[AD9][2层]HT55031参考板(EP3C16E144+74HC541+MAX3232)原理图和pcb文件1 B$ N+ V! o# T D
; O8 ^+ d* B6 n* F) i5 P
文件描述:
+ K7 G: O* E+ z- J9 a4 ^+ @! i" [9 K" {7 f7 @* R1 F
1. 作品用途:HT55031参考板
" b4 X- f% D& W* o) r' e. p W+ A2. 软件版本:AD9
; B( a) z5 ?; g3. 层数:2层
9 p! j# Z# E4 I0 m1 ]4. 用到的主要芯片:EP3C16E144+74HC541+MAX3232# ]: X D9 @7 x+ |7 B# }
5. pcb尺寸:160*233.35 MM( o0 F. [9 c7 f4 E9 ?
作品截图如下:$ G" p% f! z1 c: J$ Y3 {( C% }1 ^
" B/ E3 [; t; d- h. X. G9 j
顶层截图:
( f2 R) ]7 O' ~
8 a& N3 X- M% X/ `4 p底层截图:
4 O4 O5 ]/ N+ Y, y
5 _/ r: o* U* D' d" q' A0 [
1 E8 Y) G" r8 a
全层截图:
8 {: m8 F$ o0 {& H q5 j+ d" u
9 z8 s$ o( f8 n9 X7 K( y
# V2 v8 R0 r3 A叠层阻抗信息如下:- c+ {# L: @5 S, D
3 z; b) p* E. u, t0 r* {
BOM:4 |$ V# z$ V4 a" i' d
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 0.1UF | C1, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C22, C26, C27, C28, C38, C39, C40, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C55, C56, C57, C58, C59, C60, C61, C62, C63, C64, C65, C66, C67, C82, C83, C84, C85, C96, C98, C99, C100, C101, C102, C103, C104, C105, C106, C107, C112 | 0805 | 69 | 1000PF | C2, C93 | 0805 | 2 | 0.01UF | C23, C30, C31, C32, C33, C34, C35 | 0805 | 7 | 25V-10UF | C36, C37, C79, C91, C94, C95, C108, C109, C144, C145 | MLL34 | 10 | 2.2P | C41, C69 | 0805 | 2 | 1P | C70, C71 | 0805 | 2 | 2.2uF/50V | C72, C73 | 0805 | 2 | 27P | C74, C75 | 0805 | 2 | 270P | C76, C77 | 0805 | 2 | 10uF/25V | C78 | 1210 | 1 | 25V-10UF | C80, C81 | 1210 | 2 | 103 | C86 | 0805 | 1 | 10nF | C87, C88 | 0805 | 2 | 25V-2.2uF | C89 | MLL34 | 1 | 2.2UF | C90 | MLL34 | 1 | J1-IEC-61076-4-101 | J1 | J1-IEC-61076-4-101 | 1 | J2-IEC-61076-4-101 | J2 | J2-IEC-61076-4-101 | 1 | J3-IEC-61076-4-101 | J3 | J3-IEC-61076-4-101 | 1 | J4-IEC-61076-4-101 | J4 | J1-IEC-61076-4-101 | 1 | J5-IEC-61076-4-101 | J5 | J2-IEC-61076-4-101 | 1 | DC-2.54-10 | J6, J7 | IDC10 | 2 | GPS_TIANXIAN | J8 | BNC-1 | 1 | RS232 | J9 | SIP4 | 1 | TEST_RS232 | J10 | SIP3 | 1 | OUT_1PPS1 | J11 | SMA | 1 | OUT_1PPS2 | J12 | SMA | 1 | | J13 | AD3PS-1 | 1 | OUT_10MHz2 | J14 | SMA | 1 | OUT_10MHz1 | J15 | SMA | 1 | X72 | JP4 | X72 | 1 | | JP5 | KFPC-9696 | 1 | | JP6 | KFPC-4631 | 1 | | JP7 | KFPC-5141 | 1 | | JP9, JP10 | KFPC-3131 | 2 | 101J | L1, L2 | 1210 | 2 | 1R5J | L3, L5, L6, L7 | 1210 | 4 | 150UH | L4 | 1206 | 1 | 100UH | L8 | 1210 | 1 | | LED_1PPS | LED_SIP2 | 1 | GreenLED | LED_DL2 | LED_0805 | 1 | | LED_GPS, LED_LOCK | LED_2 | 2 | AMS1117-3.3V | N2, N3 | SOT-223/P2.3 | 2 | AMS1117-ADJ | N5 | SOT-223/P2.3 | 1 | 2N2222 | Q1 | KTO-92 | 1 | 2N3904 | Q3, Q4, Q5 | SOT-23 | 3 | 200R | R1, R2, R29, R55, R64 | 0805 | 5 | 100R | R3, R4, R6, R13, R22, R33, R51 | 0805 | 7 | 10R | R5, R23, R30, R50 | 0805 | 4 | 1K | R7, R8, R9, R10, R11, R12 | 0805 | 6 | 0 | R14 | 0805 | 1 | 10K | R16, R17, R18, R19, R20, R21, R25, R27, R28, R32, R34, R35, R43, R44, R45 | 0805 | 15 | 2R2 | R24, R26, R31, R46, R52, R53 | 0805 | 6 | 240R | R36 | 0805 | 1 | 51R | R37, R49 | 0805 | 2 | 510R | R38, R39, R40, R41, R42, R58 | 0805 | 6 | 4.7K | R47, R48, R56 | 0805 | 3 | 620R | R54 | 0805 | 1 | 8.2K | R57 | 0805 | 1 | LM7171 | U1, U6 | SO-8 | 2 | ublox-5s | U2 | GPS-5T | 1 | EPCS4 | U3 | SO-8 | 1 | 74HC541 | U4, U9 | SOL-20 | 2 | MAX3232 | U5 | SO-16 | 1 | AD5542CR | U7 | SO-14 | 1 | ADR445B | U8 | SO-8 | 1 | AD8675 | U10 | SO-8 | 1 | EP3C16E144 | U11 | TQFP144 | 1 | LT1715 | U12 | LT1715 | 1 | ICL7660S(-12V) | U13 | SO-8 | 1 | SN74LVC1G34 | U14, U15 | DBV_R_PDSO_G5 | 2 | CAT1025JI-30 | U19 | SO-8 | 1 | 50 MHz | Y1 | 50_JZ | 1 | $ m# ^5 p. ]) ~1 X+ M& ^' l. `" x
/ s, N5 v& r+ a; Y, ], S附件:& l. Q9 V6 V0 i! N, @& K3 ~! ^
原理图和pcb文件如下:- U0 P- b ]* c9 o4 l8 L
/ S+ C9 P* e) t8 l4 F |
