环境试验标准
) E% W$ ^8 N7 [/ y& E7 ]1 g" DGB/T2423-95 IEC60068系列 电工、电子产品环境试验 . I/ P! X) R( s. c
ETS 300019系列标准 Environmental conditions and environmental tests for telecommunications equipment
5 m6 B4 C6 U% M4 Q+ APart 1-0:Classification of environmental conditions Introduction( a: m* M9 i: ]0 i1 x5 z
Part 1-1:Classification of environmental conditions Storage
% S1 k; K5 r2 N. R' kPart 1-2:Classification of environmental conditions Transportation
2 Z: B7 h8 U' Y7 L: y9 _Part 1-3:Classification of environmental conditions Stationary use at weather protected locations
; H. x9 R3 Q2 R6 V2 N! M4 [, LPart 1-4:Classification of environmental conditions Stationary use at non-weather protected locations
) \, t! O5 F% ~- _Part 1-5:Classification of environmental conditions Ground vehicle installations8 m* ^/ A( j8 H( S
Part 1-6:Classification of environmental conditions Ship environments2 z$ i; n3 v5 X6 z8 A4 e0 o7 U
Part 1-7:Classification of environmental conditions Portable and non-stationary use. Q3 s! R, d0 `# f, p6 d |
Part 1-8:Classification of environmental conditions Stationary use at underground locations; }6 u2 T, P1 m+ o0 B
Part 2-0:Specification of environmental tests Introduction7 g. Y7 R+ @& K/ ]
Part 2-1:Specification of environmental tests; Storage7 {7 M# X: R) E9 o
Part 2-2:Specification of environmental tests; Transportation& {% W% {6 e, F) t( u- b2 k
Part 2-3:Specification of environmental tests; Stationary use at weather protected locations+ s0 u, ?2 r1 K8 c7 F+ w
Part 2-4:Specification of environmental tests; Stationary use at non-weather protected locations L1 n: c! o, [) D1 n
Part 2-5:Specification of environmental tests; Ground vehicle installations
( _! `8 z4 Q1 L5 RPart 2-6:Specification of environmental tests; Ship environments' n" ]* Y) g2 w" J/ u% x
Part 2-7:Specification of environmental tests; Portable and non-stationary use
5 H: j0 n {+ xPart 2-8:Specification of environmental tests; Stationary use at underground locations " G( e k2 U' o7 o
EMC标准
9 l/ Y, y$ o ?6 g5 o$ } # v L0 b2 q) v- L T
GB/T 17626系列(等同/等效于 IEC61000-4系列及EN61000-4系列)
) V& r7 H% g1 B7 e9 u6 ]抗扰度试验综述8 C& F. I& |& L j
ESD抗扰度% W) L, t0 E. y+ n% [
射频EM场抗扰度
, ?9 f+ x- |, e$ ^脉冲群的抗扰度& `% M2 Z w4 _; Y
浪涌抗扰度% _" S% `6 E0 ?2 {; a. x
射频场感应的传导骚扰抗扰度; N" t% d7 R+ D& @9 _
谐波和谐间波测量
; k1 ]" L, ]2 i- j9 u工频磁场的抗扰度$ [" S. G7 w5 q" L
脉冲磁场的抗扰度
. C( A: |9 W* {" J: r5 o+ |阻尼振荡磁场的抗扰度* x- m( n' O8 B0 ]) f4 t
电压暂降、短时中断和电压变化的抗扰度
3 o/ R+ c: K2 i2 B! i振荡波的抗扰度 3 [. K1 n! q# X( \ d/ V9 L
信息技术设备的抗扰度要求 GB/T 17618 PREN 55024 CISPR 24,1997
; j5 u$ y8 t. M: D- G+ P信息技术设备的发射要求 GB 9254 EN 55022,1992 CISPR 22,1992
( L& d* ~/ \6 yYD/T 968-1998 电信终端设备电磁兼容性限值及测量方法# p# p! h; i7 y& O% W, L) |
YD/T 993-1998 电信终端设备防雷技术要求及试验方法2 H b/ c5 k4 ~0 v
YD 1032-2000 900/1800MHz TDMA数字蜂窝移动通信系统电磁兼容性限值和测量方法 第一部分:移动台及其辅助设备
% b- T% E, O5 q1 e$ @2 D9 AYD 1138-2001 固定无线链路设备及其辅助设备的电磁兼容性要求和测量方法, b/ N4 A+ M* c/ n2 R# W
YD 1139-2001 900/1800MHz TDMA数字蜂窝通信系统的电磁兼容性要求和测量方法 第二部分:基站及其辅助设备) h6 T$ ]% q7 u9 b+ R3 B
YD/T 1103-2001 无绳电话的电磁兼容性要求及测量方法
# I! K/ Y2 Y- nYD/T 1169.1-2001 800MHz数字蜂窝移动通信系统电磁兼容性要求和测量方法 第一部分:移动台及其辅助设备
7 q& j; Q4 G% u, H: m9 k6 N- E8 b1 cYD/T 1169.2-2001 800MHz数字蜂窝移动通信系统电磁兼容性要求和测量方法 第二部分:基站及其辅助设备
. x5 B9 \- p7 A- Z6 o' W7 `4 M; VETS_300279 专用移动无线电的EMC标准
0 V8 U+ |4 A: r( Z& ?ETS_300329 数字无绳电话的EMC要求, c2 @ d$ c9 a9 |. }9 {/ v
ETS_300342 数字蜂窝电话的EMC要求2 B( `. X, {4 G; J: \6 [8 F
ETS_300386 电信网络设备的EMC要求7 n- \2 y6 }/ }8 x+ ?- U
ITU-T K.20 :Resistibility of telecommunication equipment installed in a telecommunications centre to overvoltages and overcurrents
1 t: I- E2 g2 X( nITU-T K.21 :Resistibility of telecommunication equipment installed in customer premises to overvoltages and overcurrents: o* V: T6 Y) S+ R! d& }; K1 E
ITU-T K.44 :Resistibility tests for telecommunication equipment exposed to overvoltages and overcurrents–Basic Recommendation9 x8 J! J, P: P' s) K+ ^
ITU-T K.45 :Resistibility of access network equipment to overvoltages and overcurrents
) i' e2 \. n5 Z/ I( E0 ]* @0 L$ w安全试验标准 & ?1 | V( d0 H# z: d' @
信息技术设备的安全 ICE 60950:1999 GB 4943.2001 |
