查看: 169|回复: 0
ZCC6501兼容SN6501
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2020-12-10 13:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    FEATURES + K2 u6 {3 Y7 \5 e
    APPLICATIONS
    " K; }- L4 `" t& \6 ?, K; {/ Q" l# I. X9 T: \+ K' `* }2 W% ^
    Push-Pull Driver for Small Transformers
    5 ^6 \* e+ g! a* x+ \/ N8 m, Q/ g! ~
    ) h4 O7 z! g' T+ F- i- }! bIsolated InteRFace Power Supply for CAN, RS-3 M0 A8 L2 K- T
    485, RS-422, RS-232, SPI, I2C, Low-Power LAN 8 z5 P- C. ~- t+ p7 m9 n
    3 {/ g- c' d( k+ nSingle 3.3 V or 5 V Supply& a5 z0 i& i8 e# @9 H8 ?5 n
    . w. U6 B0 u& IIndustrial Automation
    1 h6 U' C& C: k" v
    , ^5 q' I3 D, i8 ~High Primary-side Current Drive:
    - P% F+ {/ |; l# F: a- G6 m! @7 F( w
    . W4 C9 }, Y4 d1 u5 ]) SProcess Control
    & b( g/ K2 g6 D: \5 M. t+ q8 k– 5 V Supply: 350 mA (max)
    4 i( K3 n: s; P$ _4 P7 I
    4 i9 v! M/ m# ~3 l0 i- LMedical Equipment 0 L- `- H) t1 @9 E
    – 3.3 V Supply: 150 mA (max)$ P  G. H; v/ t& H+ C! g
    6 n# ]! C2 B9 J- ILow Ripple on Rectified Output Permits Small: G$ x' T( r) I! ]- Y" P
    Output Capacitors
    ) d" w4 l; b* f" z0 s, S4 O8 Z% J7 g+ v/ a$ X/ h: m
    Small 5-pin SOT23 Package( Z4 D( l2 e( c: y0 }+ U% ?( b
    DESCRIPTION
    6 R7 D, D* d# I" f) }The ZCC6501 is a monolithic oscillator/power-driver, specifically designed for small form factor, isolated power
    # x, R0 P/ q+ Qsupplies in isolated interface applications. It drives a low-profile, center-tapped transformer primary from a 3.3 V
    4 f0 l/ y" A6 P, }  O5 ?or 5 V DC power supply. The secondary can be wound to provide any isolated voltage based on transformer
    . g* L: v. @, @4 @4 Y/ J, f0 U( nturns ratio./ x2 S: l& e5 |3 `& ?$ q1 C" e' h
    The ZCC6501 consists of an oscillator followed by a gate drive circuit that provides the complementary output
      n2 G8 J2 c, b8 e+ zsignals to drive the ground referenced N-channel power switches. The internal logic ensures break-before-make
    ( {. r2 B& a# P  q& R' B$ _- l5 M) a4 \action between the two switches.
      L, N" s: ^( [) ~( Q# @The ZCC6501is available in a small SOT23-5 package, and is specified for operation at temperatures from –40°C
    3 q* |+ C% o. h! [- _- rto 125°C
    9 J- W$ U! E0 I ZCC6501(1).pdf (1.21 MB, 下载次数: 0) ! ~7 ]4 `! S& U5 s/ g3 ?
    . l! e- A" Y9 `/ o
    9 f* ^9 {) Q7 }( o! V% k- t
    # c. [2 S6 c$ B+ g! d
    GMT+8, 2025-6-29 01:55 , Processed in 0.078125 second(s), 28 queries , Gzip On.
