缺少解
. c5 a ?8 T. {% v: t6 {0 V! o. M: B$ a0 A! E7 R
- function[x,fval,exitflag]=fsolveDemo1
- x0=[0,0,0];
- options=optimset('MaxFunEvals',0,'MaxIter',3);
- [x,fval,exitflag]=fsolve(@f,x0);
- function F =f(x)
- F=[x(1)/4-x(2)/4; x(2)/4-(x(3)-2)/-2; x(1)^2+x(2)^2-4];
- end
- end
; ^9 |1 y( W" y2 Y( L
- P4 G5 A; j, j, y, |[color=rgb(51, 102, 153) !important]复制代码3 k) k- u4 P, f5 v
- %显示
- Equation solved.
- fsolve completed because the vector of function values is near zero
- as measured by the default value of the function tolerance, and
- the problem appears regular as measured by the gradient.
- <stopping criteria details>
- x =
- 1.4142 1.4142 1.2929
- fval =
- 1.0e-08 *
- 0
- 0.0000
- 0.3873
- exitflag =
- 1
- >> 2-1.414/2
- ans =
- 1.2930
- A% M0 }$ x1 H# z. K+ [# o' w " \" r/ @7 A0 _) B
" b7 _" n# {1 n+ }8 @/ ^# U) i其中x 的解只是其中的一个,另一个为什么没有显示?( G/ X( v* y3 {3 A( T- M, u( B
