查看: 881|回复: 5
光耦的PSpice建模
发表于 2021-3-16 10:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
What are some tips for modeling optocouplers for Pspice?
. j/ f9 }) D1 v4 _% k2 j" |Though Model Editor does not provide a template for either an optocoupler or for a phototransistor, it can beused create components of these models. For example,you can use Model Editor to model the electricalcharacteristics of the input LED of an optocoupler., H( p' y( V* h0 M
In the case of the optocoupler,you need to create a model for a LED input,and also for a single BJTphototransistor output optocoupler.3 m1 X  f2 u8 |  A/ d# x: ?: h
1.LED! o+ Y0 i6 F0 r
To model LED input, fit the forward current vs. voltage curve of the LED, and the LED capacitance curve toa PSpice diode. These curves are available in datasheets.1 Z+ S! n. T0 W2 ]+ N1 [  `
2.CTR curve fit
2 z; t2 e. @9 a5 k: e, R; G( A4 YUse Mathcad or Excel to fit the CTR curve to a polynomial. A polynomial which may work is of the formA*exp(B+Cx).# x. G: E" K( k! K( s3 J
In the sample model shown below, the Gpcg source models the CTR curve. In this case, two regions were fitseparately, the region If<=10mA and the region If>10mA, where If is the LED forward current. The outputcurrent of the Gpcg source is the phototransistor collector current.
6 n( O$ o& E% ^3 i$ X! Z4 h
游客,如果您要查看本帖隐藏内容请回复
: F! r6 b3 f" a! S# p% L: a6 L( i/ W% I  g
    2020-8-28 15:14
    发表于 2021-3-16 10:59 | 只看该作者
    这是纯英文的?
    2025-5-23 15:33
  • 签到天数: 70 天
    [LV.6]常住居民II
    发表于 2021-3-25 10:26 | 只看该作者
    光耦的PSpice建模
    发表于 2021-5-31 14:57 | 只看该作者
    纯英文吗?       # D$ L' H$ V5 ~4 Y2 s- o. M& S# u
    发表于 2021-7-28 10:15 | 只看该作者
    一个具备反馈系统的PWM电源PSPICE仿真模型
    GMT+8, 2025-8-21 19:34 , Processed in 0.125000 second(s), 26 queries , Gzip On.
