查看: 767|回复: 2
電源符號
发表于 2021-6-9 21:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  ]0 S1 ?8 ~3 `1 ^, H. K* ]1 t+ b
( [8 H9 ?: ]+ G. g5 l! hPCB Net List Errors Report - Modbus0604.sch - Wed Jun 09 21:47:46 20215 K9 f' y* f3 L) b) b
- x$ E' Y/ a6 g  V# x+ \' b( M4 LDesign to Library Part Consistency Check0 x3 T6 u- \+ [* y( @5 O' U% }
----------------------------------------% ]0 w! P$ n  ]& t! b" \* b( ^
No Library consistency checking errors.
7 y1 ?; p; T. ?- }" D
$ g" U+ Q  l$ C! ^0 N+ hSingle/Zero Pin Net Warnings
$ s  J4 A* J. n6 B' @# Q----------------------------
! M3 d6 F: f2 H9 C$ q5 RNo single or zero pin nets.* R$ {) Z) y) @: k6 b
  S9 b9 ^& U* R2 |& O$ QSchematic Connectivity Errors0 g  I" g6 x. R
' S$ T( v' @: D4 b) q1 R. ?  g3 c- D% K% B* N3 U5 I; z* K! d
Power or Ground Symbols used with wrong Net Name
0 b2 u) G9 G  p* b4 _8 z! @  J5 U+ ~) K
+12V2 q; A- F" ~. G  G8 U) c
POWER        X1720  Y5600  - Power  Symbol used for net: +5V: w2 h7 H5 X7 d9 D$ D+ n
POWER        X7250  Y7450  - Power  Symbol used for net: +5V( N+ C# M* [( H. G- ^2 C
POWER        X15580 Y6470  - Power  Symbol used for net: +5V# R' [3 v$ w% R( n/ L. d
POWER        X7680  Y6980  - Power  Symbol used for net: +5V$ f6 C0 C+ F. T5 m
POWER        X6070  Y4720  - Power  Symbol used for net: +5V  l8 o3 |3 e1 c; F9 \# H( F7 X$ K0 _
! M+ y1 L# ~: z1 v
+3V34 o$ }4 D. n  r6 \/ C5 d3 t( q: `: @
POWER        X5470  Y3050  - Power  Symbol used for net: +5V! _0 I& b- z/ E9 z7 m
LOAD_DET1    X4450  Y8500  - Power  Symbol used for net: +5V' w4 ~0 H* B9 Y% P
LOAD_DET1    X6600  Y5000  - Power  Symbol used for net: +5V
% N3 p* Y0 `) |' }/ \# w! H. SLOAD_DET1    X4200  Y5100  - Power  Symbol used for net: +5V: p' {# W: w- w* ]) ~
LOAD_DET1    X11050 Y8900  - Power  Symbol used for net: +5V
- C7 }" t( {7 p! O7 PLOAD_DET1    X13200 Y5400  - Power  Symbol used for net: +5V/ ~7 s$ q3 t, }' T) [8 }8 L
LOAD_DET1    X10800 Y5500  - Power  Symbol used for net: +5V. e/ {; C$ x4 s
LOAD_DET1    X13350 Y8200  - Power  Symbol used for net: +5V
+ E! {1 m6 z6 T; n* BLOAD_DET1    X6750  Y7800  - Power  Symbol used for net: +5V
. Q% d0 F! `; l2 yLOAD_DET2    X4500  Y9100  - Power  Symbol used for net: +5V
+ c  k( i9 y  hLOAD_DET2    X6650  Y5550  - Power  Symbol used for net: +5V2 X1 p+ S5 g. V
LOAD_DET2    X4250  Y5650  - Power  Symbol used for net: +5V
5 O) t4 C& r. u8 dLOAD_DET2    X11100 Y8850  - Power  Symbol used for net: +5V$ p/ x6 n" b# I9 Y
LOAD_DET2    X13250 Y5350  - Power  Symbol used for net: +5V
0 i+ p1 w, [' ^- E3 zLOAD_DET2    X10850 Y5450  - Power  Symbol used for net: +5V
2 p+ m% j8 W* F4 n" PLOAD_DET2    X13400 Y8300  - Power  Symbol used for net: +5V
" l" x, O5 ]4 r; k0 @, hLOAD_DET2    X6800  Y8500  - Power  Symbol used for net: +5V
) u3 R" i# I+ q# J& ULOAD_DET3    X5100  Y8700  - Power  Symbol used for net: +5V. M3 L0 [3 o- |& V: ]
LOAD_DET3    X7250  Y5200  - Power  Symbol used for net: +5V3 Q: s: e7 {) c
LOAD_DET3    X4850  Y5300  - Power  Symbol used for net: +5V
, f6 O2 g# e1 D3 H% C' Q+ {LOAD_DET3    X7400  Y8150  - Power  Symbol used for net: +5V5 ]- z/ Z" N6 U; E8 A  b
mcu          X15040 Y5460  - Power  Symbol used for net: +5V: s# _5 Y3 q2 J5 D  l
MCU          X15300 Y7800  - Power  Symbol used for net: +5V
- e& m% P( y+ F6 o7 E! SINTERFACE    X7300  Y9700  - Power  Symbol used for net: +5V
