) l+ F; p0 k' G& p2 ?5 W! G' M1 g6 Q9 y2 n
RT,集成LP10.3,支持EXP的database了,这两个功能倒是不错~~
! q1 K& a( I" t$ f3 \' I would like to introduce a new feature for pads 9.3 - new CAD libraries and documentation.( R7 k0 l4 S* o ^8 ?: b6 Q; ]2 |7 Y
LP Wizard 10.3 now comes with the PADS 9.3 installation and has a seamless inteRFace with PADS.2 i- b2 e' i$ N* d
LP Wizard home page - www.mentor.com/go/lpwizard G+ T7 q8 I9 x
If you install LP Wizard 10.3 without a license, it will run in "Demo Mode" as a LP Calculator.3 _ q. i1 G2 v8 K. G q2 f
LP Calculator is the most advanced PCB library documentation tool in the industry today.( Z4 C8 D; y8 E3 @
Here are some of the features of the LP Calculator -4 L' K. ] Y: B& |. x! W7 W
- Allows users to auto-generate new land pattern information for parts not in the library
- Has a powerful search engine to quickly find the correct decal name you need for your PCB Layout
- Automatically links to component manufacturer's dimensional datasheets for verification
- Print feature that produces a full datasheet of all component and land pattern dimensions in black & white or full color
- Preferences menu allows the user to change any of the IPC default settings to customize your library creation
- View the Physical Component superimposed on the land pattern to visually see the solder joint goals
- m, q* \8 T9 ?, V' ^! [% Q. T' B! N Here are some training videos to quickly learn how to use the program -
( }5 j/ d7 J6 D" swww.mentor.com/go/lpwizard/tutorials/ U+ X' s2 E, l7 g) }8 z: v
The PADS 9.3 also comes with over 16,400 IPC certified library parts that were built by the LP Wizard.
* M3 F3 A! h4 HHere are the library names and their descriptions - `$ W4 ~" B9 a" l5 H
- BGA7351B - 1,016 popular BGA, LGA, and CGA library parts
- SMM7351B - 1,740 SMD library parts in the Most (Level A) environment w/Oblong & Rectangle pad shape
- SMM7351BR - 1,740 SMD library parts in the Most (Level A) environment w/Rounded Rectangle pad shape
- SMN7351B - 1,740 SMD library parts in the Nominal (Level B) environment w/Oblong & Rectangle pad shape
- SMN7351BR - 1,740 SMD library parts in the Nominal (Level B) environment w/Rounded Rectangle pad shape
- SML7351B - 1,740 SMD library parts in the Least (Level C) environment w/Oblong & Rectangle pad shape
- SML7351BR - 1,740 SMD library parts in the Least (Level C) environment w/Rounded Rectangle pad shape
- THA7251 - 242 PTH library parts in the Most (Level A) environment
- THB7251 - 242 PTH library parts in the Nominal (Level B) environment
- THC7251 - 242 PTH library parts in the Least (Level C) environment
- THP7251 - 242 PTH library parts in the Proportional (Level P) environment
- CNA7251 - 1,001 Connector library parts in the Most (Level A) environment
- CNB7251 - 1,001 Connector library parts in the Nominal (Level B) environment
- CNC7251 - 1,001 Connector library parts in the Least (Level C) environment
- CNP7251 - 1,001 Connector library parts in the Proportional (Level P) environment
0 N1 K! X0 R/ t/ } These IPC / RoHS compliant PCB libraries reside in this new folder -
4 D( x2 ]) H; }5 u$ I$ {$ EC:\mentorGraphics\9.3PADS\SDD_HOME\Libraries\PADS_Layout_Extended_Libraries
' I) R8 P# c* T( PThe LP Wizard comes with a bonus Connector library with over 5,300 popular connectors from 30 different manufacturers.
$ {/ X9 u) D e; qIf you want to learn more about CAD library creation and PCB layout tips & tricks follow my blog that's updated regularly.$ S" X# w! j* D+ [: c% v2 t5 i
"PCB Design Perfection Starts in the CAD Library" - http://blogs.mentor.com/tom-hausherr/& Q) K9 p" R& n
If you missed my webinar presentation - "Create IPC Compliant PADS Libraries with LP Wizard" it's available here -$ w& w' ]. E' @, A( @& T6 D
http://www.mentor.com/products/pcb-system-design/multimedia/ipc-compliant-libraries+ E4 d6 x D/ @1 c9 Q
- q- V5 m4 d, ]$ |: C5 p0 j |
