PCB Designer's SI GUIDETable of Content ; b* p/ [* b5 I5 L# }( [' ]
Basics of SI___________________________________________________________________5
4 {4 r! i; V; G0 w4 n1.1 When Speed is important? _____________________________________________5
- E3 e$ s+ o4 }8 L9 {1.1.1 Acceptable Voltage and timing values ________________________________5 5 [* v3 F* G) m; \; e! p$ B. ?* j
1.2 Signal Integrity ______________________________________________________5
, [; c3 V' w+ O. }2 [! m1.2.1 Waveform Voltage Accuracy _______________________________________5 6 R2 {& J& c5 X j& ]2 U
1.2.2 Timing_________________________________________________________5
$ i/ q7 [: Z2 l3 A L% i1.3 Speed of currently used logic families ____________________________________5
- K2 a" \$ j/ R0 b1.3.1 Transition Electrical Length (TEL) __________________________________6 / Z# L- B8 B) d0 z" C- [$ P2 Q& O
1.3.2 Critical length ___________________________________________________6
& {0 g) \, @7 @, F2 [" f6 f; p1.3.3 What is Transmission Line? ________________________________________6
& U" c q: P- a4 c- D1.3.4 What is moving in a Transmission line?_______________________________6 / O& l5 }8 _( O; G
1.3.5 Power Plane Definition____________________________________________6 ; X% p; Y7 ?4 |7 V9 `3 J7 J
1.3.6 The concept of Ground ____________________________________________7 ' p$ D8 f+ |: A( b" [7 e
1.4 STRIPLINE circuit with Electromagnetic field _____________________________7 $ v; ?; i9 T- H# X- ]4 B
1.5 RLC Transmission Line Model _________________________________________8
8 w3 ^3 g/ X0 l3 X9 R) ~: d3 Y0 H1.5.1 What is Impedance? ______________________________________________8 5 r" c+ |8 G. c0 q: Q
1.5.2 A Practical impedance equation for microstrip _________________________8 , t. Z) S" E- U k" i
1.5.3 What is relative dielectric constant Er? _______________________________9 0 ]' I4 ~: ~/ y! X( I- D
. d8 _1 r, y" k2 W5 h
& h( g; |( c! u9 ^ F6 p2 g: w |" Q+ z# d$ ~0 C
2 Interconnections for High Speed Digital Circuits _______________________________10 5 u- L. W5 c/ f; N6 E
2.1.1 Summary______________________________________________________10
- \5 E7 t5 u8 D, ~- ?2.2 Examples of dynamic inteRFacing problems _______________________________10
, e0 d8 F1 `" F9 Y" Y2.3 IC Technology and Signal Integrity _____________________________________12 ) B7 L9 Y6 S. q3 O6 X7 Q6 L
2.4 Speed and distance __________________________________________________14 7 {8 |7 P( h+ u% W, K! H; ] P, ^
2.5 Digital signals: Static interfacing _______________________________________15 1 ?1 j* d. w6 p5 S
2.6 Digital signals: Dynamic interfacing ____________________________________16
$ w- L# i9 @! L# q6 r2.7 Review questions ___________________________________________________18
6 D- m, Y* m+ {2 K1 z
" t, {: M, U* A% o- Y$ T, A' H9 \# B6 h; Q( D. Q( S& ^
7 Z& f! x j+ h/ b& T1 n9 U( C3 Interconnection Models____________________________________________________20
) O# {3 h# F2 E7 Z3.1 Summary__________________________________________________________20
) [/ K; ~3 L- K4 r, ]6 h: q) \' z" ^3.2 Reference model for interconnection analysis _____________________________20
5 ^: v( B" [( H- a- E T* V" _3.3 Receiver model_____________________________________________________21
3 F0 r0 v o1 z6 @4 K2 n9 {3.4 RC interconnection model ____________________________________________23
9 b1 I! d: A- ?3 K& |2 ]' V! g3.5 Parameters of the interconnection ______________________________________25
( H+ S& v r+ S4 ]2 x9 p$ ] @" {3.6 Refined models _____________________________________________________26
( X" B8 U L9 }) V! l3.7 Review question ____________________________________________________28 , n1 q3 k' c4 l8 t& s5 k% p
: G+ o* w5 t8 K; x
, m" K V) G! {# |* e' J
& {/ A1 A. W- ^4 Transmission Line Models _________________________________________________31
) U- s/ G* W% S" j. Z( I) d9 B0 R7 {4.1 Summary__________________________________________________________31 4 Z- p' L0 q0 [) A# ~: ?
