查看: 7027|回复: 2
orcad 16.3 器件被锁定,怎么办???
发表于 2010-10-20 19:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
orcad 16.3 器件被锁定,提示locked。。。。; z4 z* Z& ~. m; r! N& `9 \
/ b" k5 `+ F( M# ^/ D1 R4 ~6 Y9 z# ^/ ?我在操作的时候不知道怎么把一个器件锁定了,无法对器件做任何操作,不知道怎么解除,,请高手指教。
3 [6 V, C, ]) F谢谢!
( d+ d  i# q' F& v" z
发表于 2010-10-27 11:24 | 只看该作者
能否将具体点,在什么情况下被锁住了,能否上传电路图上来,仅仅被锁住的那部分也可以
发表于 2010-10-27 11:35 | 只看该作者
ctrl+L unlcok
1 W1 n( i6 Y% t( P9 i* @5 c+ kL lock. p; C, d2 N8 w3 R) ^1 p
. H  u* P4 v% F& y- u" z  C! cLocking and Unlocking Objects
! {) V: f7 }' B3 \# u, C& k5 }- dOften you need to work in a cross-application environment with Capture. In this case, you need to select components in Capture for display or selection in another (for example, PCB Editor). In this case, you may inadvertently shift a component you select on the schematic page or disturb the connectivity of the circuit. To avoid this, you can temporarily lock a component onto you canvas. This prohibits you from moving the component on the schematic page. 5 s" C1 t* C( E
Note:  This lock operation is a is only used to prevent repositioning of the component. This means you can do any other operations on a locked component, like change its properties or delete the component.
. c$ [* E6 g% X8 nTo lock a component
7 b& e) z  g- i6 K4 C6 T5 Y% `Press and hold down the Shift + Ctrl key combination.
* Y* X# U4 {6 ~0 ULeft-click on the component.& l( S0 C% T3 u) _- O
To lock multiple components, perform these steps on continuously on multiple components.
+ O% ]9 s7 X- E7 _, p& yThe component is selected by the left-click operation but also it is locked (by the Shift + Ctrl key combination) so you cannot move the component. Now if you left-click the component it remains selected.
) M+ L0 n6 `0 ^2 }" O( E" A8 U- _) {To unlock a component + B6 d2 B- k" g! I' [
Left-click anywhere on the schematic page or on another component.
GMT+8, 2025-9-10 04:12 , Processed in 0.109375 second(s), 24 queries , Gzip On.
