( t+ [; n) j0 C. Q' b
在按照《嵌入式linux应用开发完全手册》操作的时候,有一步是输入quilt push -a,但是提示如下:0 r# V) x, p N0 R2 C8 C
The program 'quilt' is currently not instalLED. You can install it by typing:0 @ M$ z2 Y1 x2 a. M. x. A8 G. X! I
sudo apt-get install quilt
- g4 s0 [; H0 Y/ X; g. qquilt: command not found
3 H4 ~5 v; T1 q5 J! ~$ x0 i$ S! V! Q; u" P- x ?$ e+ `
试过 sudo apt-get install quilt,但是提示:9 n6 |# a" t) \( e! Z: b
Err http://cn.archive.ubuntu.com kARMic/main diffstat 1.47-1
2 N9 ~' \& P% R' L7 ~6 F+ M 404 Not Found [IP: 115.28.122.210 80]# q3 t# S, q( ^& i! d q' B
Err http://cn.archive.ubuntu.com karmic/main gettext 0.17-8ubuntu2- _0 V0 m$ ~0 B- M7 i
404 Not Found [IP: 115.28.122.210 80]1 t- _, N! h+ ?, n( ?% {
Err http://cn.archive.ubuntu.com karmic/main quilt 0.46-8ubuntu1
; K" C* o' d, c3 o6 L. D% V [ 404 Not Found [IP: 115.28.122.210 80]
# s' Z6 o( \# y; q" {' D1 cFailed to fetch http://cn.archive.ubuntu.com/ubuntu/pool/main/d/diffstat/diffstat_1.47-1_i386.deb 404 Not Found [IP: 115.28.122.210 80]
! d9 Z- P9 ]/ X1 |/ @0 z& vFailed to fetch http://cn.archive.ubuntu.com/ubuntu/pool/main/g/gettext/gettext_0.17-8ubuntu2_i386.deb 404 Not Found [IP: 115.28.122.210 80]
! d4 a* L3 O4 B& y1 r4 `Failed to fetch http://cn.archive.ubuntu.com/ubuntu/pool/main/q/quilt/quilt_0.46-8ubuntu1_all.deb 404 Not Found [IP: 115.28.122.210 80]7 g8 X2 K0 m- S- _* d! I( g
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?* J" x2 q; g' @
+ y2 V! a; ~$ F; r" u
2 X0 {0 e3 O, ]! ?- N" n& F) w
在网上也搜索过quilt,但是没有安装包,所以请教下这个quilt怎么才能使用,另外请大神推荐几个下载此类软件的网址,谢谢
" F4 _& L1 [ j |
