查看: 3874|回复: 0
16.3Netin问题
发表于 2011-4-20 22:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
低版本的线路能用在16.3版本吗?
3 Q" j! P: P& \$ s, eNetin时出以下错误是什么意思啊?$ V7 d" f, V) }) `4 Q3 z. o
#1 Error   [ALG0081] Illegal character "Forward Slash(/)" found in "PCB Footprint" property for component instance U1: SCHEMATIC1, 01- CCD Flex circuit R3 (9.00, 5.20) .! G5 w- h7 {) a! S5 h0 e- h
#2 Error   [ALG0050] Duplicate Pin Name "GND" found on Package RJ213P3AA0PT_3 , U1 Pin Number 19: SCHEMATIC1, 01- CCD Flex circuit R3 (9.00, 5.20). Please renumber one of these./ b4 d; C6 E+ D) b5 ]/ ~+ w
#3 Error   [ALG0031] Pin number missing from Pin "1" of Package C , C2: SCHEMATIC1, 01- CCD Flex circuit R3 (3.60, 5.90). All pins should be numbered.
' h' U$ _  ?- G! g- f/ I#4 Error   [ALG0031] Pin number missing from Pin "2" of Package C , C2: SCHEMATIC1, 01- CCD Flex circuit R3 (3.60, 5.90). All pins should be numbered.0 {) ^3 E6 K0 n1 {6 c2 M5 _
#5 Error   [ALG0031] Pin number missing from Pin "1" of Package C , C3: SCHEMATIC1, 01- CCD Flex circuit R3 (6.00, 7.30). All pins should be numbered.
5 u8 q, I7 Z) d: g4 K#6 Error   [ALG0031] Pin number missing from Pin "2" of Package C , C3: SCHEMATIC1, 01- CCD Flex circuit R3 (6.00, 7.30). All pins should be numbered.; _3 g' s: ~/ q6 I6 @
#7 Error   [ALG0031] Pin number missing from Pin "1" of Package C+ , C4: SCHEMATIC1, 01- CCD Flex circuit R3 (1.90, 7.40). All pins should be numbered.# s. n' ^" R+ `" ]$ }4 y
#8 Error   [ALG0031] Pin number missing from Pin "2" of Package C+ , C4: SCHEMATIC1, 01- CCD Flex circuit R3 (1.90, 7.40). All pins should be numbered.
. c3 @( r7 C$ @- S2 C1 e#9 Error   [ALG0031] Pin number missing from Pin "1" of Package C , C5: SCHEMATIC1, 01- CCD Flex circuit R3 (2.30, 7.40). All pins should be numbered.
1 h8 X4 k  O0 D#10 Error   [ALG0031] Pin number missing from Pin "2" of Package C , C5: SCHEMATIC1, 01- CCD Flex circuit R3 (2.30, 7.40). All pins should be numbered.( s1 L4 J. w3 m# T9 }
#11 Error   [ALG0031] Pin number missing from Pin "1" of Package C , C6: SCHEMATIC1, 01- CCD Flex circuit R3 (8.10, 7.50). All pins should be numbered.
' u5 F3 q2 W& h) q  O1 b/ u/ j+ q: B#12 Error   [ALG0031] Pin number missing from Pin "2" of Package C , C6: SCHEMATIC1, 01- CCD Flex circuit R3 (8.10, 7.50). All pins should be numbered.
4 O+ q/ F6 O6 v#13 Error   [ALG0031] Pin number missing from Pin "1" of Package C+ , C7: SCHEMATIC1, 01- CCD Flex circuit R3 (8.40, 7.50). All pins should be numbered.0 u" u, y  c' b& ~7 i+ s& A
#14 Error   [ALG0031] Pin number missing from Pin "2" of Package C+ , C7: SCHEMATIC1, 01- CCD Flex circuit R3 (8.40, 7.50). All pins should be numbered.7 o) G6 v% y$ J9 d& @
#15 Error   [ALG0031] Pin number missing from Pin "1" of Package CON20_0 , J1: SCHEMATIC1, 01- CCD Flex circuit R3 (0.70, 3.80). All pins should be numbered.
" Q; e; n: L7 M8 X9 I  Z# A1 i4 D#16 Error   [ALG0031] Pin number missing from Pin "2" of Package CON20_0 , J1: SCHEMATIC1, 01- CCD Flex circuit R3 (0.70, 3.80). All pins should be numbered.! R6 r8 ?8 H6 Z  k  E
#17 Error   [ALG0031] Pin number missing from Pin "3" of Package CON20_0 , J1: SCHEMATIC1, 01- CCD Flex circuit R3 (0.70, 3.80). All pins should be numbered.
; @% z' b2 u8 f# Z#18 Error   [ALG0031] Pin number missing from Pin "4" of Package CON20_0 , J1: SCHEMATIC1, 01- CCD Flex circuit R3 (0.70, 3.80). All pins should be numbered.1 c# e, u3 I& r8 o, k5 r% J6 x
#19 Error   [ALG0031] Pin number missing from Pin "5" of Package CON20_0 , J1: SCHEMATIC1, 01- CCD Flex circuit R3 (0.70, 3.80). All pins should be numbered.9 j! B2 q+ `: [7 Q3 g2 D
#20 Error   [ALG0031] Pin number missing from Pin "6" of Package CON20_0 , J1: SCHEMATIC1, 01- CCD Flex circuit R3 (0.70, 3.80). All pins should be numbered.# h% M4 n) f  m, u
#21 Error   [ALG0031] Pin number missing from Pin "7" of Package CON20_0 , J1: SCHEMATIC1, 01- CCD Flex circuit R3 (0.70, 3.80). All pins should be numbered.
+ {9 h# a# D) @+ h8 H. y7 V5 E9 [5 v" U" I
GMT+8, 2025-9-10 19:24 , Processed in 0.109375 second(s), 24 queries , Gzip On.
