TA的每日心情 | 衰 2019-11-19 15:32 |
签到天数: 1 天 [LV.1]初来乍到
% J# a% y4 u4 ?
- `- w4 K3 I( J _& \8 q( r
. _9 k4 Q; N. F! Y; }- Q- Disk /dev/sda: 30 GiB, 32212254720 bytes, 62914560 sectors
- Units: sectors of 1 * 512 = 512 bytes
- Sector size (logical/physical): 512 bytes / 4096 bytes
- I/O size (minimum/optimal): 4096 bytes / 4096 bytes
- Disklabel type: dos
- Disk identifier: 0x9f740dc2
- Device Boot Start End Sectors Size Id Type
- /dev/sda1 * 2048 46530559 46528512 22.2G 83 Linux
- /dev/sda2 46532606 62912511 16379906 7.8G 5 Extended
- /dev/sda5 46532608 62912511 16379904 7.8G 82 Linux swap / Solaris
- Partition 2 does not start on physical sector boundary.
- Disk /dev/sdb: 110 GiB, 118111600640 bytes, 230686720 sectors
- Disk identifier: 0x4fae9b3a
- /dev/sdb1 2048 214302719 214300672 102.2G 83 Linux
- /dev/sdb2 214304766 230684671 16379906 7.8G 5 Extended
- /dev/sdb5 214304768 230684671 16379904 7.8G 82 Linux swap / Solaris
' \+ Y0 w9 c, _6 q& s2 u" j - a6 \: Y2 E4 s# y! E+ F$ @
5 U9 J: I* }/ x7 h6 G* D, x
: D; \( v/ t' v) d- e2 V! D f' i5 S
/ t# d; _, z6 j- root@hn:~# df -h
- Filesystem Size Used Avail Use% Mounted on
- udev 3.8G 0 3.8G 0% /dev
- tmpfs 775M 81M 695M 11% /run
- /dev/sda1 22G 14G 7.2G 66% /
- tmpfs 3.8G 48K 3.8G 1% /dev/shm
- tmpfs 5.0M 0 5.0M 0% /run/lock
- tmpfs 3.8G 0 3.8G 0% /sys/fs/cgroup
- tmpfs 775M 0 775M 0% /run/user/0
, g, ^7 R4 d9 [7 y5 [" s & S4 Y1 c+ z) Y6 {
6 O9 ` k6 k* O; W- c
8 U8 h+ a" @, I; y# E& r
- m! M$ i, P P* A8 W8 j( l" |2 a6 {& Y) S. L$ V
硬盘是120g的,但是实际上只有20多G,只有一块硬盘
0 o# ~" y% y4 m( @: p在网上查了一些命令,但是涉及的操作太多,我怕把系统搞坏& l) b& U) F7 Z7 e$ b$ j+ o! m3 V
1 f, e0 S! {+ m8 U$ ~ |
