& ~ E+ \) `! \# w$ q* fAll 1000BASE-T PHYs are required to support Auto-Negotiation. " U3 ?! v3 S. }. l 5 n4 Z* {/ {8 \% O. v) J其次就是master 和slave的选择,在自动协商的第二个要素Auto-Negotiation of Master or Slave Resolution中,其中8.4.3.2部分的介绍是这样的: ( ?7 z: f7 c5 [& @" q$ J+ ~, }) P0 S2 O% V# g7 Q
If 1000BASE-T mode is selected during the priority resolution, the second goal of Auto-Negotiation is to resolve Master or Slave configuration. The Master mode priority is given to the device that supports multiport nodes, such as switches and repeaters. Single node devices such as DTE or NIC card takes lower Master mode priority.
