查看: 10850|回复: 7
帮偶分析分析为何不能生成网络表
    2021-5-25 15:04
  • 签到天数: 37 天
    [LV.5]常住居民I
    发表于 2008-5-6 13:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    偶是第一次 capture,生成网络表的时候的时候出现如下错误
    5 m" I) }+ j) i1 YE:\CANDENCE\练习\allegro
    ' Y6 `0 V6 c( t" I! P; NConfiguration File:
    ; g' J3 G: s- f. oC:\cadence\SPB_15.5\tools\capture\allegro.cfg$ j& X% h# f1 u9 s
    Spawning... "C:\Cadence\SPB_15.5\tools\capture\pstswp.exe" -pst -d "E:\candence\练习\2440mornitoring.dsn" -n "E:\CANDENCE\练习\ALLEGRO" -c "C:\Cadence\SPB_15.5\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"( {/ b) y! L8 U* ^$ L4 s) m# h
    #1 Warning [ALG0047] "No_connect" property on Pin "P1.8" ignored for P1: SCHEMATIC1, 13)URAT (7.90, 1.20). Connecting pin to net "N16811229".4 Q% L: [( m( T3 r
    #2 Warning [ALG0047] "No_connect" property on Pin "P2.7" ignored for P2: SCHEMATIC1, 13)URAT (7.90, 3.60). Connecting pin to net "N16811584".
    * D* Q1 J! b1 `! a- l3 P- d0 r' M#3 Warning [ALG0047] "No_connect" property on Pin "P1.7" ignored for P1: SCHEMATIC1, 13)URAT (7.90, 1.20). Connecting pin to net "N16811225".
    / P3 Y) q2 p  q: d#4 Warning [ALG0047] "No_connect" property on Pin "P2.8" ignored for P2: SCHEMATIC1, 13)URAT (7.90, 3.60). Connecting pin to net "N16811590".2 \+ ?$ m' T- z2 T" [* ~
    #5 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_100UF/6.3V" is renamed to "CAP PN_C100UP-6.3V-SMT-S_100UF/".: k% ?; ?1 W2 e. l
    #6 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_10UF/10V" is renamed to "CAP PN_C100UP-6.3V-SMT-S_10UF/1".
    % I# J5 k& k. T) @7 r2 P( @#7 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_100U/6.3V" is renamed to "CAP PN_C100UP-6.3V-SMT-S_100U/6".
    2 W8 K+ E' [# t- }3 B#8 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_220UF/4V" is renamed to "CAP PN_C100UP-6., C0 l) N3 W, u+ u; E  \
    3V-SMT-S_220UF/".1 q2 C% h. W9 O, _3 q1 v
    #9 Warning [ALG0016] Part Name "SINGLE_PORTS_COMBO_0_RJ-45B_HR901103A" is renamed to "SINGLE_PORTS_COMBO_0_RJ-45B_HR9".
    - }1 R  ]  K* \- R#10 Warning [ALG0016] Part Name "UCDRAGON LCD CONNECTOR_0_SIDC50_IDC50-2.00MM" is renamed to "UCDRAGON LCD CONNECTOR_0_SIDC50".
    ! q4 f) j+ X( }#11 Warning [ALG0016] Part Name "CON IDE44-2MM_0_SIDC44_IDC44-2MM" is renamed to "CON IDE44-2MM_0_SIDC44_IDC44-2M".' |  E& }" {* I
    #12 Warning [ALG0016] Part Name "CON_USB_B_0_USB-B2_USB_HOST_PORT" is renamed to "CON_USB_B_0_USB-B2_USB_HOST_POR".# C% }0 d3 l( ?8 ?1 |2 Y
    #13 Warning [ALG0016] Part Name "USBPORT_1_USB-B1_USB_DEVICE_PORT" is renamed to "USBPORT_1_USB-B1_USB_DEVICE_POR".
    ' @( D, H# {: h2 t8 i3 t2 k' }#14 Warning [ALG0016] Part Name "IDC20 MULTI-ICE_0_20PIN2_IDC20-2.54MM" is renamed to "IDC20 MULTI-ICE_0_20PIN2_IDC20-"., h7 q/ R; z" o1 P- `5 U
    #15 Warning [ALG0016] Part Name "DIODE SCHOTTKY_1_MBRS340_MBRS340" is renamed to "DIODE SCHOTTKY_1_MBRS340_MBRS34".$ S2 j; F8 X# m" x; s$ ?
    #16 Warning [ALG0016] Part Name "HEADER 20_0_SIDC20_CAMERA_EXTEND" is renamed to "HEADER 20_0_SIDC20_CAMERA_EXTEN"., T2 y9 S) E! O6 T0 r" H, n4 U0 B! L: A
    #17 Warning [ALG0016] Part Name "PHONEJACK STERE
    * P" X& h7 e9 A4 }5 J, uO SW_EARPHONE2_MICROPHONE_CN" is renamed to "PHONEJACK STEREO SW_EARPHONE2_M".
