查看: 864|回复: 4
matlab 错误
发表于 2020-9-29 17:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
错误提示如下:>> mosekdiag
: k$ [; n* J3 j$ m; ?# LMatlab version   : 9.6.0.1072779 (R2019a)0 E3 ^% z( J& \- O! t. x
Architecture     : PCWIN64* \5 }- A3 T/ c6 F' m; y& Y$ N
mosekopt path    : D:\some application\mosek\9.2\toolbox\R2015a\mosekopt.mexw64
- N& \0 u+ [* H% EMOSEK version    : 9.2.22 N) X" u% o( \& r
Test linear solve: Error 1008 (MSK_RES_ERR_MISSING_LICENSE_FILE)) `( N: M7 A1 K( s9 E' ^* ^
Error message    : License cannot be located. The default search path is ';C:\Users\Ge Xiao\6\licenses\mosek.lic;'.
; {0 m2 r* C- u* b*******************************************************( u& d5 ]: }4 d7 X) T9 J
Below is a more detailed debug info to help you identify the problem.
& n/ v5 j1 O8 S. x  h  a& h7 i4 MSee the licensing manual and inteRFace manual for troubleshooting tips.
# j( ]) s  G; D. b2 BThis error is related to licensing.* s! K& R( m5 A; `" F6 |
The line with "License path" below shows where MOSEK is expecting the license.
# u/ i: S! u$ @. o6 kMake sure the license is placed exactly there and is readable and up to date.9 O2 k, c/ V3 ~4 j, L6 y# Z9 ?
Try restarting MATLAB if you installed a new license file.9 B5 j; y# x& G- J+ P' q
*******************************************************6 O  ]' Q. l2 p
Detailed debug info:$ y, R: P8 p7 `; }) }0 W+ {. T3 K
Mosek: Open2 M" \5 O5 J! o6 Q/ A0 q
Mosek: Using matlab (1) or system calloc (0) ? 0* k  E; c) q, C5 O! P
Mosek: Make environment) S* C; a( n7 Q1 B% n* F! Q
Mosek: done. r: 0, adr of new env = 00000000618C1DE0
( j# O# u' R. X& R; r3 \& l7 NMosek: Echo intro% L% w, ^& C# s/ m
MOSEK Version 9.2.2(BETA) (Build date: 2020-3-11 08:12:28)
5 D+ w- e; F/ J0 g2 ?+ V# CCopyright (c) MOSEK ApS, Denmark. WWW: mosek.com( x! ^% C6 C. H# e4 d6 [8 ]3 [0 \
Platform: Windows/64-X86, r+ t+ T$ G. n) p
FlexLM  G2 R6 ]$ s3 L( H3 P, K& R4 e3 o
Version                  : 11.16
% @3 s: T2 {0 W1 _Hostname                 : LAPTOP-BCTR9K5U1 M# c/ A6 {& n4 h/ k
Host ID                  : "c809a80ecdb6 ca09a80ecdb5 c809a80ecdb5 c809a80ecdb9"( I% L: P3 o6 W7 K) m  C
License path             : C:\Users\Ge Xiao\6\licenses\mosek.lic
0 G, v  z! K+ u2 b* _+ I9 S7 L4 {Operating system variables
1 o/ ~# r# b, L4 OPATH                     :1 e% {$ @% X  t: s  ?5 V
Mosek: Check version  c4 q# T# m0 _' @
Mosek: done  g6 h1 ^: F6 U! s3 k6 |
错误使用 mosekdiag (line 100)# o  w1 Y$ }+ T. X. x6 H
Could not solve a test problem8 `& C7 {" L5 Y
发表于 2020-9-29 17:45 | 只看该作者
帮你顶一下
发表于 2020-9-30 13:22 | 只看该作者
这个问题还没遇到过,帮顶
发表于 2020-9-30 13:29 | 只看该作者
等一个大神,
发表于 2020-9-30 14:26 | 只看该作者
为什么没大神
GMT+8, 2025-11-2 22:29 , Processed in 0.125000 second(s), 23 queries , Gzip On.
