本来可以转换viewdraw的不知道dx可以不可以1 K; |# x- [) B; Q$ ^
8 q: d! R: p, l, o: t
OrCAD Capture/OrCAD Capture CIS ViewReader0 P) q1 V/ u" y7 I, A+ f3 {3 t4 ]
You can use the Cadence® OrCAD® ViewReader to convert Viewlogic ViewDraw designs in OrCAD Capture or OrCAD Capture CIS versions 7.2, v9, v9.1, v9.2, v9.2.1, 10.X and 15.7.
[) p) Y8 ]7 \. D: y4 v8 m3 ]: Q/ H% `2 W2 R e
If you're an OrCAD Capture 9.2 user, please remember to do the following:3 j% j& v, U* [3 {- [/ G% h$ w
Select the OrCAD Capture v9.10 option on the first installation dialog box. The ViewReader is the same for Release 9.1, 9.2, 9.2.1, 10.X and 15.7
. @1 I5 X$ f0 w( z. [Do not install the ViewReader in your OrCAD Capture directory. The ViewReader contains files that will overwrite files you need to use OrCAD Capture- @9 ~7 Y0 Z L3 i2 x7 _7 Y% @9 x
Download FREE OrCAD ViewReader - 2 MB
, ]( z$ N" s! n0 V' ? Z
/ Y( T9 M- i3 \, w8 phttp://www.cadence.com/products/orcad/pages/downloads.aspx9 B; q- J n% [2 ?# @
7 K; Y# e' v1 S& `" s1 w+ k8 H! p |
