查看: 293|回复: 2
模拟MDIO协议,读到数据都是1,大有人模拟过吗,求解答?
发表于 2020-11-23 11:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
模拟MDIO协议,读到数据都是1,大有人模拟过吗,求解答?8 }- ^+ s( l# X+ A; z1 o% u
void delay(void)
7 L) M  W; R6 y2 d2 r{
4 f$ R6 d; U1 S) Y3 s& F0 v$ bdelay_us(1);
- \5 Y+ L% B$ }2 P* D3 @7 b}
' l3 M' V2 }4 s# W) ?3 V4 p( q8 g2 H# m/ W( G+ j1 j
void mdio_init(void)
5 ?9 c. w5 a. V9 q, l4 j{
% i* ?6 u# A3 H, Z, grcu_periph_clock_enable(RCU_GPIOA);
9 ?& P7 y& ^, u, K( m& `3 s3 z8 M/ e    rcu_periph_clock_enable(RCU_GPIOC);2 ?) b6 c+ f# w
//开漏输出
9 S+ n2 [: [  _6 w; x//MDIO---PA2   MDC---PC1
& h: D! }0 l2 M7 L! t6 M" p) B5 ~    gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_2);4 |. h, A* r5 I) [" D  f
    gpio_output_options_set(GPIOA, GPIO_OTYPE_OD, GPIO_OSPEED_200MHZ,GPIO_PIN_2);
. B( Z6 j. h: A
, F. d" J0 o0 m% Ggpio_mode_set(GPIOC, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_1);8 ]* s' `9 B1 `7 t, y. Z+ t' D, S
    gpio_output_options_set(GPIOC, GPIO_OTYPE_OD, GPIO_OSPEED_200MHZ,GPIO_PIN_1);
2 w8 a5 z; c8 |( @- ^' Z3 n+ i# `( H$ H3 \- ^
5 @6 g/ ?4 ^0 K" R3 S/* BCMMDIO_EN---PB14*/! v/ A7 q+ g/ \' [! q
    rcu_periph_clock_enable(RCU_GPIOB);
3 K+ P, k+ T% b' `    gpio_mode_set(GPIOB, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_14);
% B" [" D# g9 s& d( `% k5 O/ Q    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ,GPIO_PIN_14);
9 ^  U! R4 a+ c% O4 m- ?9 o//on---1, off---0
- x( n& Y; b: cgpio_bit_set(GPIOB, GPIO_PIN_14);
8 Z+ y0 U9 y; ]}
+ R- Z; o. k! {#if 0
+ A8 x- x0 q( q+ E; j' j" ^void mdio_init(void)
. j& B/ o+ M; @{
( [4 s; e; X% h; |7 I& _" jrcu_periph_clock_enable(RCU_GPIOA);
4 a8 w3 a! J/ B# I+ V6 v% K) [    rcu_periph_clock_enable(RCU_GPIOC);
$ ^0 H8 d9 r8 \5 e$ X
* F( g" l2 T' G' N0 ^5 K+ B8 |/ p7 P    /* PA2: ETH_MDIO */. [- s. l+ ^1 T" {5 W2 ?! S' y
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_2);7 `$ L2 b. Q$ y0 q
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ,GPIO_PIN_2);% d- A: F0 R7 Q
    gpio_af_set(GPIOA, GPIO_AF_11, GPIO_PIN_2);
+ w- g  N5 \. F" @+ p3 _/* PC1: ETH_MDC */$ d+ s7 r4 R0 B- ^. \1 H
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_1);
* C- I6 u# l# j    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ,GPIO_PIN_1);
* e% x' \7 A6 M2 I9 F* Z    gpio_af_set(GPIOC, GPIO_AF_11, GPIO_PIN_1);: }( Q4 P3 w% }, z# E9 {
& [2 L9 D2 z* D5 }7 g
/* BCMMDIO_EN */- I) ~' Y: f! i3 _, l9 x# Q
    rcu_periph_clock_enable(RCU_GPIOB);. a- u& O2 h- Q0 ]9 v4 O! i
# V& q. O5 U! z/ w) ?3 U    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_14);
/ e( @8 \* A- q7 ?//on---0, off---14 ]; D* U  T7 @$ k/ A6 R