9 I+ l+ @) X% `) K  YINTERFACE    X7300  Y7300  - Power  Symbol used for net: +5V4 z1 v6 o# U4 H9 C! S/ l, k! b" g
# X4 v( h3 x- B9 }
+3V3_MCU- E; h6 H1 j- T) i
POWER        X14160 Y8020  - Power  Symbol used for net: +5V
: ^% ~2 n! o. O+ S5 [, z  W/ KPOWER        X13290 Y8180  - Power  Symbol used for net: +5V- D& x' ~, R1 B; }6 M5 }
MCU          X1450  Y3900  - Power  Symbol used for net: +5V7 q- Q5 y8 }% R9 f  T1 E0 C# h
MCU          X12350 Y5150  - Power  Symbol used for net: +5V
# x) G. L$ X4 HMCU          X1500  Y7550  - Power  Symbol used for net: +5V; S+ U/ @0 y9 q. C3 Z
MCU          X1750  Y2650  - Power  Symbol used for net: +5V, v1 {2 N& t8 [. M+ T' s, Y$ O
MCU          X7250  Y3650  - Power  Symbol used for net: +5V
9 u* d: Z  S3 o: g4 \& I( s  ^MCU          X3600  Y9000  - Power  Symbol used for net: +5V# N7 W% r( ^8 {! h
MCU          X7850  Y7850  - Power  Symbol used for net: +5V' x6 W+ `  s' d
MCU          X1300  Y6450  - Power  Symbol used for net: +5V8 e+ n" R: A  ?4 A. v( l
MCU          X10550 Y5150  - Power  Symbol used for net: +5V
0 z/ U% P6 I" m' ZMCU          X9550  Y4450  - Power  Symbol used for net: +5V
% L2 U- w" J6 ~' k  iMCU          X11450 Y6950  - Power  Symbol used for net: +5V# t* E4 p# x! R8 s3 V
MCU          X13890 Y5460  - Power  Symbol used for net: +5V
6 k9 ^5 L, @& r4 ^- WMCU          X10150 Y9550  - Power  Symbol used for net: +5V
& l; H3 I: J  {MCU          X2050  Y9650  - Power  Symbol used for net: +5V1 ^* P+ d) H: h
OPTION       X4280  Y6330  - Power  Symbol used for net: +5V, W" V1 t% _) Y9 Q5 _
" P3 @* [) y& u* H+5VISO
6 p6 p/ g0 ^) X8 x7 o9 bRS485        X5950  Y7350  - Power  Symbol used for net: +5V
; K' A1 Z+ K& M7 [+ u3 U1 YRS485        X9700  Y6150  - Power  Symbol used for net: +5V* H% o* i/ C0 A- Z" r4 k
RS485        X12950 Y7600  - Power  Symbol used for net: +5V
6 A# S5 X  s1 a& B, CRS485        X3800  Y2600  - Power  Symbol used for net: +5V  }6 `) P/ [* f6 N2 K
& l. k7 {5 `# x* r! \
RP- L; i6 x" ?# d6 H7 x  [
POWER        X2560  Y5630  - Power  Symbol used for net: +5V- |& V1 L' x- A# a4 C
POWER        X8020  Y5290  - Power  Symbol used for net: +5V
: P( e# n; t) y! O4 |RELAY-1      X5100  Y9500  - Power  Symbol used for net: +5V
3 E3 I1 Q# Y3 B: j* o6 pRELAY-1      X5050  Y7600  - Power  Symbol used for net: +5V; E; Z* m" \8 ]4 u
RELAY-1      X11800 Y7800  - Power  Symbol used for net: +5V$ C1 ~; R9 b. y" Y$ R, r$ D
RELAY-1      X11750 Y6100  - Power  Symbol used for net: +5V
+ H. m: M# y* X, _4 WRELAY-1      X5100  Y4650  - Power  Symbol used for net: +5V2 \& J/ f& Y% \
RELAY-1      X5050  Y2950  - Power  Symbol used for net: +5V
; G" E, E( d' L! h' j4 h: SRELAY-2      X10600 Y7950  - Power  Symbol used for net: +5V8 A% C: \; k0 I6 ]2 M* g
RELAY-2      X10550 Y6250  - Power  Symbol used for net: +5V
# N3 Z1 o8 j- p6 e1 ^RELAY-2      X4400  Y8050  - Power  Symbol used for net: +5V
' E  @' d+ f2 v) a2 TRELAY-2      X4350  Y6150  - Power  Symbol used for net: +5V
0 O/ [0 r0 L& |4 w) Q7 R3 n; X# V" d' M
; l/ d3 n3 A2 e9 V0 [; w( ^
9 A+ Z* o# y# E0 n+ g
    2022-12-5 15:37
    发表于 2021-6-10 08:57 | 只看该作者
    你想问什么
     楼主| 发表于 2021-6-10 10:45 | 只看该作者
    這類訊息要
    7 h( A9 u1 {4 i+ [- m如何解決?
    ! B# R) n- F/ ?3 Z9 D& y
    GMT+8, 2025-6-27 09:20 , Processed in 0.093750 second(s), 23 queries , Gzip On.