    " N( W1 i: b) v/ k4 I3 T% k#18 Warning [ALG0016] Part Name "PHONEJACK STEREO SW_EARPHONE2_EARJACK" is renamed to "PHONEJACK STEREO SW_EARPHONE2_E".
      S* r5 T. |6 n* u2 I9 W* ~#19 Warning [ALG0016] Part Name "MAX232_1_MAX3232ESA-SO16_MAX3232C" is renamed to "MAX232_1_MAX3232ESA-SO16_MAX323".' p8 s; Y" R) Z0 Q. P
    #20 Warning [ALG0016] Part Name "IRMS6452 VISHAY_IRMS6452_IRMS6452" is renamed to "IRMS6452 VISHAY_IRMS6452_IRMS64".' m9 U3 K8 i; W. y9 G, I  q  H6 m
    #21 Warning [ALG0016] Part Name "DM9000A LQFP48_0_DM9161E-QFP48_DM9000AE" is renamed to "DM9000A LQFP48_0_DM9161E-QFP48_".8 y- G; v' j4 @' j- E2 [2 T, C
    #22 Warning [ALG0016] Part Name "74ALVC164245_8_TSSOP48_74LVCH162245" is renamed to "74ALVC164245_8_TSSOP48_74LVCH16".
    . e% R8 C' A, E#23 Warning [ALG0016] Part Name "74ALVC164245_1_74LVTH162245-TSSOP48_74LVCH162245" is renamed to "74ALVC164245_1_74LVTH162245-TSS".
    2 i6 R, j! P9 X# z: p- E#24 Warning [ALG0016] Part Name "MIC5207BM5_MIC_LDO_5_MIC5207-2.5BM5" is renamed to "MIC5207BM5_MIC_LDO_5_MIC5207-2.".& l& g  E% t9 }- ~. s, Z+ [
    #25 Warning [ALG0016] Part Name "MIC5207BM5_MIC_LDO_5_MIC5207-1.8BM5" is renamed to "MIC54 _: P1 H3 Q+ b4 f4 b- [  A
    207BM5_MIC_LDO_5_MIC5207-1.".; @9 K, x5 d) [0 Z( _; V
    #26 Warning [ALG0016] Part Name "UDA1341TS_UDA1341TS-SSOP28_UDA1341TS" is renamed to "UDA1341TS_UDA1341TS-SSOP28_UDA1"./ Y" C: S( e, Z# s4 u
    #27 Warning [ALG0016] Part Name "LP3965ES-ADJ_0_TO263-5_MIC29152BU" is renamed to "LP3965ES-ADJ_0_TO263-5_MIC29152".' n+ `# x8 K8 _  L/ x
    #28 Warning [ALG0016] Part Name "74ALVC164245_8_74LVTH162245-TSSOP48_74LVCH162245" is renamed to "74ALVC164245_8_74LVTH162245-TSS".
    0 e# Y+ f6 O/ @#29 Warning [ALG0016] Part Name "EZ1117X/SOT223_0_LD-2.5V-SOT23_LM1117-ADJ" is renamed to "EZ1117X/SOT223_0_LD-2.5V-SOT23_".7 @$ R# m! v* _9 h; e; P4 m! ^" }& P
    #30 Warning [ALG0016] Part Name "K4S561632C_0_K4S561632E-TSOP54_K4S561632C-TC75 (32MB)" is renamed to "K4S561632C_0_K4S561632E-TSOP54_".
    # @- ^$ X0 y0 t3 ^/ J#31 Warning [ALG0016] Part Name "K9F2808/1208_0_SST39VF1601-TSOP48A_K9F2808/5608/1208" is renamed to "K9F2808/1208_0_SST39VF1601-TSOP".
    * t$ i5 V& F( d$ n% `' Y#32 Warning [ALG0016] Part Name "XTAL-SMD2_XTAL_HC49SMT_25.000MHZ" is renamed to "XTAL-SMD2_XTAL_HC49SMT_25.000MH".+ {' z7 h# v# {* J
    Scanning netlist files ...