gpio_bit_reset(GPIOB, GPIO_PIN_14);
7 t: t& r2 x& {* |0 x; m$ E7 S}; i! `1 W5 z2 o
#endif: C- T% l6 D! Q/ l8 ]1 X
( s- @1 Z7 [; }8 V3 d# Y/* 设置MDC为输出引脚,在MDC输出时钟之前设置 */
7 T, J: o# M7 P7 Bstatic void MDC_OUT(void)! O/ A* `# a5 a* o9 E
, L- o  Z$ r, i# g+ H4 u" _' K$ pgpio_mode_set(GPIOC, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_1);% w$ O" b' O# R3 E
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ,GPIO_PIN_1);
. Q8 C6 u. x* R# C4 \6 E}5 g/ M$ _/ V+ v/ k0 i% Y
/* 设置MDIO引脚为输出模式 */
* K6 M# `- K* ?& Y- sstatic void mdio_output(void)
: U/ m3 ]  ?. `! K{  C+ p! o+ Q8 b& j" j
MDC_L();
/ o0 e% ~% S  b, O( _. r
. M  B8 `2 U1 U1 I/* PA2 MDIO */3 m  M' o/ s8 W8 @$ j3 N
8 ?0 o! E2 j" Z3 o+ F$ ngpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ, GPIO_PIN_2);) }4 t" @1 ~/ P6 }/ g
. e3 O/ n1 e- r! @* O* t" x9 e2 ~delay_us(1);
* u" U0 ?% l2 K; Y: U% M; @0 I4 i0 F8 f& D8 ]+ J& _
MDC_H();
3 r" D% F9 ]$ C  ~delay_us(1);" z8 J' n: i: ~% [3 a+ P0 r" W
}* F4 r* `) {: u7 \; G- b2 o6 F' l
/* 设置MDIO引脚为输入模式 */
1 x: R! b9 e+ W" U1 fstatic void mdio_input(void)
9 m7 Y9 F9 m) I' m: A; J3 V{
7 M+ D# ?! I8 o) s  L6 jMDC_L();
1 N! \3 k; f, Q9 O7 u/* PA2 MDIO */
0 w- |$ L4 j0 v& q* @& }- f& cgpio_mode_set(GPIOA, GPIO_MODE_INPUT, GPIO_PUPD_NONE, GPIO_PIN_2);
; s% u* f# q- K  S& }5 ^delay_us(1);    0 A1 q1 l4 ?* p. Q$ _
' _& w! w1 t" V' q' Q
MDC_H();
' `3 t5 s8 N4 o/ ], f* Q  \delay_us(1);; Y( o! w1 H( o2 J0 |( c+ D% T( ^
8 |# M9 _% B. K. }$ ?9 _+ O4 b& ~}( p9 d' ]0 L. N- E% r% ^
//set MDC CLK2 T$ q# v4 l& k" W( p8 D3 n: \
void set_mdc_val()' H8 L8 F' q6 D5 ^4 J6 T6 @
{* v0 L3 _9 `" r
MDC_L();, a+ Q. o  I) O9 |
delay_us(1);
, p/ M$ L! L! Q  A1 |* W! W    MDC_H();
6 X  ]4 b) G  Fdelay_us(1);- `9 ]% t) ^6 z3 _
5 c2 s8 U2 V- M//set MDIO val
+ a, ^$ Q4 h# D; F" \/ |void set_mdio_val_bit(uint8_t val)" z# L  P" a7 m9 F# N- ~2 e
{. [4 H6 r5 [# Q+ E6 j
if( (val&0x1) == 0)& ?% w9 i9 h4 i
  gpio_bit_reset(GPIOA, GPIO_PIN_2); . I) I0 M4 ]9 A! r# U
else
% U" b' H6 Q9 @" D3 N7 }4 P  gpio_bit_set(GPIOA, GPIO_PIN_2); ( [  o2 Q% t5 r; s) n9 W
}& \* I$ x6 o$ j* r3 T' P
- g: D& {1 a2 d7 J6 H#if 1; p$ l9 o1 J5 P1 I' ^
/* MDIO发送一个bit的数据,MDIO必须已经被配置为输出 */
! r5 @: W+ v, l& \2 C0 q) zstatic void mdio_bb_send_bit(uint8_t val)) V1 N" }* N3 X4 Q
{ % u# M5 A# u6 X$ \) n6 \
MDC_L();
# @6 E5 J; j& g# W# B1 T
# ^4 o( C; V% d% Z& @/ R8 h( tset_mdio_val_bit(val);
6 p7 [& ?, b8 R4 ?% c% Z- Pdelay_us(1);
; r) R2 i7 _% o3 T; f5 t- n$ g
5 L% i2 Z' w- [7 V) ~    MDC_H();$ N6 S6 K; V- O4 V
delay_us(1);
. J$ [3 l6 ~6 {& a& t