4.2 Transmission line models _____________________________________________31 : S# J( ^% W2 ~ `1 W( ~( W2 ?; U) ^
4.3 Loss-less transmission lines ___________________________________________32
# ]( Y0 V" Y# u9 [4.4 Critical Length _____________________________________________________34 " _4 G( Z8 C) Y1 H; U, i
4.5 Reference transmission line model______________________________________35
1 f \) @4 ?0 {! q4 _- H6 n6 l, i4.6 Line driving _______________________________________________________36 0 h. ^# ?, M0 h. t9 S
4.7 Propagation and reflected waves _______________________________________37 7 j6 N2 B! a% k
4.8 A sample system____________________________________________________39
' L+ [' d$ d: E9 R, D% {) {5 R4.9 Review questions ___________________________________________________42
4 U% h5 w, q1 t- J0 e/ q, JPCB Designer’s SI Guide Page 2 Venkata & O! L( ]0 S3 d% w( x! _* Y
5 A- D9 ~- j" W- l u7 `7 X
) f( @* u% J- E; C7 L
5 k9 t; z( K" {0 f5 Analysis techniques _______________________________________________________45 9 M: M6 g9 D. G: J8 ]; e3 u- E
5.1 Summary__________________________________________________________45
! g7 H% l) s& p; n5.2 Transmission time and skew___________________________________________45
% t7 ?. _# e, L* L4 p! Z5.3 Effects of termination resistance _______________________________________46
- Q8 c' _ c3 f9 p. i5.4 Lattice diagram _____________________________________________________48
, Q9 P, H X8 P n: c( ?! S; s5.5 Examples of Real Lines ______________________________________________49 ( R# i- ~7 u/ ]. v6 v6 E9 K- b
5.6 Simulation code ____________________________________________________51
+ R, v( J$ J2 M' T) F9 [- M5.7 Examples of results__________________________________________________54
( ^/ ]3 M6 ?" F+ S" r0 e! j, L1 R5.8 Review questions ___________________________________________________55 + Y' b h. k, F" J1 j+ ]: j
0 Y! O+ q k+ @7 u, b! }
. G# Y) b) d: j6 F) Y
7 o, A9 A& _( [: J6 W% ]& f6 Design guide for interconnection ____________________________________________57 & @8 W! L [. R, R
6.1 Summary__________________________________________________________57
0 C. ~8 d4 o4 g+ l9 L6.2 Incident wave switching ______________________________________________57
( G8 m9 i2 L2 S0 M" V6.3 Effects of capacitive loading __________________________________________58
$ o# N" y, [5 `6.4 Termination circuits _________________________________________________59 + `- R9 h& S8 S, `
6.4.1 Passive termination______________________________________________60
0 i( h& m1 A; O" v6.4.2 Low power termination___________________________________________61
- {. Z5 V3 V9 K/ ~% N( b6.4.3 Active low power termination circuit. _______________________________61
8 d/ {" s" l6 k6.5 Driving point-to-point lines ___________________________________________62 5 |7 L9 ?, Z1 t+ Q
6.6 Driving bused lines __________________________________________________64 8 s) A1 T2 g5 Z. W) l
6.7 Design guidelines ___________________________________________________67 / |# r# d/ {! X" A5 j" a! V6 a
6.8 Review questions ___________________________________________________67 |
