查看: 703|回复: 10
[AD9][4层]HT55032前面板(EP3C16E144+STM32F107+DP83640)原理图和pcb文件
发表于 2020-8-13 15:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[AD9][4层]HT55032前面板(EP3C16E144+STM32F107+DP83640)原理图和pcb文件( O( a% I9 f$ g# P, p9 J' `
7 G. B: _4 `" @# K$ D6 O文件描述:8 P7 D8 Q5 n& S$ ~1 U4 t4 S6 H
2 B( w0 }0 ?( b' b/ \' Q0 b( i
1. 作品用途:HT55032前面板% K6 Z! P# _# |2 Y! e
2. 软件版本:AD9. o- A0 t5 Y- ^) a1 F& |
3. 层数:4层; v: Z) @+ d, g9 @; j7 P8 g/ d
4. 用到的主要芯片:EP3C16E144+STM32F107+DP836404 z/ i( m. ^# [1 {% b' y
5. pcb尺寸:160*233 MM2 D4 w( [, r) x; Y6 u8 o2 w8 h
作品截图如下:
/ f3 K: B" J- |; k2 c9 b* r  V( B( X5 Y# t
顶层截图:
2 |6 M. \5 q7 m- l9 j( D ( y7 y7 |1 \/ O" d
底层截图:+ g8 |0 V( h% s: k- ~, d
( b" f. \. ~( [0 E* ]0 N# U
  E) H, m" Q; V6 [全层截图:
; h+ q! Z; g. |. T% A
+ [: G  X3 M! R3 b
4 K. _) ~- q9 E叠层阻抗信息如下:( O+ ~$ O' X5 C  v, o1 _/ [: Y* j* b# r
9 w# N3 F% t5 m& o9 w& GBOM:
+ K1 q7 W2 d# B3 q5 }! }1 w9 e
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
25V-10UFC1, C2, C12, C13, C27, C28, C38, C39, C53, C54, C64, C65, C1551210
13
10uFC3, C6, C20, C21, C29, C32, C46, C47, C55, C58, C72, C73MLL34
12
0.1uFC4, C7, C8, C15, C16, C17, C18, C19, C22, C23, C24, C25, C26, C30, C33, C34, C41, C42, C43, C44, C45, C48, C49, C50, C51, C52, C56, C59, C60, C67, C68, C69, C70, C74, C75, C76, C77, C78, C81, C82, C83, C84, C85, C86, C87, C88, C89, C90, C91, C92, C93, C94, C95, C96, C97, C98, C99, C100, C101, C102, C103, C104, C105, C106, C107, C108, C109, C110, C111, C114, C116, C120, C122, C123, C127, C131, C135, C141, C144, C146, C158, C159, C160, C161, C162, C163, C164, C165, C166, C167, C168, C169, C170, C171, C172, C173, C174, C175, C176, C177, C178, C179, C180, C181, C182, C183, C184, C185, C186, C187, C188, C191, C192, C193, C194, C195, C196, C197, C198, C199, C200, C201, C202, C203, C204, C205, C206, C207, C208, C209, C230, C231, C234, JP2, JP3, JP4, JP7, JP8, JP9, Q2, Q40805_C_Y
141
33pFC11, C14, C37, C40, C63, C660805_C_Y
CAPC71, JP12, JP13, JP14, Q60805_C_Y
10UF/25VC79, C80, C112, C113, C115, C117, C118, C124, C154, C156, C157, C189, C1901210
13
50PFC1190805_C_Y
0.01uFC121, C125, C132, C133, C137, C138, C139, C147, C148, C1490805_C_Y
10
2.2uF/50VC126, C1400805_C_Y
2.2PC128, C1420805_C_Y
1PC129, C1430805_C_Y
270PC130, C1450805_C_Y
27PC134, C1500805_C_Y
2.2UFC1361210
2.2UF/50VC1511210
1000PFC1520805_C_Y
0.1UFC153, C236, C239, C240, C241, C242, C243, C244, C245, C246, C247, C248, C249, C250, C251, C252, C253, C256, C257, C258, C259, C260, C261, C262, C263, C264, C265, C266, C267, C268, C269, C270, C2710805
33
10UF-50VC232, C233MLL34
10UF/25VC237, C238, C254, C255MLL34
LED1D1, D2, D3, D4, D5, D6, D7, D8, D9, D10, D11, D12LED_0805
12
CON6GPIO1, GPIO3HDR1X6
J1-IEC-61076-4-101J1J1-IEC-61076-4-101
RJ2-IEC-61076-4-101J2J2-IEC-61076-4-101