( P4 p( t& c% I3 l1 q* k// set_mdc_val();
! D) H5 t# e; o* F/ l  t}
( V; {  T) D# J! x/*  $ `! H( o- N7 r- V) A
*  MDIO发送一个数据,MDIO 必须被配置为输出模式.   w$ d$ @; j3 u" [
*  value:要发送的数据* B$ y) }, Y7 b3 [8 k% ?# O8 R
*  bits:数据的位数
; ?8 ^$ C! G9 m9 n*/  * V, |( P4 {. B2 P, ]/ P
static void mdio_bb_send_num(unsigned int value ,int bits)
% u7 X  ]9 d$ v, h{; Z" Z# k2 x. x* @& r- n, p* l- e# N
    int i;( O3 l6 X7 ?6 B9 R
1 o% Z4 \- M6 i8 b' k    for(i = bits - 1; i >= 0; i--)3 t: L% t/ d" M" O/ @( {
        mdio_bb_send_bit((value >> i) & 1);: H8 K8 |+ @5 ~! K, y
/ p. p3 {( l4 g' i, n) d3 q/*  MDIO 获取一个bit的数据,MDIO必须已经被配置为输入. */
3 k/ k5 \9 r' p$ ^static int mdio_bb_get_bit(void)
6 z' _# y7 \7 S+ z% z3 r0 @{
4 f9 x9 z1 K; m% O, Z' u0 r    int value;1 n6 n$ j) @5 b7 B0 t
9 F: l0 u, o% Z: `1 s
// set_mdc_val();
! l5 D4 |3 Q# lMDC_L();
+ _4 w: K* \* ^, j1 D- Y! [' ]6 {* @; i- A; f$ x0 L( L+ |: V# X
delay_us(1);
, e3 h3 i% A' A" }+ Yvalue = GET_MDIO();
: }( n2 h; V* J5 x) T& @! @' Z
! W( [2 H" C4 N* b, J  r    MDC_H();
% D6 J7 O1 c8 m- L& D& P8 cdelay_us(1);
# Z& T/ f- U; I/ q- _, F: Q    return value;
7 s  Q, P9 w: r  J. i. h4 q) _}# {% t, d5 W3 A; [$ @8 x
7 z2 c) `* Z! p6 B*  MDIO获取一个数据,MDIO 必须被配置为输入模式.
* d8 ]2 A/ K- n( k5 G*  bits:获取数据的位数
5 v5 a1 _& n8 o" d# j& H*
( F& B3 @  I+ X! p2 X1 P# V*/
/ e1 ~: ]" z3 c9 u7 ?7 ustatic int mdio_bb_get_num(int bits)
7 {$ J0 X0 F1 |! n" _{0 w9 \+ u% ^# u: W. b: [
    int i;; N' d: \8 r- q! }# G/ L
    int ret = 0;
: h2 {% q9 P1 v( v    for(i = bits - 1; i >= 0; i--)
+ w: Y  E: @7 d- d' t2 e) B4 u& J" w    {" ^2 F7 a! p  U  k1 J( n  N
        ret <<= 1;" r: s  o8 E& G
        ret |= mdio_bb_get_bit();
0 h" i, _4 h8 A3 ^( T. p7 V5 s    }9 a4 q  ]& X8 o$ [0 r3 j4 H
    return ret;1 x' A- ]2 |' }# Y! R, J9 N% E' K4 p7 B
}" p* H) i. D8 x" U* u; a) r* @* n
/** `, M# x) `% P
MDIO frame format definitions are shown below:
4 F5 F) a. {9 ~# X) `Preamble = 32-bit 1's (optional)
5 G8 q2 d9 H8 [; R/ nSTART = Start of Frame indicated by 00 pattern
2 ~; \1 j3 y! X1 POP = Opcode (access type)
) f* Z+ Y: |* P! C, I3 R; w– 00: Address
3 W# S3 c1 a5 R# u& ~7 V– 01: Write
) i; o% g5 u2 w! _" i4 |5 G) r– 11: Read
) ^1 Z  X1 M8 T$ }# p– 10: Post read increment address
2 n2 E* k, D4 X0 G' HTA = Turnaround& u* f( n2 H8 V" |
– Z0: Read
8 [7 ~2 ^( _$ a/ r6 f– 01: Write
4 J7 b4 ^. Q0 I$ K' |# fPRTAD = Physical Address (hardwired)
1 O& ?' n6 g8 e3 e# |& NDEVAD = Device Address   R: H6 R1 p7 a7 W
– 00001: PMA/PMD, {! \7 G4 `8 t; e, a0 N6 l6 o
– 00111: AN ' k; U& m5 Y. `1 g9 |" k
Address/Data = 16-bit Address or Data, L) [- [  s+ q: u3 ~. Z) L
