查看: 1735|回复: 3
二层板改为四层板中的问题
发表于 2011-4-24 10:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟真在将一个二层板改为四层板,用的是altium,添加中间电源plane和地plane怎么将顶层和底层的GND和VCC和这两成连接起来,望高手指点下,谢谢
+ ?3 }: Z; s2 t) O% T+ \
发表于 2011-4-24 10:52 | 只看该作者
打孔后处理内电层
 楼主| 发表于 2011-4-24 11:22 | 只看该作者
回复 huo_xing 的帖子. N+ G* k3 C8 e7 f- X' _- C
/ p+ v! Q2 D- h5 u+ _AD的help文档中有如下一段9 N3 n: S1 ~4 R& \
Special support is also
& Z* ?, x( K: `+ a, Fprovided for connecting 2 R  V4 M8 K6 R. d) d
SMD power pins to * n% }# e) S! Y0 F& c
power plane layers. SMD pads on a net that is connected to a power plane are automatically tagged
, c3 H' G) ^. M3 a2 s; n* Nas connected to the appropriate plane. The autorouter completes the physical connection for these
2 I8 U+ B" {! M! o( K) qpads by placing a fanout – a short track and via which is relief or direct connected to the plane layer.
1 V% }% i" Z4 J' b* _" ^2 ^4 IWhen a net is assigned to a power plane, a small cross will appear at each pad on the net on the
: t. y7 m3 V1 v$ S9 Kappropriate power plane layer.' w  q  t# F: u. j; F5 \! Q1 D& n
这是不是说SMD的地和电源软件自动会将其连接到电源和地层呢还是要自己手工连接呢
5 w* T4 @: G) P1 v, z. ~
2 j: W& b1 v. A/ `) B" R# a* R* D
发表于 2011-4-24 11:44 | 只看该作者
表贴器件要打孔
GMT+8, 2025-9-13 09:43 , Processed in 0.109375 second(s), 24 queries , Gzip On.
