查看: 1198|回复: 1
17.2 不能更新元件封装的问题
发表于 2020-8-26 11:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大伙有没有遇到17.2  不能更新元件封装的问题,  我用了S063, S053的补丁, 测试全是不能更新元件,元件库里改了焊盘,从PCB中更新不了, ------ Symbol Refresh Messages ------
/ H) U: n8 b) H. h
- I' k+ g5 k- n0 _7 I( ?
4 s5 k- y) L% z'R0402X'  symbol starting to refresh:
% t( L5 F2 b' S3 h6 f5 _     ERROR(SPMHDB-238): The design is corrupted. It may have been copied from a different architecture using ASCII mode; copy usin~
9 t# q8 X4 T2 R% [0 ]4 b! w     g binary mode.
6 W6 \+ L/ b& Q( N( n' A. M' p% X! O     ERROR(SPMHNI-254): Unable to load symbol, 'R0402X': 'The design is corrupted. It may have been copied from a different archit~5 O# E' {4 p+ E% K" b2 A; U
     ecture using ASCII mode; copy using binary mode.'.
  k% H+ @. J6 v# ^( @0 ^/ L: P$ X
; d( J5 {! x& c6 p+ `' q- K$ D
& Q1 T5 ?$ |) P) Z! j. H0 u0 [8 k8 V3 b+ r, F# ^, c) p
------ Pad Stack Refresh Messages ------
& I: G& W3 j( s6 x% d" m. e# F
; J" \4 n8 k/ g5 F% m# j1 w) w% X; b4 w( P' w$ H6 B  [, v: I
'SMD0R508X0R508'  pad stack refresh starting.
5 ~0 W5 X% ~3 m$ }8 T, _" H- z     WARNING(SPMHGE-126): Cannot load padstack: 'SMD0R508X0R508'.
. N. r  \1 w# y# j4 C
; k8 i7 N8 b1 W' T3 Y- Y2 F! g* s2 E9 E, O
----- Symbol Update Summary ----% t9 O/ y/ Y4 f! S; [2 Y0 s
8 W4 U, Q' o. k- @( }) f9 f. T( a8 jRefresh symbol errors; due to these errors this design is NOT updated.
. l; F1 k! K7 _       1  errors detected./ p5 F* p/ P+ j
       1  warnings detected.3 B7 p0 Q3 N! N, T
提示大多是这样, 焊盘,PSM的路径均没问题,  只有我把元件从编辑区中删除,再放进来时,发现它能更新,但是整板上全是0402,又怎么能这样做呢?  还有原理中改成0603,刷网表成0603,再刷回来就可以更新,但都是下策,不知道有什么直接的原因,这么大的BUG?
    2023-1-3 15:10
    发表于 2020-8-26 17:42 | 只看该作者
    你新建的PAD名称不能跟修改前的一样,不然就替换不了
    GMT+8, 2025-9-10 23:01 , Processed in 0.109375 second(s), 23 queries , Gzip On.