*/% i$ |+ f- u. ?' [# ~
/*1 A6 |6 U& K; O$ r6 I) {- n- p
read:, v. Y5 T# i5 E7 H5 A3 N
Frame 1: Address (Opcode = 00, PRTAD = 0, Device Address = 1, Address/Data field = 0x8200)
& f2 C; e* z8 o; E" d6 I" tFrame 2: Read (Opcode = 11 or 10, PRTAD = 0, Device Address = 1, Address/Data field = data read back from 0x8200)
( ?% X3 z4 s5 f* N7 @9 C0 d) J*/
3 {4 l5 U. [2 r& N3 n3 cuint16_t read_data(uint8_t phy, uint8_t dev, uint16_t reg)1 S5 R  t; I3 S. s9 t) [
{5 u' b% t" A7 b7 Y7 `0 ^  r
int ret = 0, i = 0;
7 F9 Z9 W" y+ z  H) _6 Qmdio_output();
# M5 [6 n7 h  f
) x' I0 [; j) p//第一帧数据,先发地址
1 i9 s2 E; T( n! T# i6 R/*发送32bit的1,这个帧前缀域不是必须的,某些物理层芯片的MDIO操作就没有这个域*/5 v) M3 ~% n; Y; z) I/ D
for(i = 0; i < 32; i++)
/ x3 h! Q9 X0 [3 M2 L9 Z  mdio_bb_send_bit(1);
$ |2 N1 r' f" w# n) _, \; D7 J
+ {: B1 }- X$ B( f: `$ s# ^( I//start 00 2 m. m& e7 w& {
mdio_bb_send_num(0x0, 2);
2 a) X+ ]8 W/ o( W//Opcode = 00% m5 o' }3 n8 p2 A( _/ m6 |
mdio_bb_send_num(0x0, 2);  o/ a; \5 I0 ^
//PRTAD---5bit
/ ~& O" G; N. Z* R: m5 z5 ymdio_bb_send_num(phy,5);
# R8 C3 @" e" o+ a//Device---5bit+ f0 j( Q  v: |
mdio_bb_send_num(dev,5);* O! d+ l1 n: V& j6 W- N8 {/ l
//TA---0x01-write---2bit
2 X5 k# ~" L" }* _; W1 B$ t4 s5 Zmdio_bb_send_num(0x1, 2);4 w; g8 a" F& @8 w0 t
//Address---16bit
, M1 e# G' G: w. a) P, }0 kmdio_bb_send_num(reg,16);
% _! R5 a9 V6 Z3 ?7 n0 ?1 h2 N$ o& E% Q0 h
//第二帧数据
% W1 @2 \; l$ Y4 c/*发送32bit的1,这个帧前缀域不是必须的,某些物理层芯片的MDIO操作就没有这个域*/5 G- I4 C/ C# `1 g3 z' u
! X- \/ d6 n! i. d! k  mdio_bb_send_bit(1);
9 Q5 p4 b. X4 ?" a5 x4 h- {- u, ~! C' A0 H
//start 00 0 o" o. C# p/ y. o" W) i+ X8 s3 C0 p
& S$ B/ j& s4 Y0 p: t. J! H* _. b' X//Opcode = 10
! i  B; T. ?" mmdio_bb_send_num(0x10, 2);
0 |9 M! a% U8 n! q$ t% u. }' m//PRTAD---5bit
3 q+ ?' m* @! H1 wmdio_bb_send_num(phy,5);
* U- t1 U+ J3 ^. _8 {7 X* W//Device---5bit; g' n' E. p6 q4 T  e6 e
3 R+ ]1 ]; F, S6 V4 `, H
0 D; ^+ q0 K$ W% {0 bmdio_input();" o! G% i3 {" |( {' w
// //TA---0x00-read---2bit! F5 L, B# K7 |
// mdio_bb_send_num(0x2, 2);
: w" `4 k3 N0 n/ f* ]2 m. ^set_mdc_val();
7 E$ U% y) h4 J) s" A$ a* Y
$ \3 C5 b1 n0 F//get data% O% p$ n* C" ?1 z, g, L8 E
ret = mdio_bb_get_num(16);
) \: i: H$ ]4 |4 ?. N4 f  Z. `/ f9 L( T, q9 V( u: b; K
mdio_output();
% E$ u) E2 x3 `; O6 @// //高阻态4 n3 K  i) M* ^$ u  q
// for(i = 0; i < 32; i++)% K1 ]" x1 V0 U0 f; R9 M2 `! }
//  mdio_bb_send_bit(1);
8 J6 w* O  ]& F1 Z0 `7 L9 u
7 M+ s0 o( M) @# |. ireturn ret;
5 c! @5 `8 _4 }}1 r, Y3 k, \; }2 L4 U1 b9 `6 w
发表于 2020-11-23 13:21 | 只看该作者
是不是管脚定义错了啊
GMT+8, 2025-6-25 19:03 , Processed in 0.078125 second(s), 23 queries , Gzip On.