    ! w+ M0 I2 w& }( aLoading... E:\CANDENCE\练习\ALLEGRO/pstchip.dat0 F, Z* L) F1 M6 s, a! Q
    Loading... E:\CANDENCE\练1 Q" i; [) m/ D
    癨ALLEGRO/pstchip.dat2 ~6 I/ T+ i: s5 }) q/ f% V
    Loading... E
    / A3 A% \2 v) U# @9 n2 \: d; E:\CANDENCE\练习\ALLEGRO/pstxprt.dat
    # S: a& J0 r% `9 M( x% \) S5 i- yLoading... E:\CANDENCE\练习\ALLEGRO/pstxnet.dat: _+ }. {5 v2 l0 c" Y6 A; l+ h
    Error: Line 443 in file E:\CANDENCE\练习\ALLEGRO/pstxnet.dat:% N% G8 L# w1 o
       Could not create new pin inst <logicalPinName>
    , F- L. b4 j) |' K, \+ `$ r Detected in function: pstReadNodeSec
    - A* i' A; A& A) b/ F& q& v& YError: Line 443 in file E:\CANDENCE\练习\ALLEGRO/pstxnet.dat:0 ^9 u% f6 o- \: W: A1 C1 I# y+ b
       Error loading the net list file
    7 n& A5 _4 b3 V& @4 i7 o; ? Detected in function: ddbLoadPstXFiles & G/ ~7 [6 w. q- v
    #33 Error   [ALG0036] Unable to read logical netlist data.
    ( i. G  b% _% f' n) C) m$ tExiting... "C:\Cadence\SPB_15.5\tools\capture\pstswp.exe" -pst -d "E:\candence\练习\2440mornitoring.dsn" -n "E:\CANDENCE\练习\ALLEGRO" -c "C:\Cadence\SPB_15.5\tools\capture\allegro.cfg
    发表于 2008-5-6 14:56 | 只看该作者
    楼主不能有中文呀
    2021-5-25 15:04
  • 签到天数: 37 天
    [LV.5]常住居民I
     楼主| 发表于 2008-5-6 17:31 | 只看该作者
    改过后还是出现同样的错误,不知道元件的封装和capture里的图如何对应起来,好象我随便用一个封装名字都可以
    发表于 2008-5-6 19:20 | 只看该作者
    对呀,我们从库里面选择一个元件后,那元件本身有一个默认的封装,如果我想改成适合自己的封装,直接电击part property后在footprint里面填写一个封装后,就会出现好多这样的warnings,- @( J* b- A9 W
    $ U0 ^* I/ v: w这个问题该怎么解决呀,版主,你出找吧,兄弟都等你救命呢!!!!!!!!!
    发表于 2008-5-7 09:19 | 只看该作者
    早上以来就看这一串,头痛的呢
    参与人数 1贡献 +5 收起 理由
    kxx27 + 5 给点鼓励!
    发表于 2008-5-7 09:24 | 只看该作者
    这样吧,一类一类的来分析。: q7 R) A# \  ^, u
    #1 Warning [ALG0047] "No_connect" property on Pin "P1.8" ignored forP1: SCHEMATIC1, 13)URAT (7.90, 1.20). Connecting pin to net "N16811229".6 R: S% ]2 H# x: S4 P
    . r3 D( |7 t) g4 x3 o
    ALG0047,这个警告基本可以忽略;造成这个问题的原因是,设计之初先对器件相关的管脚上加上'X'(也就是NC符号),更新设计的过程又对管脚做了连接处理;但是后面的连接处理没有去掉管脚的NC属性,不信的话把那个管脚上的net删掉看看。
    - w9 K$ S$ o3 y2 V解决办法很简单,对这些管脚再做一次NC
    发表于 2008-5-7 09:28 | 只看该作者
    #5 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_100UF/6.3V" is renamed to "CAP PN_C100UP-6.3V-SMT-S_100UF/".' K6 T: n+ K9 @0 k6 A
    8 [) Z3 S, D; S3 z6 g0 Y/ F) a/ m4 I这个警告不可避免,allegro对相关的属性名称进行合并,超过一定数量的字符就截掉;在命名规范的前提下就不考虑这个警告了。
    . K  b; M1 P$ d; ~3 S无法根治
    发表于 2008-6-2 15:41 | 只看该作者
    这个#2 Warning [ALG0016] Part Name 3 c2 @3 p' X  @8 Y5 J
    之类的错误在于你建立元件原理图的时候你的原件Value值太长了超过32个字符,从而使系统在进行命名规范的时候溢出,而出错,很简单的,只写关键元件名,比如! e. u! \& P" r9 N, J' O
    A2541P10_HDR2X5-100MIL_2X5 HEADER" is renamed to "A2541P10_HDR2X5-100MIL_2X5 HEAD错误只需要8 i4 J, G- q0 Y  ?2 e3 M5 m$ E7 [2 q
    把2X5 HEADER更改为A2541P10,去除中间的空格即可." s4 ^( g% }1 L6 c' {, c
    Allegro对一些字符[例如"空格","小数点"等等]很在意,可以参阅相关文档的描述.
    GMT+8, 2025-9-30 07:43 , Processed in 0.125000 second(s), 25 queries , Gzip On.
