查看: 1212|回复: 1
netin出问题
    2019-11-19 15:48
    发表于 2010-12-5 00:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    netin出现以下问题$ s- c4 M9 o8 e- e+ D# F" Y  O
    & ~& D+ q' a  U
    cadence Design Systems, Inc. netrev 16.2 Sun Dec 05 00:32:39 20102 c" W& z  o7 D% f" Z% g& N* M$ g
    (C) Copyright 2002 Cadence Design Systems, Inc.
    ) l* r& I9 }8 O------ Directives ------
    7 p% L/ `* F0 d1 v0 }( E0 t+ B4 WRIPUP_ETCH FALSE;
    ) a7 @- b+ B- ORIPUP_SYMBOLS ALWAYS;; f+ X* t% m0 u% M" K4 O
    Missing symbol has error FALSE;
    $ A; F$ A# r+ N. CSCHEMATIC_DIRECTORY 'F:/L.R.Town/dev';4 p  r& v' F! p& J9 o* d& m
    BOARD_DIRECTORY '';" Y0 _: B( z4 f. z2 T) G
    OLD_BOARD_NAME 'F:/L.R.Town/pcb/2010_1204f.brd';
    9 M9 [+ m+ i' v9 L) q2 x6 R" j, DNEW_BOARD_NAME 'F:/L.R.Town/pcb/2010_1204f.brd';
    9 q- v- ~" I- J+ m# WCmdLine: netrev -$ -i F:/L.R.Town/dev -t -y 1 -z F:/L.R.Town/pcb/#Taaaaaa03424.tmp/ J+ X+ O" ]# [/ K6 j5 v5 q
    ------ Preparing to read pst files ------& N. A) p% {% f2 s1 \/ V0 M
    Starting to read F:/L.R.Town/dev/pstchip.dat
    - d4 o" h3 ?; h  w4 W+ V3 c* H, U   Finished reading F:/L.R.Town/dev/pstchip.dat (00:00:00.07)
    2 d# l9 W8 d( b8 d7 D* {Starting to read F:/L.R.Town/dev/pstxprt.dat
    : w0 ]: F- i* p! t' ~9 s# _9 H   Finished reading F:/L.R.Town/dev/pstxprt.dat (00:00:00.03)
    " h# t+ }7 F9 v8 [Starting to read F:/L.R.Town/dev/pstxnet.dat
    4 `/ g  O2 a6 B( D   Finished reading F:/L.R.Town/dev/pstxnet.dat (00:00:00.04)
    : c2 m) @6 v. U------ Oversights/Warnings/Errors ------
    . _: d5 e; x0 r9 ?; r2 o! {- A/ f) G; n
    9 D2 O* f4 v: |0 y#1   Run stopped because errors were detected
    ) b& A8 B4 P2 E+ [netrev run on Dec 5 0:32:39 2010
    % i2 c2 c$ f- W" L6 k   DESIGN NAME : 'L'; K; U7 h1 a, P, u( H9 Q
       PACKAGING ON Sep 28 2008 21:55:15
    & }. M5 y# T% _# n, n   COMPILE 'logic'; W+ N9 X% \: u* v. _
       CHECK_PIN_NAMES OFF+ u5 _" z( ]# I# w, q1 v2 R# L  ^
       CROSS_REFERENCE OFF6 G  P( n0 i8 s, n7 ^8 ~; }
       FEEDBACK OFF
    8 E. S0 T; V" z1 E8 B& Z5 _8 m   INCREMENTAL OFF
    0 E" I/ k& f* G' V& y5 X  a   INTERFACE_TYPE PHYSICAL
    " Z! t: \& [3 c3 r1 W+ r; h6 ?, {   MAX_ERRORS 500" }% S! F# p5 Y5 P
       MERGE_MINIMUM 5
    & |  W7 J4 ]1 x2 ], M- f6 ?   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'; y( u4 c3 H6 x6 k9 g+ G( n
       NET_NAME_LENGTH 24# }, a: @: k- t+ D
       OVERSIGHTS ON
    7 W( _) e; k- B8 o* Z% @   REPLACE_CHECK OFF
    6 Q" ~# q" k  j" `  B   SINGLE_NODE_NETS ON* ?" X3 J$ C) E# }3 H
       SPLIT_MINIMUM 0
    3 Z/ D# e: N$ p   SUPPRESS   20  F6 Z5 z- E  k5 o5 ?
       WARNINGS ON! V2 s$ k) Y5 ?, o, \4 n
      1 errors detected3 g, o, M- f- Z& n
    No oversight detected. U. j8 e3 @% y- f6 ?% g
    No warning detected. L# j( @" \9 k' j! X# [) b- m
    cpu time      0:06:08
    ) s; f3 r2 u5 X8 b* Q- Yelapsed time  0:00:03
    1 X! W+ \& T/ b/ ~6 q0 y7 [6 h% C8 `0 D% a7 f
    请大家帮忙解决
      P9 V1 [. k* c+ O5 v/ ~: N, c
    发表于 2010-12-6 10:16 | 只看该作者
    没贴全,他会提交ERROR具体的错误
    GMT+8, 2025-11-3 17:12 , Processed in 0.156250 second(s), 24 queries , Gzip On.
