[AD9][2层]1589O-6-AC27M参考板(EPM3064ALC44-10(44)+SN74HC74+LM2596S-5.0)pcb文件. |" w/ }/ N4 V5 K
% F. `$ x( U. i文件描述:$ I0 i' C* j: M" {8 c/ U8 s4 z- M' F
1 p" [- a# b9 n, l8 d+ _
1. 作品用途:1589O-6-AC27M参考板
7 I* X8 ^4 n$ T- {" |2. 软件版本:AD9
! a o$ |5 X$ M' n2 [3. 层数:2层 G) Z6 U2 d( K( e$ w& o/ m4 D
4. 用到的主要芯片:EPM3064ALC44-10(44)+SN74HC74+LM2596S-5.0
5 i' {4 O' g# F( h" ~ w5. pcb尺寸:160*109 MM' O9 p+ t, c) V* O7 \/ ?
作品截图如下:
2 ~& G) c2 N6 j- g3 `: T( Y1 U G1 M" k/ K
顶层截图:! O6 w! G7 y% P- j' B0 t
) k% m1 m" l* R) R: G
底层截图:0 j/ \0 Y0 O! g1 ?) P3 U
% S0 |0 h- v+ m5 c
$ s# K6 m3 V1 Z8 E% P+ C% {
全层截图:
/ e) }2 n4 \. Y7 w* Y2 N( X3 \) R) m
5 ` Y/ A3 H3 _, A/ C
叠层阻抗信息如下:
0 Z6 B' B3 V% J: }! Z, A
: y1 a* S- i" j! D; q; x
* ]# b0 T ~- P& {$ O
BOM:
[0 R- l1 o# g: UComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1UF | C1, C2, C3, C6, C15, C17, C20, C21, C22, C23, C50, C51, C52, C53, C54, C71, C72, C73, C83, C84, C92 | 1206 | 21 | 30PF | C4, C5, C59, C60, C61 | 1206 | 5 | 0.01UF | C7, C14, C55, C74 | 1206 | 4 | 240P | C8, C12 | 1206 | 2 | 0.33UF | C9 | KRAD0.2 | 1 | 10UF | C10, C16, C63, C85 | MLL34 | 4 | CD11X-25V-680UF | C11 | KCAPZ2 | 1 | CD11X-16V-220UF | C13 | KCAPZ | 1 | 0.47UF | C18 | MLL34 | 1 | 2.2UF | C19, C64, C65, C66, C67, C68, C75, C76, C77, C82, C88 | MLL34 | 11 | 12PF | C56, C89 | 1206 | 2 | 10PF | C57, C90 | 1206 | 2 | 5P | C58 | 1206 | 1 | 1000PF | C62, C91 | 1206 | 2 | 5PF | C69, C70 | 1206 | 2 | 200PF | C78, C79, C87 | 1206 | 3 | 51PF | C80, C81 | 1206 | 2 | 51P | C86 | 1206 | 1 | 1N5819 | D1 | KDIODE0.4 | 1 | 1N5824 | D2 | KDIODE0.4 | 1 | 1N4448 | D50, D51 | KDIODE0.4 | 2 | FUSE1 | F1 | KRAD0.2 | 1 | CON2 | J1 | KSIP2 | 1 | XH 2.54-4P | J2 | HCSIP4 | 1 | CON6 | J3 | KSIP6 | 1 | HEADER 5X2 | JP1 | M12-GPS | 1 | XH 2.54-2P | JP50, JP51 | HCSIP2 | 2 | 33UH | L1 | L-150 | 1 | 3.9UH | L50 | KAXIAL0.4 | 1 | 4.7UH | L51 | KAXIAL0.4 | 1 | 100UH | L52, L54 | KAXIAL0.4 | 2 | 1MH | L53, L57 | KAXIAL0.4 | 2 | 12UH | L55 | KAXIAL0.4 | 1 | 18UH | L56 | KAXIAL0.4 | 1 | LM2596S-5.0 | N1 | TO-263-5 | 1 | AMS1117-3.3V | N2 | SOT-223 | 1 | 2N2222 | Q50, Q51, Q52, Q53, Q54, Q55, Q56, Q57, Q58, Q59, Q60, Q61 | KTO-92 | 12 | 10K | R1, R2, R5, R7, R8, R9 | 1206 | 6 | 300 | R3, R12, R13, R51, R52, R53, R88, R89, R90 | 1206 | 9 | 3K | R4, R14 | 1206 | 2 | 4.7K | R6, R50, R74 | 1206 | 3 | 1K | R15, R63 | 1206 | 2 | 430K | R16 | 1206 | 1 | 750 | R54, R91 | 1206 | 2 | 6.2K | R55, R92 | 1206 | 2 | 2.7K | R56, R95 | 1206 | 2 | 620 | R57, R96 | 1206 | 2 | 5.1K | R58, R59, R83, R93 | 1206 | 4 | 10 | R60, R61, R62, R78, R79, R80, R81, R94 | 1206 | 8 | 51 | R64 | 1206 | 1 | 12K | R65, R75 | 1206 | 2 | 510 | R66, R76 | 1206 | 2 | 8.2K | R67, R97 | 1206 | 2 | 390 | R68, R77 | 1206 | 2 | 100 | R69, R82 | 1206 | 2 | 1.5K | R70, R86 | 1206 | 2 | 30 | R71, R72, R84, R87 | 1206 | 4 | 120 | R85 | 1206 | 1 | 1K | RW50, RW52 | KREV | 2 | 50 | RW51, RW53 | KREV | 2 | KT1 | T50, T51, T52, T53, T54, T55 | SSTT10 | 6 | SN74HC04 | U1, U2, U3 | SO-14 | 3 | AT89C2051 | U4 | DIP-20 | 1 | SN74HC00 | U5 | SO-14 | 1 | SN74HC74 | U6 | SO-14 | 1 | EPM3064ALC44-10(44) | U7 | KPGA44X8 | 1 | ICS501 | U9, U10 | SO-8 | 2 | IMP813L-CPA | U31 | DIP-8 | 1 | CDDX1401 | U32 | KSIP11 | 1 | MAX4017ESA | U50 | SO-8 | 1 | 11.0592M | Y1 | XTAL1 | 1 | VCXO-27M | Y2 | VCXO-1 | 1 |
: ]. @' d: L/ J, D1 \* t附件:7 o* T7 X- e+ q( j
pcb文件如下: V6 J8 u5 V) I9 O) A: U( P+ {
| , \" U) h. z* E0 c7 U6 J/ E' |" h0 q
