查看: 291|回复: 3
CCS5 编译问题
发表于 2020-12-10 13:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
请教报这个错误是少安装了什么文件引起的
"D:\\ti\\ccsv5\\utils\\bin\\gmake" -j 4 -k all
making ../src/sysbios.ae674 ...
'Building file: ../DSP.cfg'
'Invoking: XDCtools'
"C:/ti/xdctools_3_25_03_72/xs"
--xdcpath="D:/ti/bios_6_35_04_50/packages;D:/ti/ccsv5/ccs_base;D:/tI/OMAPL138_StarterWare_1_10_04_01/include/hw;D:/ti/OMAPL138_StarterWare_1_10_04_01/include;D:/ti/ipc_1_25_03_15/packages;D:/ti/syslink_2_21_01_05/packages;F:/DSP_test/MessageQ/share;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p myBoard -r release -c "D:/ti/ccsv5/tools/compiler/c6000_7.4.4" --compileOptions "-g --optimize_with_debug" "../Dsp.cfg"
cle674 D:/ti/bios_6_35_04_50/packages/ti/sysbios/BIOS.c ...
java.lang.NoClassDefFoundError: config/Shell
Caused by: java.lang.ClassNotFoundException: config.Shell
        at java.net.URLClassLoader$1.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(Unknown Source)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
        at java.lang.ClassLoader.loadClassInternal(Unknown Source)
Exception in thread "main" gmake: *** [configPkg/linker.cmd] Error 7
asme674 D:/ti/bios_6_35_04_50/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
asme674 D:/ti/bios_6_35_04_50/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
asme674 D:/ti/bios_6_35_04_50/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
asme674 D:/ti/bios_6_35_04_50/packages/ti/sysbios/family/c64p/Clobber_asm.s62 ...
asme674 D:/ti/bios_6_35_04_50/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
asme674 D:/ti/bios_6_35_04_50/packages/ti/sysbios/family/c64p/MemoryProtect_asm.s64P ...
6 t  Q" M+ J* A/ S6 c2 \/ r
1 ^! p' D. T- a4 ?$ @6 S/ Q
  F9 z* s) A4 F+ E, }, E
. t4 F# E% h" |6 g$ ^3 {% z8 R
发表于 2020-12-10 15:15 | 只看该作者
仔细检查一下步骤
GMT+8, 2025-6-25 07:57 , Processed in 0.093750 second(s), 26 queries , Gzip On.
