_4PIN_SMD_32X25-7M12070053,12MHZ,15PPM,2PPM,35PPM,10PF,FUNDAMENTAL,085-0347-000-085-0347-000,12MHZ12MHzDISCRETE1Y1
XTAL_SMD_4_032X025_DOSC_4PIN_SMD_32X25-7XZ3270027,32.768KHZ,25PPM,5PPM,25PPM,15PF,086-0282-000-086-0282-000,32.768KHZ32.768KHzDISCRETE1Y2
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
推荐
发表于 2023-9-13 14:33 | 只看该作者
666666666666666666666
推荐
发表于 2022-3-1 11:45 | 只看该作者
jetson_Xavier_NX_A01, s$ V+ E) V+ I# w0 E' p4 X: G1 D
推荐
发表于 2021-6-15 16:46 | 只看该作者
发表于 2021-7-28 12:30 | 只看该作者
谢谢楼主分享。。
发表于 2021-8-28 20:41 | 只看该作者
学习一下
“来自电巢APP”
    2025-8-18 15:04
  • 签到天数: 570 天
    [LV.9]以坛为家II
    发表于 2021-9-2 16:05 | 只看该作者
    下载,学习一下。
    奋斗
    2025-6-9 15:24
  • 签到天数: 337 天
    [LV.8]以坛为家I
    发表于 2021-9-7 17:38 | 只看该作者
    下载研究学习内容
    发表于 2022-2-24 19:48 | 只看该作者
    谢谢楼主的热心分享8 w# ~8 H! L0 i/ ~$ a
    发表于 2022-3-11 13:27 | 只看该作者
    不错不错
    “来自电巢APP”
    2022-4-26 15:59
    发表于 2022-4-26 15:58 | 只看该作者
    感謝您的無私奉獻!
    13#
    发表于 2022-7-26 17:04 | 只看该作者
    多谢分享,谢谢楼主
    2022-1-3 15:25
  • 签到天数: 9 天
    [LV.3]偶尔看看II
    14#
    发表于 2022-7-26 22:30 | 只看该作者
    正需要学习,感谢分享
    15#
    发表于 2022-7-28 11:41 | 只看该作者
    谢谢分享,已经收藏
    GMT+8, 2025-8-19 18:13 , Processed in 0.187500 second(s), 29 queries , Gzip On.