RJ3-IEC-61076-4-101J3J3-IEC-61076-4-101
RJ4-IEC-61076-4-101J4J1-IEC-61076-4-101
RJ5-IEC-61076-4-101J5J2-IEC-61076-4-101
78M05J6D-PAK
DC-2.54-10J7, J17, J18IDC10
CON3J8, J9, J10, J13HDR1X3
IN_1PPSJ11SMA
IN_10MHzJ12SMA
OUT_10MHz2J14SMA
OUT_1PPSJ15SMA
OUT_10MHz1J16SMA
JTAGJP1, JP6, JP11HDR2x10
CON3JP5, JP10, JP15, JP16, JP17, RSSIP3
CON8JZ110MTB
101JL1, L41210
1R5JL2, L3, L5, L61210
LEDLED0805C
LED1LED_GAOJINGLED_2
LED3LED_RX/TXLED_SIP2
LED2LED_SYNCLED_2
AMS1117-3.3VN1, N2, N3, N4, N5, N6, N8, N10, N12SOT-223/P2.3
9
AMS1117-ADJN7, N9, N11SOT-223/P2.3
Header 2X2P1HDR2X2
±12VPowerCON4
STM32F107Q1, Q3, Q5LQFP100_N
1.5kR1, R24, R27, R50, R53, R760805_R_Y
RESR20805_C_Y
49.9R3, R4, R5, R6, R29, R30, R31, R32, R55, R56, R57, R580805_R_Y
12
10KR7, R8, R9, R10, R11, R12, R13, R14, R15, R16, R18, R19, R21, R23, R25, R26, R33, R34, R35, R36, R37, R38, R39, R40, R41, R42, R44, R45, R47, R49, R51, R52, R59, R60, R61, R62, R63, R64, R65, R66, R67, R68, R70, R71, R73, R75, R77, R78, R82, R87, R91, R92, R93, R97, R102, R104, R105, R106, R109, R110, R111, R123, R124, R128, R131, R134, R137, R138, R139, R140, R141, R1420805_R_Y
72
4.87k .1%R17, R43, R690805_R_Y
100R20, R22, R46, R48, R72, R74, R119, R120, R121, R122, R143, R1440805_R_Y
12
RESR28, R540805_R_Y
240RR790805_R_Y
10RR800805_R_Y
100RR81, R85, R89, R99, R1070805_R_Y
1KR83, R86, R88, R94, R95, R96, R100, R101, R103, R125, R126, R127, R129, R130, R132, R133, R135, R1360805_R_Y
18
200RR84, R98, R114, R1170805_R_Y
51RR90, R1080805_R_Y
2R2R112, R113, R115, R1160805_R_Y
240RR1180805_C_Y
33RR145, R146, R147, R1480805
1KR149, R150, R151, R152, R153, R154, R155, R156, R1570805
9
10KR158, R159, R160, R1610805
240RR1620805
10kR1630805C
LAN2RJ-45LAN_8L
LAN1RJ-46LAN_8L
LAN3RJ-47LAN_8L
EP3C16E144U1, U2, U23TQFP144
DP83640U3, U5, U7LQFP48-1
MAX3232U4, U6, U8, U19, URSSO-16
DAC8531U9, U10TSSO3X6-G8/X.3
ADR445BU11SO-8_Y
LM7171U12SO-8
24C02U13, U21, U25SO-8
LT1715U14LT1715
EPCS4U15, U22, U26SO-8
LM7171U16SO-8_Y
ICL7660SU17SO-8
74ACT541U18SOL-20
SN74LVC1G34U20DBV_R_PDSO_G5
CY2305SIU24SO-8
32.768KHZY1, Y2, Y3HC-49/S_Y
, V% w5 k! R1 N. s3 S& ^
附件:
! S( C( l$ h, M" L原理图和pcb文件如下:
3 R1 C0 T/ L& N) \" P8 T6 F
游客,如果您要查看本帖隐藏内容请回复
5 Z5 f3 s% p3 A% D8 Z2 u$ ?7 N
发表于 2020-8-13 15:58 | 只看该作者
学习一下
    无聊
    2020-4-29 15:08
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2021-1-12 08:44 | 只看该作者
    学习dp83640
    发表于 2022-3-11 15:42 | 只看该作者
    好好学习,谢谢分享。。
    * Q3 ~: s+ ~/ v* r- m: \5 b1 q
    发表于 2022-3-15 13:48 | 只看该作者
    & V5 U2 ~; K6 P# J6 e, G# h! H+ Every good, thanks a lot
    慵懒
    2025-7-17 15:00
  • 签到天数: 151 天
    [LV.7]常住居民III
    发表于 2025-1-19 15:03 | 只看该作者
    学习一下
    ) P. L- ~, K+ g/ L
    GMT+8, 2025-7-18 01:46 , Processed in 0.171875 second(s), 27 queries , Gzip On.
